Question about Kitchen Ranges
Ignitor will not ignite
When I moved my whirlpool super capacity 465 stove it was working, now that I have plugged it back up the ignitor doesn't work. I have definately got gas coming out , no clicking sound. PLEASE HELP!!!
    Problem Solver:
  • 31 Answers
Sounds like something came loose and it not making contact or the ignitor went bad. Completely take the unit apart, check and clean connections then put it back together and try it again. Make sure there are no fuse links blown as well. Otherwise it was on its out and you just need another one. Also make sure you have power to device.
Posted on Sep 19, 2009
2 Suggested Answers
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool super capacity 465 - Oven won't light
This is your gas valve that is bad on this unit. Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your complete model number and we will get the correct part out to you asap.
We are available from 7 AM until 9 PM CST Monday through Saturday.
Posted on Nov 10, 2009
Whirlpool super capacity 465 gas stove. The oven will heat up but doesn't want too stay heated. What should I do to fix this problem?
Could be a weak ignitor. How old is the unit? What model do you have? Does the broiler work? Need more information. Thanks
Apr 12, 2016 | Whirlpool Kitchen Ranges
I have a Whirlpool super capacity 465 gas oven that won't stay lit. It often lights up the first time just fine but then it turns off which is normal but when it tries to relight itself the ignitor...
That sound to me like yall have some carbon buildup on the igniter. On this stove the igniter does 2 jobs. It lights the burner and verifies back to the control that Houston we has ignition. If junk is built up on that ignitor then she won't be sending verification of ignition back to the control. That white residue needs to be removed. NOTE: I don't have your model number I am going by what you describe that this stove is a Direct spark ignition model. If you have a normal ignitor it probably is weak and not drawing 3.5 amps to open the valve. Post a model number (bottom drawer frame)
More Here
Sep 08, 2011 | Ovens
I JUST MOVED INTO A HOUSE WITH A WHIRLPOOL SUPER CAPACITY 465. IT DIDN'T COME WITH A MANUEL AND WE DON'T KNOW HOW TO BAKE. WHEN WE PREHEAT IT DOES NOTHING. THE SELFCLEAN AND BROILER WORKS THOUGH
Remove the bottom tray in oven compartment...... usually 2 screws at the rear... Turn it on to bake and see if ignitor glows if not test ignitor for 120v if you have 120v replace the ignitor. If it glows and still does not light burner after a few seconds the ignitor is weak replace it. (The gas safety valve has to receive a certain amount of power that must flow through the ignitor for the burner to ignite a weak ignitor will not allow enough power to flow through it). If you are not getting 120v trace the circuit.
Nov 04, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirpool gas stove super capacity 465 the stove works but cant get the oven to work
whirlpool super capacity 465 accubake system gas stove with auto starter - oven worked fine the previous night the next day will not do any thing any help out there?
Jan 16, 2010 | Ovens
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
I just had my ignitor replaced. The ignitor glowed but it must pull a certain amount of amps before it will allow the gas valve to open. Once the ignitor starts glowing the gas should come on within 30 seconds. Now that I saw it done I realize it was something I could have done myself. Be sure the tech does not try to slip you a used ignitor as mine tried.
May 23, 2009 | Kitchen Ranges
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
The range on Whirlpool Super Capacity 465 will not ignite
You need to replace the oven ignitor. This is located under the bottom pan of the oven. Take out the racks and then remove the 2 screws from the back section of the lower plate. Then you will find the ignitor. The ignitor may still get red but the ignitor has to draw enough current to open the gas valve. This is a very common problem. Replace the ignitor and this will fix your problem.
Feb 06, 2009 | Whirlpool GS460 Gas Kitchen Range
Whirlpool Super Capacity 465 the oven/broiler does not come on.
More than likely a bad ignitor
Here is how to tell If the ignitor is glowing it should be VERY bright, if it is dim orange it is weak and bad.
Jan 08, 2009 | Whirlpool SF357 Gas Kitchen Range
Whirlpool super capacity 465 gas range model# sf377pegq5
I have the same problem intermittently on my Super Cap 465. After reading the following quote from another site, "There have been cases where radio waves, electronic signals and sometimes something as strange as dimmers in lights have caused some weird problems with some computer panels in stoves like these", I tried turning off lights that might be on the same circuit and wouldn't you know it, the oven igniter circuit worked.
Aug 20, 2008 | Whirlpool GS460 Gas Kitchen Range
Kitchen Ranges Logo
130 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
