Question about Garden
Will not start
Will start (spark plug works) but then shut down and not restart when I turn off the choke. Grey exhaust coming from motor.
5 Suggested Answers
boscia
  • 163 Answers
SOURCE: ryobi weed trimmer
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. i
Posted on Nov 29, 2008
SOURCE: Homelite AP 125 two stroke motor will not start
If you have a two line fuel system make sure the lines didn't get crossed. If they are you could still get gas to the cylinder but not enough. I hope this will of some help to you. Donnyb60
Posted on Mar 18, 2009
  • 127 Answers
SOURCE: My husqavarna 28cc will start fine but when i turn
the carb needs to be rebuilt they have 50 hrs service use
Posted on Aug 22, 2009
rycgl
  • 1545 Answers
SOURCE: Starts with choke but will not run when choke is
I've noticed the Echos are cold-blooded and a decent warm-up time is required. You indicate the fuel mixture has to be somewhat rich to keep the engine running. This indicates the needle jets need tweaking to acquire the proper mix (if applicable) or else the fuel pump diaghram is not functioning properly and needs replacement according to the symptoms.
Here is a link to the site that has the G&D (gasket and diaghram) kit and RB (rebuild) kit part numbers for you. You will need to know your machine's model. Link to determine your carb: http://www.zamacarb.com/pdfs/APPL_CR2010.pdf
This is the link to determine the part numbers of the kits. Zama has a great site and informative links:
http://www.zamacarb.com/pdfs/QuickKit_CR2010.pdf
Please vote on this solution.
Posted on Sep 12, 2010
Husqvarna Problems
When it won't start have you removed the spark plug after cranking it over like you were attempting to start it cold with the choke on and then inspecting the spark if it's wet then you know it is in fact getting fuel enough to start and you can proceed with the next test which is putting the spark plug back on the plug wire and grounding the spark plugs base against the motor so it can ground and crank the motor over like you again were trying to start it and seeing if your getting a good blue colored spark that is blinking fast and doesn't stop blinking/arching at the plugs electrode. ( shut the choke and throttle positions off and when you ground the spark plug do so away from the plug hole) This test is easier if you have someone turn the key for you so you can watch what the spark plug is doing while cranking it over for about 5 to 10 seconds. If erratic or no spark and assuming you've changed the spark plug or plugs then something is grounding the shut off side of the coil or coils or you have a coil problem.
Nov 20, 2013 | Husqvarna Zero Turn Mower Z5426
I recently tuned up my blower. It starts great but if I turn it off Nd try to restart it it floods and will not start until I let it sit for awhile.
If the engine is warm and you shut it down, leave the choke off, lower the revs and start it. (when the choke is wide open you are using the fresh air coming in to dry the spark plugs and prevent flooding). If the motor is already flooded use that procedure to dry the plugs, then go back to full choke until it tries to start and quits again, then use half choke and pull one more time... works all the time.
Oct 22, 2013 | Echo Pb-251 Leaf Blowers
My 2005 Honda 350 ,while I was ridding it I down shifted and it back fired and died I pushed it home because it would not start all it would do is turn over but not start even with the choke on it would...
Do you see black smoke from the exhaust pipe or do you smell a sulpher smell? Pull the spark plug and see if they are wet with gas. If they are then shut your fuel off and start it after you clean the plug and hold the throttle wide open until it starts and clears out.
Sep 18, 2013 | Computers & Internet
1993 ford mustang starting problem
Do a fuel pressure bled down test, it should not loose more than 5 PSI after shut down, if it does then the fuel pump is defective.
Jun 30, 2017 | Cars & Trucks
Not starting after being washed. Initial start on choke ran, then stopped after choke closed. Did this three times. Also have oil dripping out after this from start of exhaust.
Did you get water down the exhaust pipe???
Take the spark plug out,clean it and put it back in.The oil coming out the pipe may be soot and water mixed together.Try this and see how you go
Apr 20, 2011 | KTM SX 200 Motorcycles
Car not starting, oil in spark plugs. changed valve cover gasket and spark plug seals. still cant get the car to start. starter is turning engine turns over and getting spark. i can smell fuel coming from...
If you smell fuel in the exhaust the vehicle is flooding or there is no spark. If it is a carb engine, make sure that the choke is in and hold you foot flat on the pedal while trying to start, this will clear any flooding.
Apr 01, 2011 | 1996 Honda Accord
My 2003 suzuki vl 800 misses real bad and it wont stay started without the choke being out. Could it be a spark plug or what
hi normaly this indicates a fuel problem, as the machine wont run properly without the choke you poss have a blocked jet in the carb or something, when you put the choke on the fuel is then pulled up, as the choke flap has closed of the air flow the natural thing is the vachume will pull up exsess fuel, this is fine until your engine becomes hot then the engine will start to run rough as a result of the overfueling, with respect of the spark plug if the engine runs the chances are the plug is fine, however overfueling will eventualy contaminate the plugs causing poor starting, with extreme care feel the exhaust pire from each cylinder where it comes out of the cylinder head, if it is hot then the spark plug is working just to reiterate you must ware a heat proof glove or wait till the engine has cooled down a bit before placing your hand near to the exhaust to avoid severe burns.
Nov 21, 2010 | 2003 Suzuki VL 800 Volusia
Press washer starts an runs for 5 min then shuts down/ restarts in a few min then shuts down again
It sounds like could be one of the problems listed below or a combination of those things.
1) The exhaust is partially blocked. Check the screen covering exhaust port for carbon and dirt build-up. The high-speed exhaust air must pass freely.
2) Gas is not flowing freely to carburetor > under gas tank, find the rubber hose connected to carburetor. Pull off rubber hose and make sure gas flows freely. You can use this hose to drain gas tank of old gas, and then put in new gas.
3) Carburetor is partially gummed up and engine cuts off when gas flow slows down. Check small engine repair shop or auto parts store for gum out, and don't store engine with gasoline in the tank. Or put additive in gas when storing machine.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or the machine would die. We still use the machine at 2/3 throttle.
5) Dirty air filter that won't let engine breath enough air to keep up with combustion. Take off air filter and see if problem persists.
6) The spark coil is going bad?? Change spark plug to see if problem persists. Is spark plug wire pushed all the way on the spark plug?
Oct 14, 2010 | Craftsman Garden
Petrol leak exhaust
the unit is flooded...pull the spark plug and turn the unit over a few times to help dry it out.problem is that the crank case is also full of fuel.you can turn the unit upside down for a day to help the fuel out.install new spark plug,don't choke it,pull the trigger to full throttle pull the recoil ten times this will pull the fuel up to top of cylinder.remove spark plug pull a couple times and reinstall the spark plug.start the unit. if the unit floods again you have carb troubles.the needle is stuck open letting in too much fuel and it needs to be replaced.let me know if this helped.
Mar 11, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
