Question about Canon PIXMA MP530 All-In-One InkJet Printer
Display says Paper Jam, but there is none - Canon PIXMA MP530 All-In-One InkJet Printer
The machine always detect a paper jam without a paper?
Is there a small piece of paper over the paper jam sensor?
Feb 01, 2015 | Office Equipment & Supplies
Tells me my printer has a jam but there is none
Hell,
Paper jam errors can also be caused by worn pickup rollers. When the printer tries to print a page and the rollers can not grab a sheet of paper to feed into the printer the printer will think there is a jam and display the same error. Pull out the paper drawer all the way and reach inside the top of the opening and you should find the pickup rollers. They should feed rough not smooth. If they do feel smooth then they will need to be replaced by a Canon repair center.
I hope this helps,
BuddyMc
Nov 30, 2012 | Canon imageRUNNER C1028i Laser...
Paper jam on display but there's no paper jam
Then the roller are dirty or need to be replaced because they cant grab the paper so the machine is miss feeding jam is when the paper hit something or stop electrically move to different draw or the by pass
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 25, 2012 | Minolta bizhub 200 All-In-One Printer
Paper jam
  • Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
  • 2Turn off the copy machine before pulling out the paper.
  • 3Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
  • 4Check for any paper fragments and clean up any torn pieces.
  • 5Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
  • 6Replace the cover and paper tray and turn the machine back on.
  • 7Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push
    see the diagram for copiers and let`s the way of paper for troubleshooting .
  • 12_19_2011_4_33_16_pm.jpgsincerely. Merry Christmas.
    ernesto cuadra
    managua, nicaragua. c.a
    Dec 19, 2011 | Office Equipment & Supplies
    My computer says there is a paper jam but there is none on the display screen. I tried opening it up but it doesn't work, my computer still says it has a paper jam. My printer is HP Officejet 4355. My...
    Turn the printer off.
    Disconnect the AC power.
    Disconnect the "data" cable from the computer.
    Reconnect the AC power.
    Turn the printer on.
    Press the "paper-feed" button, to try to feed a few sheets of paper through the paper.
    Reconnect the "data" cable.
    If this fails, take the printer to a qualified technician, for professional trouble-shooting.
    Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
    This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
    The display says there is a paper jam, but there is none
    Sounds like the printer need to be "reset"
    Cancel all print jobs.
    Disconnect the printer from your computer
    Turn power to printer off and unplug it.
    wait 1 min, then reconnect printer to your computer.
    then plug printer back in and turn it on.
    Start your print job over.
    Should the paper jam suppossedly still exist, cancel the print job and run the maitenance program off the printers' menu that is stored on your computer.
    Start print job again.
    Should the problem still exist contact support at Samsung via the links on their homepage.
    Good luck.
    Oct 05, 2009 | Samsung SCX-4100 All-In-One Laser Printer
    Printer says paper jam but there is none
    Look Inside of each cover on the printer & see if there is a small piece of paper inside. Also, check if there is loose dust from the paper built up by the sensor switches. If none of these work, try flipping the sensor switches manually. Sometimes these get stuck in a particular bad paper jam.
    Feb 11, 2009 | Canon Pixma MP500 All-In-One InkJet...
    Canon PIXMA  MP530 All-In-One InkJet Printer Logo
    35 people viewed this question
    old marine
    old marine
