Question about Pool & Spa
I cleaned my great lakes hot tub and there is no on and off switch! i turned the jets off after it was completely drained then i filled it up put the filter in and now it wont turn on! how do you turn it on!
  • Dale Cobb May 11, 2010
    do you hear the pump(s) turn on? Sometimes when they are drained and refilled, the pump can airlock and not pick up prime. If it's an electrical issue, check the breakers and GFCIs. When refilling your spa, try to fill it through the skimmer to try and prevent air lock.
    Problem Solver:
  • 8 Answers
Sounds like you have an air lock. Loosen the union at the pump, turn jets on, air will escape and then tighten back up.
Posted on Sep 25, 2009
How can i clean/disinfect my tub/jets really really well? Im not sure what is safe to use in my tub.
Log in to this link.www.wikihow.com. It will give details . you can use dishwasher detergent works well for me. fill the tub with hot water ,several inches above the jets, run for ten minutes or so , drain refill with fresh water run for ten minutes to flush system . drain again finished.
Nov 12, 2014 | Home
Morgan hot tub
if no drain at bottom usually with hose connection on it use a sump pump or syphon make sure power is off until fully refilled
Jun 30, 2014 | Pool & Spa
Great lakes hot tub humming sound
You either have a locked pump, impeller or stripped impeller on the pump shaft. Remove the jet pump assy and repair the pump and or impeller. You can also replace the pump assy.
Apr 30, 2014 | Holmes Products HM495-UC Humidifier
Water is draining from hot tub after its filled & dont know why
Hi Mary,sounds like your drain stopper may not be closing tight.Try removing the stopper by turning it counter clockwise,then jam a small rag in the drain as tight as you can to stop the water and fill the tub.If it still leaks then the drain plug where the stopper goes may have to be re-sealed or one of the jets may have a leak.If the tub is over a ceiling do not keep re-filling the tub you will cause major water damage to the rooms below.
Jan 05, 2014 | Leisure Time Filter Clean 1 Quart - 12...
How do you clean the jets in a whirlpool tub? Is there any product to put in water and run jets to clean them?
Put white vinegar in the water and run it through your tub. Fill the tub to it's maximum running capacity, which is normally just above the jets, and pour a gallon of vinegar in the water with it. Let it run with the vinegar for about 20 minutes, then turn it off and let the vinegar sit in the jets for about 30 minutes. Then start up the jets again for about another 10 minutes and drain. Then run plan water through the jets for about 15 minutes, drain and that should do it. I would recommend doing this at least once every 2 months depending on your water type and how often you use the tub.
Feb 13, 2013 | Home
I have a walk-in jacuzzi-type bathroom tub. When the automatic blower comes on it sends out a mildew smell. How can I get rid of it?
First of all, after each use, refill the tub with warm water and run the jets for about 10 minutes to clear out any excess debris etc.
To eliminate the smell/mildew/mold. :
-Fill the tub to above the jet level with HOT (over 140deg.) water
-Add two tablespoons of low sudsing dishwasher detergent and five cups of distilled white vinegar
-Run the jets for 20 minutes
-Drain the tub and use a tooth brush or any small brush to gently clean inside and around all of the jets and nozzles, remove all foreign material you can from the areas inside (disassemble the outter rings to do so) and around the outlets. Be as thorough as possible.
-Rinse and refill the tub with CLEAN COLD water and run the jets for another 20 minutes.
-Drain the water and the smell and mildew should be eliminated.
To prevent future mildew build up/odors once a month fill the tub with HOT water (again) and four to five cups of vinegar (no detergent) and run the jets for 20 minutes. Drain and fill with clean cold water running jets another 20 minutes. If the tub is used very often you can increase the scheduled flushing of the system to every two to three weeks. The mildew/mold flourishes in the warm wet areas inside the jet tubing and nozzles. Diligent maitenance is the best way to make sure you're not bathing with any unwanted guests in your bathwater!
-Take care
Mar 01, 2012 | Washing Machines
I have a 2004 great lakes hot tub with a balboa controler. My hot tub heats up fine when the pump runs on high but the temp light never comes on when the pump runs in low.
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Feb 04, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Reset error code hot tub
tub is in sleep mode usually to change u must press temp button then light button you want to b on standard mode STD
Oct 04, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
I have an Eljer jet bathtub with a smell to the water when we bat
What you smell is algae forming in the pipes. If you have small black particles in the tub when running the jets, it is algae. Fill the tub with hot water, add 2 teaspoons of cascade dish soap and 1/2 cup bleach. run the tub for 15 minutes and drain. fill tub with cold water, run for 15 minutes and drain, tub is now ready to use. repeat as necessary.
Aug 02, 2009 | Home
Indoor jacuzzi bathtub problem
Just add 1/2 cup bleach to a full tub of clean water, turn on the jets.
Grab a small goldfish strainer / net and scoop out the moldy chunks.
Keep cycling the water until most of the chunks are gone.
Drain the rub, refill and add 1/2 cup bleach again, repeating the process.
The problem is caused by water left in the lines after use, and it turns moldy.
After each use...drain the tub completely, then turn on the jets for about 10 seconds. This will purge the lines of any standing water.
Fill the tub with clean water and cycle the jets with bleach once a week to prevent any further problem.
Hope this helps...it worked for me, I had the same problem.
Nov 27, 2008 | Home
Pool & Spa Logo
441 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
