Question about Acer Aspire 9300 Notebook
Acer aspire 9300 screen doesn't show . it powers on but the screen is still black. its not two years old yet.
  • Acer Master
  • 13,433 Answers
You got two year warranty on it? My acers have always had only 1 year warranty.
The laptop is most likely unable to start up. In most cases its a hardware issue, should take the laptop to a local professional for a check or if your in warranty contact acer.
Possible reasons could be bad memory, overheating, failed mainboard, failed video adapter, loose contact between display and mainboard.
You can try reseating the memory in the bottom of the laptop, it will be covered with 2 screws.
Remove them, and take out the ram from the computer, make sure they are clean, do not use water, or clean them, you can use the eraser end of a pencil to clean the contacts on the memory modules.
Place them back in and make sure they are in the right away, only handle them from the sides.
If the problem still remains, unplug and remove battery again, (might aswell keep the battery removed untill the issue is solved.)
Remove both ram modules from the laptop.
Start up the laptop with no ram at all, it may beep or complain, or it may do noting, unplug after 1 minute.
Plug in the other memory card, plug the machine to power, try starting up, if it works, turn it off and place in the other aswell, turn on and see if the machine works, if it does, problem solved. If it does not work.
Remove both ram modules, try the other memory on both slots and try starting up each time, remember to unplug power every time.
If the problem remains then do the same with the other memory module try it on both slots.
Next thing you could check at home is the cables between the display and the mainboard, you can also check the display in a dark room or under a light and see if there is picture on the display but no backlight, in that case the issue could be the cables between the mainboard and the inventer or the inventerboard or the backlight itself.
This will require repair in any case take it to a local professional.
Posted on Sep 11, 2009
  • 39 Answers
Try to use external monitor.
If external does not working- sell for parts
If OK try to repair backlight or inverter
2 Suggested Answers
  • 178 Answers
SOURCE: acer aspire 9300 notebook black screen while in use
If there is power beside you,why not connect you laptop to the family power,it will be good to your acer aspire 9300 battery life .Pay attention to your acer aspire 9300 laptop have been 2 years old,i think it most properly some problem to your acer aspire 9300 battery.
Posted on Jul 13, 2010
Acer Aspire 9300 1 long and 2 short beeps
Have the same problem and i solved it after 1 month tries
the problem was in NVIDIA Graphic card
the solution was by by heating the NVIDIA Graphic card for 5 min or more
Sep 26, 2012 | Acer Aspire 9300 Notebook
When i turn on my Acer Aspire 9300 the power comes on but will not boot up. I have even hooked up a external monitor that worked for about a week now NOTHING!!
if nothing showing on screen graphics card problem check the hard drive light is showing during boot up or it's a faulty hard drive to
Nov 16, 2010 | Acer Aspire 9300 Notebook
Acer Aspire 9300 My Aspire 9300 has worked fine
It maybe the problem of your graphics processor,so you can't see the NOOK working normally .Your Acer Aspire 9300 battery haven't effect to this mattery ,why you tried taking it out !
May 18, 2010 | Acer Aspire 9300 Notebook
Acer aspire 9300 notebook black screen while in use
Sep 24, 2009 | Acer Aspire 9300 Notebook
Acer Aspire 9300 turns on with black screen
Hello!!
Try entering thro the safe mode ... and restore the system. let me know the updates.
Cheers!
Jun 23, 2009 | Acer Aspire 9300 Notebook
Acer aspire 9300 black screen (display adapter)
I have been fixing computers that has long beeps and short ones. It is usually attributed to memory problem connection. Open the memory compartment at the back of the PC then detach the memory card. Clean with cloth softly enough not to destroy the circuit board or a pencil eraser to clean-up dust that caused the connection blockade. Reconnect after cleaning.
Jun 21, 2009 | Acer Aspire 9300 Notebook
My Aspire 9300 no work anything
Did you recently change or add memory? My 9300 will not recognize 4GB RAM after I upgraded the BIOS to version 1.2, so I use only 2GB and it works ok again.
Apr 27, 2009 | Acer Aspire 9300 Notebook
My acer aspire 9300 doesn't turn on.
Try this
Remove all power from the computer
Laoptop: remove the battary & the power plug
Desk top: remove the power plug
Hold the power button for 60 seconds
Plug your PC on and reboot
Feb 18, 2009 | Acer Aspire 9300 Notebook
Acer 9300 bios upgrade failed
Hi!
I have the same problem, and my problem was that I have installed 4GB ram and that ram modules wasn't accepted with the new bios. So I installed the old modules and it all worked again, downgraded the bios to one version older and installed my 4GB ram modules and it all worked.
Hope that's your problem too.
Good luck
Feb 14, 2009 | Acer Aspire 9300 Notebook
Replacing a back cover on Acer Aspire 9300
This link shows how to take apart an ACER 5100, which is a similar procedure to dissasemble your laptop. Once you get the screen out you'll see how to finish the repair.
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 09, 2009 | Acer Aspire 9300 Notebook
Acer Aspire 9300 Notebook Logo
865 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
