Question about Air Tools & Compressors
Tank does not fill to proper psi. tank fills to 60 psi motor keeps running but wont fill to 150 that its supposed too. when i shut off compressor no air leaking????
    President:
  • 1,167 Answers
Strip the cyclinder off and inspect the valves if closing and opening also check to make sure you dont have a blown head gasket also on the tank from the pipe from the pump unit is a gold valve you need to open the end off this valve with the tank drained and turn the ruber around with the spring inside and replace this if still doesnt work get back to me bud
Posted on Sep 11, 2009
  • ollie reece-jones
    ollie reece-jones Sep 11, 2009
    strip the cyclinder off and inspect the valves if closing and opening also check to make sure you dont have a blown head gasket also on the tank from the pipe from the pump unit is a gold valve you need to open the end off this valve with the tank drained and turn the ruber around with the spring inside and replace this if still doesnt work get back to me bud
My 60 gallon kolbalt was running and stop when it filled now it wont go o ever with the tank drain it spins free it does nothing no sounds either
When you say it does nothing do you mean the motor wont come on or the motor comes on and it wont build pressure? if the motor comes on, there are several possibilities:
1. The unloader valve is stuck open
2. The valves in the head are bad
3. The flywheel is loose
If the motor wont come on, the pressure switch is bad (which holds the unloader valve open)
http://www.mastertoolrepair.com/air-compressor-parts-vt6362-p-60727.html
Oct 10, 2016 | Kobalt 3.7-HP 60-Gallon 155 PSI Electric...
Compressor wont stop running
Hi pickeringstr
Replace your shut-off switch...it is faulty
Bud
Apr 28, 2013 | Air Tools & Compressors
A porter cable 135 psi 60 gallon upright
If the motor doesn't shut off at the desired pressure then your pressure switch is either set too high or is broken/stuck. The pressure leak at 150 psi is the safety valve doing its job opening when the pressure gets to an unsafe level in the tank.
Aug 27, 2012 | Porter Cable Air Tools & Compressors
I got one of your compressors off a friend that had not used the unit in years, it say in his garage and collected dust. So I changed the plug and wires, got a new outlet in my garage for a 230 line and...
With pressure in tank test for leak at the check valve. Follow the discharge line from the pump to the tank. There you will find the checkvalve (usually brass valve). If the check valve leaks the compressor will be under load when motor tries to start and will probably trip breaker. Look for reset button (red button )on the compressor motor and push-in to reset. With pressure in tank the motor /pump should turn freely by hand. If checkvalve good and unit turns freely, test capacitor for proper valve. It should test to within 95% of printed uf/mfd. Good holidays
Dec 15, 2010 | Puma Air Tools & Compressors
We have the pressure set at 60 psi and when the pressure is reached the motor keeps running. I have drained the tank hoping that would do something but no change. Just keeps running though the desired...
Sounds like a pressure switch to me. I would like to ask you a few more questions, let me ask you this, is the tank set at 60 Psi or the regulator? You can email me at phoenix.repair@hotmail.com for faster response time.
Oct 19, 2010 | Porter Cable C2002 150 Psi 6 Gal...
I have a 5 HP Coleman air compressor. I was using it to provide air to my plasma cutter which requires 60 psi to operate. Basically, air compressor's motor keeps running, but it's stopped creating air...
You did not list model number, however if you have oilless type check the cylinder/piston by manually turning crank until piston is at top and examine cylinder for wear or scratches. If worn replace cylinder kit for full pressure. If ok check reed valves /valve plate for wear or broken reeds. If oil bath type, problem is usually air leak or reed valves / valve plate. As a general rule, you can keep track of wear by noting how many minutes it takes to fill the tank to cut-out. As the compressor wears it will take increasingly longer to fill. When new, and depending on tank size/ hp, most compessors fill within 2 ~ 5 min. Good luck
Sep 24, 2010 | Coleman Air Tools & Compressors
I have an Ingersoll Rand T30 10 HP compressor that runs OK and will bulid up 150 psi without any problems. But when the pressure drops enough to kick the pressure switch, the motor won't start. just tries...
When the compressor comes up to pressure and kicks off, you should normally hear a gasp of air escaping. That gasp is the release of pressure from the compressor itself - not the tank, and it is supposed to get released so that the compressor can restart without being preloaded with compressed air. My guess is that the gasp is not happening. It is probably some debris or a gummy mechanism. The mechanism is supposed to be triggered by the same mechanism that shuts off the motor.
Aug 30, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
How long does it take for the compressor to fill up during the first use? The motor has been running for 15 min and the pressure needles have not moved....
Make sure the tank drain on the bottom of the tank is shut off if there is one.
It should not take more than three or four minutes to fill a small pancake tank.
You hear any hissing noises while the pump is running? If so, there's an air leak, see if you can stop them somehow.
If the above does not answer, return unit for refund or exchange.
May 12, 2010 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
My compressor runs way too long to fill up to 150 PSI. It fills up quick to 120 PSI then just takes forever to get to 150 but finally does. It's only 1 year old with very little use. 17 gal, 1.1 horse,...
The pressure switch should be at the factory setting of about 120# max. Not to be hurtful,but what you discribe is normal. Even a 2 HP 220V is minimum for a compressor.. You go by the CFM Rating. You and I can not afford a two thousand dollar 12 CFM Unit. Your compressor is simply too small, to do much. It is pushing against tank pressure so much,after 90# that the reed valves can't hold it. Set it at 100 to 120. It is not designed to run up to 150 max. Now if it is,an oiless compressor , it won't last long. My Campbell- Hausfeld lasted 31 years. Got a new one two years ago
Mar 13, 2010 | Air Tools & Compressors
Hi,I have a Sears 2 hp air compressor,model #919.176320 and it will fill,when empty.It will not refill when I have any preasure in the tank.It should fill,then refill when the air presure drops to 60...
It's trying to come on too soon. 60 PSI is too much pressure for it to run. Reset the pressure switch to kick in around 40 PSI. That will do it.
Jul 06, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
172 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
