Question about ASUS P5PE-VM Motherboard
D345AJ ic PACKED IN 3-pin ? what`s at out ?
  • Anonymous Jan 04, 2009
    i want the graphic card driver for my PC as after formatting my pc graphic is not clear. my mother board is Asus P5PE VM
  • Hairy29 May 11, 2010
    what pin are you referring to?can you ellaborate the problem pls...thanx!
  • 259 Answers
Not sure what information you were requesting. So here is some information about your motherboard:
- LGA775 socket for Intel® Core2 Duo/65nm Pentium D/Pentium 4/Celeron CPU
- Intel 865G + Intel ICH5
- 1066(O.C)/800/533 MHz
- Dual-channel DDR400
- Intel® Extreme Graphics 2
- 1 x AGP 8X
- 2 *ATA133 ,2 x SATA
- 10/100/1000 LAN
- 6-Channel audio
Here is a link to all the drivers to your motherboard:
This includes the manual!
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5PE-VM
If you need more help Let me know. :]
Posted on Dec 12, 2007
Is audio output (from main ic) is imputed in utc2003 audio amplifier ic?
Is the UTC2003 IC your main IC?
You can't find inputs or output of this IC?
This IC is power Operational Amplifier simply. It has TWO inputs noninverted = pin 1 and inverted = pin 2 and ONE output = pin 4. Pin 3 is ground and pin 5 is supply voltage. It's simple as the rake! What is your problem? Sorry for my rusty English...
Feb 03, 2015 | Audio Players & Recorders
Part Idenfication
hi,there is a notch or a hole on the top of the IC.
The pin adjacent to the notch is the pin number1
and the pin below no.1 is no.2
....no. the pins in the above fashion......all the best
happy christmas
take care bye & have a nice day
Dec 21, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tip
SAMSUNG PLASMA POWER SUPPLY CLICKING.
If you have a Samsung Plasma PS50A550 which will keep clicking and not come on, the fault is in the power supply .Check Power supply if its a BN44_00222a. This PCB cost almost $ 300.00 can be fixed for around $ 30.
The fault is in the 5.3v supply to the T.Con PCB. On the Power supply check voltages.VS will not come on unless the T.Con pcb is active.
Check on printed circuit side of PCB on secondary side there are 3 IC close to one another. 2 IC'S are 8 pin and one is 16 pin. Replace both 8 pin reg IC (25h3ll ) these are available from RS components. Part number is STS25NH3LL. The 16 Pin IC is a L6725A but this is not faulty.
lets keep these good TV working for another 4 years.
on May 30, 2014 | Samsung PS50A550 50" Full HD Plasma TV
Sony walkman NWZ-S754 Recharge is through computer - but can I recharge it via mains or in car.
Yes you can charge your player through main. All you need is a converter which connects to the usb cable to the plug. They are available in the market so you will need to look for it. Or you may find it at any electronic store.
Jan 20, 2011 | Sony Walkman Video NWZA818 MP3 Player
My Panasonic TC-21Z88RBN doesn’t displays the total picture vertically ,when the picture is display it like not in the center of the screen sum of it is disappear in the bottom
Hello
Your TVs vertical output section has the fault. You just open your TV after disconnecting it from the AC mains wall socket, and locate the vertical output section. This section uses an Ic marked as part [IC 401] on the board and its number is LA7840. Just look for any loose soderings around its components legs, and the solderings at the IC legs, which has 7 of them. The IC stated above will be screwed onto a heatsink to radiate heat out of it when it works.
If all soldering point are fine, come towards the IC legs and measure the voltages at each leg. The voltages must be
pin 1= Ground
pin 2= 12.6
pin 3= 24.7
pin 4= 4.4
pin 5= 4.4
pin 6= 24v [vcc]
pin 7= 1.8
All voltages stated above are DC voltages with respect to ground. If any of this voltage is missing, find out the reason for that. If all of them are noted abnormal, IC may be defective, and replace it.
