Question about Marantz SR-5200 Receiver
Statics and hissing...
Hello!
I am from Hungary and I have a big problem with my Marantz SR-5200 receiver.
The only way I can get clear sound is using s-direct. Any other selection produce severe static and hissing all of the speakers, so that seems to indicate it is something within the receiver, around the DSP card.
Is there anything I can look for to repair it myself, or will this require a full repair job? Or should I just bite the bullet and buy a new receiver?:)
Thank you for helping me.
P.s.:I'm an engineer, so I would like to try to repair it myself.
  • 2 more comments
  • Anonymous Sep 02, 2008
    I am also from Hungary. Recently bought 2 Marantz : SR 5200 and SR6200 from Ebay. Both are defect..I will make an attempt to amend them.
    having similar problem. (hiss, display ok, leise whithe noise ....... contact:arctech@freemail.hu (need electrical drawing..)
    I would like to share experince at fixing this problem.
    Good Luck.....
    This moustache ******** on the photo below, is a great **** - sounds like somebody has been living under a rock !
    Hey ********, you had better telling no more stupid advice.....
  • harper220 Nov 18, 2008
    I have similar problem. All inputs work fine cd, tv, aux etc... S-Direct only! Surround mode does not work and all speakers have white noise. I do not understand suggested fix. Move antenna to different location?? Ground loop? Confusing?? Can you explain more clearly?
  • Seth G Feb 16, 2009
    Hi folks,
    It looks like I have the same problem with my Marantz SR6200. More then a year it is
    giving me this a kind of a scrunchy white noise on the background after it is
    running perfectly for 15 min or sometimes immediately. I did by pass this through using
    different outputs, like from optical to coax. First it did work fine,
    but eventually I did had the same problem on this output as well. Now I have no outputs left anymore :-( whre I do not have this problem.
    I see thekinfam posted that the replacement of IC720 did solve the
    problem? Is this easy to do? If yes, where can I buy this IC720 and how
    can I locate this on the pcb?
    Your help will be really appreciated..
    SG
  • arctech Apr 08, 2009
    látom magyarországról írtál, nekem is hasonló a problémám az SR 5200-assal, de defektesen vettem az Ebay-en, utána vettem egy 6200-ast is, úgy tűnik mindkettőnek DSP gondja van. Esetleg szervizleírásofd lenne hozzá ?
    üdvözlettel,
    Kokas Péter
    20 9232144
  • 4 Answers
I also have the same fault, The static noise is coming out
of ic720 [ cs4391 or cs4392 ]on digi pcb which is D-A converter
this ic maybe faulty, i have ordered a replacement ic and will
post here if solves problem
Posted on Oct 11, 2008
  • 1 more comment
  • thekinfam Oct 14, 2008
    Replaced ic, all is fixed
    ic720 was faulty, all fixed
  • thekinfam Mar 19, 2009
    "Seth G asked if this is a easy repair"
    ic720 a surface mount ic and awkward ta access ,
    if you have good soldering skills you will be able
    to do it, if not i would not attempt it and would take it to
    a repair shop.
Because your DAC chip have problem.
thekinfam is right
http://www.kazuo.com.cn/attachments/month_0811/20081110_d1bd724d970bc3aea6d5L96wYX7XnDSi.jpg
The first green board is DSP board
http://www.kazuo.com.cn/attachments/month_0811/20081110_b717d1a14466baf4c877HTDQJ7r3J8eD.jpg
Remove IC-720
http://www.kazuo.com.cn/attachments/month_0811/20081110_8930d73d409dd7ee32d6S3R79jKVSPHr.jpg
Install new DAC (CS4391)
http://www.kazuo.com.cn/attachments/month_0811/20081110_695b888fd01ad998dd6fg88C1wjgUX8J.jpg
If your sourrond channel have this problem you can change IC-719 (CS4228)
Normally CS4391 cost 1usd.
Posted on Apr 28, 2009
I have similar problem with Marantz 5200. All inputs work fine cd, tv, aux, etc... S-Direct mode only. Surround sound does not work and all speakers put out white noise static. I'm a little confused by marsrover's suggested fix. Can you explain more clearly?
Posted on Nov 18, 2008
  • 682 Answers
Please disconnect all electrical equipment around you and connect it to wall outlet directly-change the place of your antenna to another place-bring power cord with ground loop isolator-bring an transformer 1:1(input=output)and connect your system to it.
Posted on Jul 05, 2008
My marantz sr 5200 has stuck in "Mute on" situation
Your mute switch has been broken some how,End will have to be replaced.
Oct 11, 2012 | Marantz SR-5200 Receiver
No surround modes produce any sound . only have sound on s direct mode. marantz sr 5200
Not having the ability to look at it on the bench, more than likely your DSP chip is bad. If you have a local repair house that is willing to confirm that is the problem without charging you an arm and a leg, that's your best bet. It is an expensive repair, anywhere between 300 to 500. At that point, I would say to replace the unit. Sorry for the bad news, but that's my "best guess" The only other thing to check would be your "Audio input Settings" Make sure it's either on "Auto" or whichever type you are using. "Digital Coaxial", "Optical", or "Analog" (RCA) hope this helps! If you have any further questions, just post a reply and I can help further. Best of luck!
Jun 03, 2010 | Marantz SR-5200 Receiver
My marantz sr5200 dont reproduce dobly digital signals , maybe junt 2 channels.
I have the Marantz SR5200, unable to get the Set-up / t.tone button to work, don't have the instructions,
Mar 19, 2010 | Marantz SR-5200 Receiver
No sound out of speakers (Marantz SR5200 receiver)
sounds like you might need to open it up and check the speaker wires that you plug your speakers up to it might be lose or something else like that cause it happened to me before and that was it.
Feb 21, 2009 | Marantz SR-5200 Receiver
Marantz SR-5200 - Analog inputs only play the right channel
please invert your cable and watch if the problem moved the problem in your cable change it with new one.from any radio shack near you or any electronic store.
Jul 05, 2008 | Marantz SR-5200 Receiver
SR-5200 owners manual
http://www.retrevo.com/s/Marantz-SR5200-Receivers-review-manual/id/511dj791/t/1-2/
Jun 26, 2008 | Marantz SR-5200 Receiver
Playstation 3
I assume that the Marantz has an Optical lead input. If so you should connect an digital optical lead directly between the PS3 and the Marantz receiver for the sound while keeping the HDMI lead to the projector for the picture. You will need to configure the PS3 to be outputting the sound to the optical output (done through the settings menu).
Jan 08, 2008 | Marantz SR-5200 Receiver
Loss of volume on left channel
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Oct 15, 2007 | Marantz SR-5200 Receiver
Total loss of sound...what to do?
please repeat your setting first- and then disconnect all speaker out.
connect your speaker one by one until you find the bad one and change it-you can also apply contact cleaner spray over volume control and move it many times-please do not forget yo unplug headphone jack first.
Sep 23, 2007 | Marantz SR-5200 Receiver
Really bad sound quality loadsa hissing
A snake didnt make a home of it while you were away???LOL Naww just teasin .. First off may I say that if your going away for any extended time like over a few days unplug the electronics in case theres a stormn or power surge!!.. Ok now that the barn door is closed after the horse got out. Hmm Sounds like could be need reseting?? try unplugging for a night and trying in the am or PM whatever your time to be is?? If that dosent help you got a power surge its more sounding like and if your not a tech Im sorry to say you will need to callon a pro to assist you in this repair Good Luck
Jun 21, 2006 | Marantz SR-5200 Receiver
Marantz SR-5200 Receiver Logo
2,205 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
