Question about Brother P-Touch 1180 Label Printer
Brother p-touch labeller I put in a refill tape TZ laminated, and when I print I get the clear plastic layer ontop of the ink layer, on top of thsticky white layer, and lastly the peel-off layer, so the ink is printing onto the clear non sticky tape.
P-Touch 7100 cutter error
Just a (too late) suggestion: The cutter on the PT-7100 (and I think on every Brother Label printer that uses TZ tapes) has a replaceable blade. Sometimes just removing the blade and making sure the tape path is clear of gunk is all it needs.
Apr 07, 2015 | Office Equipment & Supplies
P-touch 1180 will not print, I type in what I want and hit print, and I get an error. how do I fix this error, what is the error?!?!
You did not specify the error you are getting. However, if you have an additional TZ cartridge, try replacing the cartridge as the current one may be jammed or out of tape.
Apr 17, 2014 | Brother P-Touch 1180 Label Printer
My ptouch isn't printing; after creating a label, when i press print, the tape comes out but nothing is on it.
Try a different tape. Usually, when the ink and label get screwed up it's time to trash it and start over, but you might just inspect the cartridge to make sure they are joining properly. If another tape works, there's your answer. If not, well 1180's aren't very expensive and our Brother store (Staples) has a sale on them every other week. Another heads up. If you have a Meijer's store nearby, they are stupid. They're selling black on white 12mm TZ tapes for $9.99. Go and buy them all :-)
Carl
Apr 21, 2011 | Brother P-Touch 1180 Label Printer
How do i change the tape on it?
This machine uses the Brother TZ tape, which is available in a variety of colors and three widths (1/4" (6mm), 3/8" (9mm) and 1/2" (12mm)). A TZ tape is supplied with this machine.
1 Press in on the rough area at the top end of the machine and fold open the back cover. Should be the exact process as loading batteries.
2 If a tape cassette is already installed, remove it by pulling it
straight up.
3 If the ink ribbon in the other tape cassette is loose, use your finger to wind the toothed wheel in the direction of the arrow on the cassette until there is no slack in the ribbon. Also, make sure that the end of the tape feeds under the tape guides. Note: If you are using a new tape cassette provided with a stopper, be sure to remove the stopper.
4 Insert the tape cassette firmly into the compartment, making sure that the entire back of the cassette contacts the bottom of the compartment. Note: When inserting a tape cassette, make sure that the inner ribbon does not catch on the corner of the metal guide.
5 Securely close the back cover, making sure that it snaps into place.
6 Feed the tape by holding down CODE and pressing PRINT once, and then push in the tape cutter lever to cut the tape.
You can also get a copy of the user's guide here.
Thank you for using FixYa! Don't forget to rate our service.
Feb 10, 2010 | Brother P-Touch 1180 Label Printer
Brother P-touch 1180 tape cartridge jammed
Man, that tape's a real b!%^ch. I just spent an hour figuring it out, so here ya go... In the center is a (larger that the rest) gray wheel, this is the "toner" take up reel. On the tape that's come out of the cassette, seperate the three layers, and start "reeling in" just the toner. (The laminate and label that have come out are just lost, no real hope for them) When you get close to the end of the toner, help it feed straight back in, and it will go all the way back in. You may have to hold on to the laminate and label so it doesn't try to follow the toner. once that done, it should look like the original cartridge, trim off the excess and you should be good to go.
Brian
Nov 13, 2009 | Brother P-Touch 1180 Label Printer
How to refill brother LC65 ink cartridge I have the refill kit but no instructions
Trust me, this is the BEST way and the EASIEST way to refill black and color LC61 or LC65 inkjet cartridge from Brother. See the pictures
1. cut the plastic part (see picture). You can use a utility knife or a steak knife (very easy to do)
2. make a hole on the left side (NOT in the midle) and do it straight and don't go deep (see picture)
3. poor the ink with your refill kit and do it straight and don't go deep because the inner side of the cartrigde is made of cheap plastic (like a plastic bag) and you don't want to perforate it
4. put your plug, tape, hot glue or what ever you have to seal the hole.
5. put the cartrigde back in your printer, do a print test and this is it.
Sep 13, 2009 | Office Equipment & Supplies
QL 550 won't print
It has no ink as it is a thermal printer.   Make sure you are using genuine Brother Thermal Labels.
Mar 09, 2009 | Brother P-touch QL-550 Thermal Label...
LOADING TAPE INTO A BROTHERS P-TOUCH
I'm on my second machine since December. Neither P-Touch would feed the white tape, the other layers bunch up inside the machine. Called Brother, and they were no help (indeed not much interested in my problem), except to suggest I clean the rollers with alcohol/q-tip. This action did result in the tape feeding, but not properly as I now get an unusable label strip with all three layers, and printing on the clear layer backed by black layer. POS if you ask me; it is going back to the store.
Nov 17, 2008 | Brother P-Touch 1180 Label Printer
Brother P-Touch 1180 Label Printer Logo
715 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
