FixYa.com
Tags:
Quartet gbc Shredmaster 2240S  Shredder
Automatic Shredding
posted by KellyR on Dec 10, 2007
My shredders Automatic option isn't working - I have to physically turn on to shred - once done motor keeps running until I power it off. How do I reset the Automatic shredding?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 02, 2008
Not Rated (0)
fellowesrep
Rank:Guru Guru
Rating: 86%, 86 votes
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc board, contact manufacturer for more info.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Shredders problems?
Shredders
Finding a user manual for a...
I'm looking for the user manual... Answer This...
Shredders
parts for Achiever shredder...
I'm looking for the plastic... Answer This...
Shredders
removal of cover
I have a Novitech paper... Answer This...
Shredders
shredder won't shred
I don't know what is wrong but... Answer This...
Shredders
Mechanical sensor broken. Works...
Hi, Hoping someone can help me... Answer This...
Repair Service
Find Shredder Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
