When i plug my tv in it just clicks and will not turn on sylvania model srt2227w
    Scholar:
  • 61 Answers
The clicking you described usually indicates a circuit breaker re-set and failure. This is usually indicates a circuit problem or defective component in either the low or high voltage power supply. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Posted on Sep 13, 2009
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
Direct TV remote
I think you mean Hughs when you're referring to your direct Tv remote? And you want that remote to turn on/off your Sylvania Tv, right?
I'd need to know the Hughs model number on the remote to know if it's a four or five digit code requirement. But here's a site that might help. http://www.remotecodelist.com/remotes/
Scroll down to Hughs and that link should take you to the DTV site where they have a wealth of info regarding codes. Find your model number remote control and you should have a list of possible codes to try.
If all this doesn't work let me know and I'll research sme more.
Good Luck!
Bill
Nov 25, 2007 | Sylvania SH50102 LCD Remote Control
Tv wont stay on
there is a short, could be anything....Check amount of blinking light
Feb 04, 2012 | Sylvania 6842THG 42 in. Plasma HDTV
My Sylvania 32" Tv Model #SRT2232S won't turn
Hello
There is a fuse inside the power supply bard of your sylvania TV. Check whether it has blown out. If bllown out, replace it with same type bothe in size and amperage. If the newly inserted fuse also blow up as soon as you switch on the set, make sure that the power supply section has some short circuit in it, and should be cheked well. OK.
Sep 28, 2011 | Sylvania SRT2232S 32" TV
I have to click "on"
unplug the TV. Press and hold the power button (on the TV, not the remote) for 30 seconds, repeat. Plug it back in and try to turn it on.
Apr 22, 2011 | Sylvania Televison & Video
I would like to use my Sylvania LC320ss8 Flat screen tv as a computer monitor but when I plug in the monitor plug the screen on the tv says format not supported. My operating system is Windows 7 and...
If you have connected the TV to the computer with a VGA cable, what resolution was your previous monitor using? You may need to change the resolution or refresh rate with your regular monitor attached. This TV has a native resolution of 1366 x 768 .
If you are connected via one of the HDMI ports, check the specifications for your TV. Then try using the VGA output. Not all TVs support a computer signal over HDMI. Unfortunately, I can't find the LC320ss8 at the Sylvania Support site: http://www.sylvaniaconsumerelectronics.com/ . If the model number has an error, click on Downloads and enter the correct model number.
I hope this helps.
Mar 31, 2011 | Sylvania LC320SS8 32 in. LCD Television
My sylvania 19' tv (model #LC195SL9A) keeps going to standby instead of turning on
I was having this same problem with this same model. I would turn it on, the green light would blink a few times, then it would go into standby. After repeating this 10-15 times it would finally turn on. I called customer service and they said to try resetting the TV by unplugging it for 30 minutes. If that didn't work, they said to call a service center to see if they could figure it out.
Well I unplugged it for 30 minutes, plugged it in, turned it on and Whalla! It works! I am so glad it wasn't something else.
Jun 15, 2009 | Sylvania LC195SL9 19 in. LCD TV
Factory Remote Control for Sylvania model SRT2319 doesn't work
You can buy an original replacement remote for your TV clicking the link below:
New Original Sylvania SRT2319 Remote Control $39.99
Apr 18, 2009 | Sylvania SRT2319 TV
Remote codes
Hello thank you for choosing FixYa.com for your answer my name is David.
I have found a list of codes for the rcu600m for the sylvania tv here they are
Code For Model RCU600M
Code 004 for Sylvania TV Code 006 for Sylvania TV Code 008 for Sylvania TV Code 019 for Sylvania TV Code 062 for Sylvania TV Code 068 for Sylvania TV Code 069 for Sylvania TV Code 075 for Sylvania TV Code 076 for Sylvania TV Code 077 for Sylvania TV Code 088 for Sylvania TV Code 116 for Sylvania TV Code 130 for Sylvania TV Code 132 for Sylvania TV Code 134 for Sylvania TV Code 161 for Sylvania TV Code 183 for Sylvania TV Code 196 for Sylvania TV Code 353 for Sylvania TV Thank you again for choosing Fixya.com
Was this solution helpful? Show your Appreciation by rating it:
Nov 08, 2008 | RCA RCU600M Remote Control
Programming it to a Sylvanvia TV model 6420FF
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
