Question about Bose Wave Radio
Bose Wave Radio. Loud buzzing noise, started with
Bose Wave Radio. Loud buzzing noise, started with just FM now does it on AM and alarm. Noise is so loud that is about all you can hear.
  • 16 Answers
SOURCE: Water spill on Bose Wave Radio - Radio now buzzes.
Bose have fixed, standard repair rates for all faults and should be able to provide you with an estimate before sending. These are almost always economical to repair...
Depending on the age of the product, it should be repairable, but if not, they may offer a trade-i to the latest version
Posted on Jan 25, 2008
  • 20 Answers
SOURCE: bose wave radio static only
Try replacing the battery (turn it over, have a look on the bottom there will be a door for a battery) and then trying it. Alternatively connect a aerial as it sounds like a reception problem.
Posted on Dec 11, 2008
SOURCE: no fm or am reception on my bose wave alarm clock radio
I had the same problem took off the two screws in the back and one under the cd cover once I took it apart the am rod was loose i put a piece of duct tape to hold it down and it works great, don't drop it anymore
Posted on Mar 25, 2009
BillB-SA
  • 2761 Answers
SOURCE: Bose wave radio won't turn on
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monpoly on repair of these units. Their web site, www.bose.com, offers to repair most Wave radios for $100 or to provide a $200 allowance towards purchase of a new Wave. Before you spend the big bucks on theis trouble-prone product though, you might want to check out the new HD radios -- better sound and MUCH lower prices than Bose.
Posted on May 22, 2009
cjackHD
  • 71 Answers
SOURCE: How can I get the Bose Wave radio to work in Europe??
Yes. The tuner spacing option should do this. If it's a Wave Music System or a Wave Radio II, go into the 'setup menu' and look for 'tuner spacing'. -If it's older, you may want to call Bose for a solution.
Posted on Jun 12, 2009
Loud static burst at random times
Bose is proprietary. It could be electronic parts that are called capacitors.
Dec 09, 2013 | Bose & Wave& Music System
AWRC3G
Assuming you're talking about listening to radio not CD, I feel like an idiot asking this but do you have an antenna attached to the FM antenna input on the back? If not, attach one. The FM antenna in the power cord is rudimentary at best. Putting your hand on it makes you an antenna so hissing stops. Move away it starts again.
Apr 17, 2013 | Bose Wave Radio
Loud popping noises affecting C D and Radio
You need to stop using the system to avoid further damage, go to www.bose.com contact customer support and the technical department, they have the authorized technicians and the much needed parts available, service is done on site by their factory trained personal.
Jun 16, 2012 | Bose & Wave& Music System
Bose Wave Radio, Model AWR1-1W When turned on radio emits a loud buzz and no other sound. Pushing tuning, volume, and aux buttons has no effect. Is this fixable? If so, how?
Loud buzz is usually caused by static and radio interference in radios. If none of this is affecting you unit presently there there is a probability that some cables which aid the fm antenna in receiving stations this could act as static which brings about the buzz on the unit. Either way it is caused by interference on the fm receiver end and all you have to do is get that serviced and the problem is solved.
Hope this solution has been helpful?
Dec 30, 2010 | Bose Wave Radio
Bose Wave Radio pops, loud hum that fades
Power supply capacitors have dried out and need to be replaced.
Sep 03, 2017 | Bose Wave Radio
Bose Wave Radio only turns on + off using am/fm toggle button
Unfortunately, Bose does not release their parts lists or schematics, effectively creating a monopoly for parts and repairs. In fact, their web site says that the Bose factory is the only option for service or repair. They used to list a flat rate repair charge on the web site, but removed it - probably because it scared too many people. Their troubleshooting guide (below) might help, but it's very simplistic.
Before you invest in expensive factory repair on one of these trouble prone sets, you might want to investigate the new HD radios -- better sound at a MUCH lower price.
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/troubleshoot/index.jsp
Jun 11, 2009 | Bose Wave Radio
Bose wave radio
phoned bose as i have similar prob, bose said remove the 9 volt batt under base leave for ten mins then plug into mains without bat and try again if this fails it needs to go to bose.
Nov 10, 2008 | Bose Wave Radio
I need an instruction book for my bose radio.
Hi - You can download the manual from the link underlined in blue below:
Bose > Wave Radio
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Jul 29, 2008 | Bose Wave Radio
How do I make my alarm on my Bose Wave Radio play the FM Radio instead of the usual beeping noise?
When you choose the alarm button on the back row of buttons in the middle you get 4 options, no alarm, beeping, music, beeping & music. These are represented by icons on your front panel the note and the ))) sign.
Regards
Derek
Dec 20, 2007 | Bose Wave Radio
Dec 14, 2007 | Bose Wave Radio
Bose Wave Radio Logo
1,655 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
