Question about Mach Speed P4MBMS Motherboard
Sound on my pc goes in and out randomly..
Sound on my computer goes in and out randomly, I usually play music on my pc and all of a sudden the sound goes away and comes back randomly...everything is fine with my sound card/drivers. I even tried re-installing my drivers but the problem didn't go away. This is frustrating, please help...I have read posts of people with the same problem but I didn't really see any solutions.
    Sergeant:
  • 222 Answers
Are you sure it's the pc? I assume you at least have some powered speakers if you play music through the pc consistantly. Could be shorting out. Could be many things really. I'd try different speakers 1st and if the same happens then it's pc. From there I'd focus on the power supply. Could be shorting or on last leg. If this only happens after a long time of playing then could be the pc is getting overheated. Hard to say without knowing the quality and condition of pc and parts. Could be the electrical outlet it's plugged into. Move pc to another location and if knowledgeable enough make sure it's plugged into a totally different circuit. As crazy as it sounds, I've tested pc's running off a vehicle inverter from batteries which can actually run better more consistant power than the power company. Beyond heat and electrical, and if not the problem, then I would assume you are trying to do too many things on the pc and bogging it down and using a single core with low amount of ram.
Posted on Sep 12, 2009
How to play music from mobile phone to tv
If you have TV that you can connect a computer to, use the audio in jack for the PC sound and connect a cable that will fit both the phone headphone jack and the TV usually a 3.5 MM stereo cable. Then switch the TV input to PC or whatever number the audio in jack is and play away.
Jul 09, 2016 | Cell Phones
How come the disc for Malata MDVD 6628 cannot be played for a whole song. It can only be played for only about 30 sec, after that, it suddenly changed to random sound which is is not a song.
That would be typical of song "clips" that they give you to "preview" the song before you have to BUY the full version to be able to use it. Usually thosee run for 30 seconds and then fade out.
Aug 05, 2011 | Wanlida Group Malata DVDMidi Karaoke...
Charging the battery on iriver E100
Yes, you use a USB cable to charge it from your PC.
Jun 18, 2009 | iRiver E100 Digital Media Player
Speakers don't play audio
try to change or update you sound driver
May 16, 2009 | HP Compaq Presario F730US Notebook
I have lost all sound in my Presario V2000
sounds to me like either the sound card is faulty or you may need to update the drivers for it
Jan 24, 2009 | Compaq Audio card Sound Card
Strange Green Vertical Line
I encountered a problem with my sony vaio laptop after installing windows xp. It lost sound and keeps reporting that it does not have sound device when i try to play music.
Apr 21, 2008 | Sony VAIO VGN-BX563B PC Notebook
No sound
check the plug that goes directly to the altec box. or it could be the wire is the culprit..
Apr 08, 2008 | Altec Lansing VS4121 Computer Speakers
Sound Starts on Then Goes Off Randomly
I actually fixed the problem. It was a driver issue. Try this with your sound card program. I opened up the program in charge for sound. In my case it was soundmax. And pressed the load defaults button and clicked apply and everything started working again. The same thing happened again after a while so I pressed defaults again and it worked. But It happened again so I uninstalled the drivers and updated them. Everything was fine after that. Now I have a problem with my registry.lol
Hope it helps.
Nov 06, 2007 | Mach Speed P4MBMS Motherboard
Left Speaker Problem
Sounds like the left channel in the built-in amplifier went out or possibly damage in the connector or cabling. Quick test to eliminate the PC is to connect another set of working speakers or headphones into the PC speaker jack without making any changes. If it works w/o problems then it?s the speakers. You can try plugging the speakers back into your PC and while playing something start wiggling the left channel cables and the main cable that goes into the PC. In particular pay attention to stress points like connectors. If that turns up nothing and you have the appropriate tools and skills you can open the speakers up and test out the solder points for the cables as well. As always make sure your warranty has expired completely before you open them up or start cutting away. Let us know if you have any other questions and please don?t forget to rate this post.
Apr 12, 2007 | Logitech Z-2300 Computer Speakers
Mach Speed P4MBMS Motherboard Logo
1,110 people viewed this question
Top Mach Speed Computers & Internet Experts
David
David
Iqbal Husain
Iqbal Husain
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
