Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Will not get water. is going to dish washer just not in it
  • 60 Answers
There is sometimes a problem with the solonoide that stops the water from comming into the dishwasher get a technichian to look at it. as it can be the timer or electric board that is not send the signal to the solonoide.
Cheers
Al
Posted on Sep 11, 2009
Samsung dish washer DD81-01549A_EN How do you reset the dish washer it won't wash it just hums
Humming could be no water going in, check fill hose.Or get a bucket of water put into drum then start machine helping to Flush out.
Oct 21, 2017 | Samsung Washing Machines
Will run thourgh cycles but only a little water will go in
Check fill line for a kink, (remove kick panel on bottom of dish washer)
If no kink then replace fill valve. Unplug dish washer fill valve is where water line is hooked on.
Aug 10, 2014 | Frigidaire Dishwashers
Dish washer runs all cycles but no water entering dish washer
Make sure you check that the water is turned on to the dishwasher.
Check for a kinked or squished fill hose. If all else fails its most likely you need a new fill valve for your dish washer.
Feb 28, 2013 | Maytag Dishwashers
How do you replace water intake hose on machine
under the kitchen sink there is a water valve that is attach to a hose that goes in behind the dish washer that feed the water to it,,,,the dish washer is attached to the counter by two screws in the front of it,,take them out and the you can slowly pull out the unit,,,to change out the water feeder hose,,but make sure you shut off the water going to the dish washer first
Feb 19, 2011 | Dishwashers
Water does not go into the dish washer during the wash cyle. This is a new problem on an existing Magic chef dish washer.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 08, 2010 | Magic Chef Dishwashers
Dishes are not drying
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jul 12, 2010 | Electrolux 23 in. ESL6114 Built-in...
Dish washer problem
check water going into unit. disconnect to make sure there is a strong pressure going through.
check the water valve with a meter if there is continuity the valve is good. if not the valve is bad a no water water will go through. let me know if this helps
Feb 23, 2010 | Dishwashers
Dish washer not working
close the hot water valve to the water line feeding the machine and disconnect the water supply from the valve.Once you've done that than slowly turn on the valve to see if their is any water flow if their is water coming out of the valve than you probably have a problem with the pump.
Feb 02, 2009 | Home
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
43 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
