Question about Avaya Radio Communications
Avaya 6424D+M handset / headset
In work I use an Avaya 6424D+M with a handset however when I plug the headset into the headset socket to use that instead of the handset it doesn't work.
What equipment do you have? You might need an adaptor.
Is this fixed?
Posted on Jun 24, 2008
Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Feb 16, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
How do we complete a basic set up for Plantronic CS70 VT head piece?
Plug in powerpack to the base unit.
Unplug the handset with the curly cord from the phone and place both aside.
A short cord connects between the Handset socket on the PHONE and the PHONE socket on the BASE UNIT.(socket is near the power socket)
the HANDSET and curly cord plugs into the socket near the front of the base unit- it's the one that's extreemly hard to plug in!
Charge for 12 hours before use
Call someone and get them to stay on the phone while you turn the rotary knob (may need a screwdriver) on the side- keep turning it until you can hear each other
look for orange light as you hang it up to indicate that it's chaging
Good Luck!
Jan 13, 2010 | Plantronics CS70 Wireless Headset
Cannot hear the ring in my awh75n headset.
There should be a small wire with a 90 degree plug on one end and the other will have a small ropund piece. The plug plugs into the headset base. The round piece has sticky tape on it and plugs on the speaker beneath the handset.
Dec 16, 2009 | Avaya AWH75N Wireless Headset
I need the pinout for the Avaya 2400 series telephone headset RJ-11 Jack.
I noticed that Avaya headset is different from the Avaya handset or any other standard headset: The outer two pins are switched.
Avaya-Headset-pinning is like this:
Look to the RJ11 and turn it until you see leads from top and from front, then from left to right you look at
1) mic 5V
2) speak
3) speak
4) mic gnd
RJ11 of Avaya-handset and any standard headset/handset from the supermarket:
1) mic gnd
2) speak
3) speak
4) mic 5V
Hope that helps.
Nov 24, 2009 | Avaya 2420 Corded Phone
Handsfree not working
Make sure that the phone cord that comes out of the back of the CS50 base plugs into the Handset port of the avaya telephone, not the headset port.  Then make sure the coily cord that comes out of the telephone handset is plugged into the front of the CS50 base.
It takes 1.5 hours to charge to 80% capacity, and 3 hours for a full charge.  You will know it's charged fully because the yellow blinking light on the front of the base will now be solid.
May 15, 2009 | Plantronics CS-50 Professional Headset
Have 2 t7316e nortel phones...i can hear the other person, but they can't hear me...tried swapping handset, but that didn't resolve the issue...any answers?
Look at the bottom of the set that is giving you troubles, check to see if the handset is plugged into the correct spot.
It should be plugged into the Handset jack not the headset jack.
This is a common mistake.
Feb 23, 2009 | NorStar T7316E Telephone
Have the 6408D+ phone. Got a Plantronics CS55 Wireless Headset.
You can use an handset lifter accessory, such as the HL1 or HL10 to pick up the handset every time you need to use the headset.
Dec 12, 2008 | Avaya Definity 6408D Corded Phone
Avaya 4610 ip phone--wireless handset?
CS60 from Plantronics. A bit expensive but perfect
Dec 29, 2007 | Avaya 4610
- JPL Monaural Headset not working
Lift the handset, you might need an adaptor.
Nov 09, 2007 | Avaya Radio Communications
Radio Communications Logo
722 people viewed this question
Top Avaya Radio Communications Experts
Are you an Avaya Radio Communication Expert? Answer questions, earn points and help others
