Question about Kitchen Ranges
Frigidaire range model PGLEF387AS1 - doesn't heat up when put on 'convection' setting. Heats up on 'bake'. Problem started today; always worked fine before.
  • 52 Answers
SOURCE: frigidaire oven will not heat up
here is a list of error codes that may or may not be displayed by the oven.
Frigidaire Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F2 Oven temperature too hot Check and replace oven temperature sensor (RTD). F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F4 Shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F6 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F8 Oven door lock failure Check lock relay and door switches.
Posted on Jan 29, 2008
aborcass
  • 2651 Answers
SOURCE: oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Posted on Mar 26, 2008
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
  • 112 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
jumptrout51
  • 3361 Answers
SOURCE: Range door will not seal properly.
Place a hammer handle between the door and the frame at the hinges..
Push on the door, carefully.
This usually works to re-seat the door hinges.
Posted on Mar 08, 2009
Motor working sound when our new Frigidaire electric range is heating to selected temperature. Is this normal?
some fan assisted ovens turn on the fan to get up to temperature, its an energy efficiency thing, also mean pre heat is quicker. if you need more info on this unit here is web page
http://www.frigidaire.com/Owner-Center/Product-Support--Manuals/?productCode=LGEF3045KF
hope this helps you.
Jun 11, 2017 | Frigidaire Kitchen Ranges
Broil and range work but bake does not
check oven burner tubes and ignitor and flame sensor
Sep 19, 2017 | Frigidaire Ovens
My Frigidaire ele. convection oven only heats up to 287 drgrees
Good Afternoon Mitchel, thank you for your inquiry!
It could mean a few things in why your range is taking a long time to reach desire temperature:
    ·Convection heating element
    ·Thermal cutout
    ·Thermal oven sensor
    ·EOC (electronic oven control)
    ·Ignitor
    ·Bake or broil element
    ·Shorted wired connections
    It would be advisable for the above parts to be properly diagnosed by an expert to determine the root cause to reduce the risk of unnecessary parts. Best regards!
Nov 21, 2013 | Frigidaire FEF364DQ Electric Kitchen Range
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
It's a Model JJW8530CAB. The baking element
Are you having any issues at all with the display at all? Did this start out of the blue or did you have a power outage or anything else?
Jan 20, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
Dacor oven overheating
sounds like your bake relay is not closing
you need service relay board replaced
Aug 01, 2017 | Dacor Preference PGR30SS Gas Kitchen Range
Kitchen Ranges Logo
118 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