[vcc] stands for main input voltage to the IC.
If you need any more assistance, feel free to contact me through Fixya. Ok.
Dec 07, 2010 | Panasonic TC-21Z88R 21" TV
Samsung 1640 printer how to resat
first turn off printer and plug off cabel power
1. open printer
2. look at IC EEPROM 93c66WP
3. connect no 1 and 4 pin IC 93c66WP
4. turn on printer, wait until printer shown green lamp, it mean calibration finish
5. turn off printer again
6. disconect no1 & 4 pin ic 93c66WP.
7. turn on again, and printer ready again
Dec 04, 2010 | Samsung ML-1640 Monochrome Laser Printer
AV-48WP74 48 in. Rear Projection HDTV-Ready Television: my 3 colors are all out of whack and the convergen...
you most likely need to replace the convergence ICs. If you are lucky, they may have unsoldered pin connections at the PCB, you can try re-soldering those loose pins. What usually happens is that because of the heat generated, the pins have become detached at the IC also, thus the need to replace the ICs. Some of these have either fuses or resistors to the ICs that have also opened & will need replaced also.
May 16, 2010 | JVC AV-48WP74 48" Rear Projection...
Need vertical ic replaced and capasitors. do
Don, who says you need the vertical ic replaced? Although you are to the point as to where the problem is. I think the ic is ok. The ic is a 7 or maybe a 9 pin component. In some cases it could be 13 pins. If you are sure where the location is, it is mounted to a large heat sink. I am not real sure of mitsubishi location scheme . If you can find it, most of the time pins 3 and 4 will be shorted. Measure to be sure. I think it is good. Look real close at the pins. They may have rings around them..resolder these making sure not to use to much solder. They should make contacts between pins. Now examine the four or maybe 5 capacitors with corresponding numbers. replace them with exact values. Use High Temp 105 degree ones. If you decide to replace the vertical ic, removed the clip around it. It will be the LA78--- series, cross it with an NTE replacement. see your electronic store for parts.
Jul 07, 2009 | Mitsubishi Televison & Video
TV problem
Over Current Protection
Pin 1 of IC951 is also the Over Current Protect input.
The internal FET.s ground return is at pin 2 of
the IC. The voltage drop across R955 and R956
indicates the FET.s current, and is coupled through
R953 to pin 1 of the IC. The Over Current Protect
circuit is activated if the voltage at pin 1 of the IC
exceeds 1.35 volts.
Stabilization and rough regulation are provided by
feedback from pin 3 of T951 to pin 1 of the IC. Fine
regulation feedback is from a secondary supply,
through the Photo Coupler, PC951, to pin 1 of IC951.
Its possible that Diode D953 is leaky allowing the voltage to rise on pin 1 of the IC
Feb 23, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Sony Trinitron KV-32FS320 4 blinks
First, understand the dangers of high voltage and charged capacitors inside a TV set! Discharge all capacitors and the picture tube in a safe way before proceeding.
What kind of IC is it?
If SurfaceMounteD:
1. Heat the IC pins and use a solder wick to remove ALL solder tin.
2. Use a sharp screwdriver or a knife to gently lift the IC from the PCB. Pay close attention if any of the pins is still attached to the PCB, if so, repeat step 1. Be careful, if you break the PCB, the Sony is ready for the dumpster...
3. Put the new IC in place, begin to solder pin 1, and then the pin most far away from pin 1.
4. Solder the rest of the pins, as quick as possible to not overheat the IC. Don't care if solder short circuit the pins.
5. Use a solder wick to remove all eventual short circuits that was the result of 4.
6. Inspect one more time to be 100% sure no short circuits remain.
7. finished.
If mounted through holes:
Same as above, with following additions:
1. a possible addition of a solder sucker.
4. The speed is still important, but since the pins are not so close, you should be able to do it without shorting.
Dec 31, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
ASUS P5PE-VM Motherboard Logo
263 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
