Question about Watches
Watch won't start. - Watches
  • kurlandn Sep 11, 2009
    I do not have manual. Cannot see how to get access to battery or how to do anything but change time and date.
  • kurlandn Sep 13, 2009
    Sorry. Sharp SHP 105, Battery 377
  • 13,433 Answers
Please tell us more about your watch, is the battery empty? have you tried a new one?
Posted on Sep 11, 2009
  • Ekse Sep 11, 2009
    can you atleast send the brand and model of the watch? it just says "watch" on your post. I don't know what watch it is.
Won`t start after battery change
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs....
Oct 06, 2015 | Tissot watch - T17.1.586.52 PRC 200...
Watch won't work after changing battery
Apr 20, 2013 | Watches
Only second hand operates. Rest of the watch won't move.
The seconds hand is purely a 60 second timer mate! It's the small crono dial at the top which is actually the real seconds hand! To get it going you need to unscrew your top adjusting wheel and push it once.....and it will start and the watch will hold time fine!
To stop the large seconds timer hand undo the bottom adjusting wheel and push it! Boom job done!
It caught me out aswell until a watch maker told me Rolex works the same and what you think is your seconds hand is just a timer the other hands won't follow hope this helps chaps
Aug 23, 2012 | Nixon 51-30 Chronograph Wristwatch
New watch won't start
Maybe the battery is bad? If its new take it back to where ya bought it and tell them. Most places will replace of fix it. I would check the battery.
Aug 11, 2012 | Armitron Watches
I'm able to set the time and date but once i push the crown back to its original place the watch doesn't start so i push the upper bumper and the seconds begin to run nevertheless the minutes never...
your watch is chronograph,. and it is not in the picture. probably your problem is the second hand won,t move, it is because that the sub dial on the lower part it is the real second hand. the big second hand is for the stopwatch. the to sub dial on the upper sides of your watch. the upper button/bumper is to start and stop the stopwatch or the big second hand and the bottom bumper/button is to reset it. i hope this can solve the problem...
Jul 25, 2011 | Swiss Army Wenger Sportedge Bracelet Watch
Hi i just bought a "the cannon" watch from west 49 and i don't know how to get the watch to actually start. i set the time on it but it won't start ticking. i'm wondering if it's...
Hi alec,
I see that you cannon watch is not ticking even after you have set the time.
Well after you set the time you push the knob back in once the time is set right then the watch should start ticking that instant.
If the watch is not ticking at all then it is either a damaged watch or the watch sold to you may not have batteries on it.
can you give me a model and info regarding the watch maybe we can get information or a manual about the watch for further checking before considering it to be broken.
Also if you can try calling or going back to where you purchased the watch maybe they give you details on why it will not click since you just bought it I believe they will assist you if it may need replacing.
I hope that this helps.
Have a nice day,
mvincentc
Jul 02, 2011 | Watches
What kind of battery does the texas instruments model 101 watch use?
I am pretty certain that this watch uses two #386 silver oxide button cells. Alkaline cells would work, too, but they'd burn out more quickly--not that batteries last all that long in this watch, anyway. I'm basing this on the slightly newer (~1976-78) plastic-bodied TI LED watch that I have in front of me that I believe contains the same time keeping module as the original model 101.
It is also possible that the earlier watch would have taken #357 batteries, which are the same diameter as #386 cells but slightly taller. Both battery types were popular in LED watches of the time. However, I would suggest starting with #386 cells, as I destroyed the case back of a plastic TI LED watch many years ago by trying to use #357 batteries instead of the slightly smaller 386s. Both batteries put out the same voltage, so the watch will light up with either. However, the case back won't close if the battery is too tall--and if you force it, you can bend, distort, or shatter (in my case) the all-but-unobtainable case back.
Have fun with this watch! Mine still lights up and keeps good time.
May 28, 2011 | Watches
I have a watch which I use sparingly for less than two years. The watch stopped working even with a new battery.
mcdevito75 here, Sometimes not useing a watch is just as bad as over use. Try to set the time and move the hands around a bit, the mechanism is most likely a little stiff, you can also try to tap the watch with something that won"t hurt the finish, (Handle of a Steak knife) at the 2--and 4 O"clock position on the watch and at the 9 O"clock position on the watch caseing not the crystal (glass)
Jul 03, 2010 | Watches
Replace battery for PULSAR Y911. how ro start it?
To restart the watch, you have to short the battery with a pin that sits under a sticker on the back of the watch. The sticker is supposed to explain that. You can usually do it with a pair of sharp scissors or tweezers. Without "jumpstarting" the watch, just installing a new battery won't start the watch. (I don't know why.)
Dec 04, 2009 | Pulsar Watches
Watches Logo
24 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
