Question about Kyocera FS-3900DN Laser Printer
Won't print, screen says processing - Kyocera FS-3900DN Laser Printer
The Computer won't get to the Desktop Screen. It stops the process of logging in at a screen that shows a loading bar that keeps repeating.
You will need to either, re install the operating system or do a system restore. The latter is available on the F8 screen (press at computer start.)
Aug 16, 2013 | Computers & Internet
Is it possible to screen print at home, not professionally?
it sure is. read how to screen print at home here
http://www.guardian.co.uk/lifeandstyle/2010/may/11/how-to-screen-print-tshirts-at-home
Feb 21, 2013 | Crafts & Hobbies
Brother mfc 257 won't print blue
Printhead is bad and needs replaced. Brother gives a 1 year warranty and may replace the printhead for free even after the warranty has expired.
Feb 10, 2013 | Office Equipment & Supplies
I have a Lexmark S504 wireless multifunction printer. I can print a test page but a can't print anything from any application. The Windows print page window comes up and if you click OK it appears to...
It could be a printer driver issue. Please follow the steps below to fix the problem.
First, clear the print queue from any stuck print jobs. You can do the steps mention - going to Services and stop the print spooler, delete the files in the spooler folder and then restart the service.
Second, delete the existing Lexmark Interpret S405 printer driver. On your computer, go to Start menu > Programs > Lexmark > Uninstall. After the uninstall process, reboot your pc when prompted.
Third, visit the Lexmark website to download and reinstall the Lexmark Interpret S405 printer driver. Select the version of your Windows operating system. Download and execute the file. Follow the instructions on your computer screen.
After the reinstall process is successful, try to print again to verify that the problem is fixed.
Sep 07, 2011 | Lexmark Interpret S405 Wireless All-in-One...
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
I get a ink system failure, hp c8180 all in one printer ?
Hi, Its a common error which comes for many individuals and we can rectify by ourselves.
Please perform the following steps. 1]Press and hold the "*" key. 2]Press the "#" key and release both keys. Display should say "Enter Special Key Combo" 3]Press and release in sequence the "1", "2" and "3" buttons.screen will say "support" R0631M 4]Press and release the right arrow button until the display says "System Configuration Menu". 5]Press and release the "OK" button. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", 6]Press and release the "OK" button.Display should say "Hardware failure status: Clear. Press OK to clear". 7]Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". 8]Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 9]Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 10]11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. 11]The error won be displayed in the printer. 12]Let us print a self test page to check the functionality of the printer.Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report
THANKS FOR USING FIXYA..FEEL FREE TO POST YOUR COMMENTS.. BEST WISHES
Dec 19, 2010 | Office Equipment & Supplies
The print screen process will not work with my keyboard. Neither will the Alt + prtscrn. I do not get anything when I try to paste.
Press PRINT SCREEN.
Click Start
Click All Programs
Click Accessories
Click Paint
When Paint opens, click 'Edit' and 'Paste'.
You should now see the captured image of the screen.
Note that ALT-PRINT-SCREEN captures _only_ the current window;
PRINT-SCREEN captures the _entire_ screen.
Dec 30, 2009 | Adesso (KB-558B) (KB558B) Keyboard
XP SP3 sends docs to print que but nothing prints
Open up your print queue. Cancel All jobs.
Go to the start menu and either click on, or search for cmd. This will open the command window. You also need to open your task manager.
In the task manager, search for a process called spoolsv.exe, or if that doesn't exist, find a process with "spool" in the name. This is your print spooling process. Right click the process, and end it. You can close the task manager now.
Next, go to the command prompt. Type "net start spooler" without the quotes, and hit enter. This should restart your spooling process. Close the command window, and try to print.
If this doesn't work, you should check to make sure you're printing to the correct printer. If it doesnt solve the problem, uninstall your current printer (you may have to end the spoolsv.exe process again), and reinstall the drivers for your particular model, which you can find at the manufacturers website.
Jun 23, 2009 | HP Remanufactured Compaq Presario SR1130NX...
Kyocera FS-3900DN Laser Printer Logo
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
