Question about Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height
The rubber under the tank bowl is leaking were do i get the rubbe
The rubber that under the tank bowl is leaking were do i fine that at
How do you know what size regular or the extra wide one?
Posted on May 10, 2010
  • 31 Answers
You can get this at just about all hardware stores its a common iten try lowes or home depot if your local hardware store doent have them
Posted on Sep 13, 2009
My Briggs and Stratton mower was working fine 4 days ago, I put new premium gas into the machine today and it ran fine for 5 minutes then it conked out and will now not start at ball.
Never put premium gas in your mower,always use regular unleaded.Empty tank out,under the carb is a bowl,with a screw holding it on,remove screw and empty bowl,be careful and don't loose rubber washer,when you remove screw,gas will come out,put rags under bowl before you remove to catch gas,and always use lawnmower oil in the oil tank.Your spark plug may have fouled out,also replace it.You may need a socket to get screw off.
May 04, 2017 | Briggs Garden
Toilet tank to bowl small leak
You need to replace the tank to bowl nuts, washers, and gaskets as well as the flush valve gasket. One word of caution. When installing the new bolts to hold the tank in, place a rubber gasket under the washer inside the tank, and also one on each bolt under the washer underneath the tank. If you omit the one under the tank you may end up cracking the tank when you tighten it down.
Jan 16, 2014 | American Standard Cadet 3 Right Height...
1995 Honda XR 600 R leaks badly from the carburetor overflow hose
Hi, Anonymous and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
8. Damaged petcock diaphragm allowing fuel to flow through the vacuum line into the combustion chamber.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to repair leaking caburetor float bowl
Carbs leaking Here is how to fix it
XR600R service manual repair 1988 2000 XR600 Download Manuals Technical $15
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-xr-owners-manuals
Jun 29, 2013 | 1995 Honda XR 600 R
The tank leaks from the two bolts that hold tank to bowl. I replaced bolts and the rubber gasket (it has ears). Slow dripping from two bolts.
Under the heads of the two bolts (inside the tank) there should also be rubber washers. Remove the bolts, clean the bolt holes (in the tank) thoroughly (a nylon scouring pad works). If the rubber washer aren't new, replace them. If the bolts aren't new, replace them too. While you have it apart, thoroughly clean the surfaces where the large rubber gasket seats too, in case your leak is coming from there. If cleaning and new bolts and washers doesn't fix it, you might try some plumbers putty or bathtub silicon caulk (not on the large gasket). Coat the two rubber washer generously all over. Good luck.
Nov 01, 2010 | Eljer 141-0220-00 Toilet Tank White
Jacuzzi sent me new rubber gasket for attaching flapper assembly to tank-(held in place with a large white plastic nut) Does the totally flat side of the rubber washer face the tank or away from the tank?...
The rubber washer goes to the inside of the tank under the flush valve which gets screwed on with the large plastic nut on the bottom side of the tank. Then the foam gasket fits over the plastic nut which goes into the toilet bowl hole for the water to flow into the bowl. Tank needs to be removed from the toilet bowl.
Aug 31, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Theres a leak between tank and commode what needs replacing?
There are three rubber washers. There are two small ones under the heads of the bolts that pull the tank and the bowl together. (If this is a new toilet, it could be that these need a little tightening, but don't break it!) There is a large rubber washer where the water goes from the tank to the bowl.
f this is an old toilet, turn off the water, remove the water, remove the water supply pipe from the bottom of the tank, then remove the two bolts holding the tank and bowl together. Lift off the tank and you will see the rubber washers. Remove them and clean. Hardware stores have replacements. It might help to take the old washers with you to the store. You should replace the bolts if they are corroded. They sell kits that have the bolts and all three rubber washers included. Good luck. Al K
Aug 30, 2010 | Sterling Home
I have two new Drake toilets that were installed. The first one is working great but the second on is leaking from the bolt & nut that is connecting the tank to the bowl. Can You help?
It sounds like the tank bolts are not sealing. Make sure you used the rubber washer on the inside of the tank under the bolt. Also make sure bolt is fairly centered before tightening. You can purchase a set of tank bolts from your local home improvement center that contains rubber washers that will seal on both the top and bottom of the tank. In proffessional installations this is what I do. I hope this helps. Please vote on advise. Thank you.
May 13, 2010 | Toto C743S01 Cotton Drake Round Bowl Only...
Water leaks when flushed between tank and bowl.
You have a large rubber washer between the tank and the bowl that may need to be replaced. It is around 3 or 4 inches in dia.You have to take the tank off the bowl to replace it. You can get it at any hardware.
Hope this helps
Sep 15, 2009 | Home
I fixed (I think) a broken flaper valve assembly. In doing so, I created a leak where the bolts affix the tank to the bowl. I can't find a rubber gasket assembly (I don't even know if that is the right...
Go to home depot and tell them you need a tank-to-bowl gasket. They have them at home depot and it may come with new bolts for the tank-to-bowl fastening. New bolts would be a good idea to pick up anyway. One rubber washer under each head, then a rubber washer at the bottom of the tank. Use a metal washer and nut to secure this to the tank, then use another washer and nut from the bowl to the tank.
Jul 06, 2009 | Sterling Home
Pegasus Technologies Two-Piece Round Toilet by Pegasus - 15 3/4 Inch Bowl Rim Height Logo
126 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
