Question about Dewalt Cordless drill/driver kit 9.6 volt 3/8" DW926K - 2
HOW TO ADJUST DRILL TO USE 9/16 BIT?
How do you adjust dw926 cordless drill to accept 9/16 drill bit?
    Sergeant:
  • 384 Answers
Purchase a 9/16" drill bit with a turn-down shank.
Posted on Sep 11, 2009
Makita cordless drill
It sounds to me like the clutch is set to a low setting. Its the dial just behind the chuck with the numbers on it, you can turn it to adjust how easily the drill slips, the purpose of it is to make it easy not to strip screws or drive them in too far. Just turn it to a higher number or all the way and it should work fine. The setting its on is whichever number is on top of the drill (opposite the handle), there should be a little arrow on the body of the drill pointing to it. The highest setting will not be a number but an image of a drill bit, in this setting it will not slip at all. Some of these drills are also hammer drills (as the drill turns, the chuck will also "hammer" in the direction your drilling, this is for drilling into concrete and things like that and requires a special bit (if your drill has that there will be an image of a little hammer on the dial next to the image of the drill bit). I hope that helps, Good luck.
Apr 24, 2013 | Makita Lxfd01cw 18-Volt Compact...
Putting new bit in my skil9. I'm relatively new with my drill and i'm trying to hang curtains so I need a bigger bit in my drill
Hold the black part on the end of the drill with you hand firmly and then run the drill in reverse...that will loosen the bit...
Place the next bit into the drill and then holding the end run the drill forward till the bit is tight...
heatman101
Dec 05, 2010 | Skil 2566 02 120V 14.4V Cordless Drill Usa
I'm new to home improvement, and just bought my first cordless drill (Ryobi P204, 18-volt, 1/2"). How the heck do I insert the bit? The drill comes with two batteries, and a charger. There is an opening...
Like many drills these days, the P 204 has keyless chuck. In order to secure a bit, locate the forward/reverse switch (right above the trigger). Set it to the center of the three positions. This will lock the drill so that it cannot turn. Now turn the black portion at the front of the drill's nose (looking at the drill from the front, clockwise rotation will tighten the chuck and counterclockwise will loosen it) Adjust the chuck jaws so the bit you have chosen will fit without too much slop and then tighten the chuck until it holds the bit snugly and straight. Unlock the forward/reverse switch (push to the right to drill or insert screws) and you should be ready to go!
Oct 24, 2010 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
The collet seems jammed and I cannot adjust the size to fit the drill bit
web search-black and decker repair manuals- they have site for parts,repair guides and diagrams
Oct 06, 2010 | Black & Decker & Cordless Drill
I can't get the the drill bit out of my cordless drill
Try to keep your drill straight and try a bit harder - looks like you were drilling something very heavy.
Apr 03, 2010 | Dewalt 18 Volt Compact Drill Kit
Which drill bits for b&d cordless
you can use any brand of bit on the market,but you need to use the correct bit for the material you are trying to drill thru
Mar 21, 2010 | Black & Decker Drills
DeWalt cordless drill DW926. I can't get the
Turn your drill speed selector to "1" and put drill direction in reverse. Hold the outer end of the chuck and push the trigger. Should come loose.
Nov 18, 2009 | Dewalt Cordless drill/driver kit 9.6 volt...
Clutch slipping
Try Rotating the bit holder head while holding torque adjuster or visa versa and turn the torque off in increments,test and adjust as desired.
Please rate Thanks
Mar 28, 2009 | Drills
Dewalt Cordless drill/driver kit 9.6 volt 3/8" DW926K - 2 Logo
88 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
