Philips J44414 Logo
Posted on Sep 11, 2009
Icatch philips webcam green hue very dark
Ywas fine yesturday now it doesnt work all green and dark color view
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Sep 22, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
2806
Points
21
Some times if you remove the drivers and then reinstall the device it works fine.
I hope this helps.
The grey in my relaxed brown hair occasionally turns a greenish color I use adore semi permanent, dark chocolate any idea how to avoid this?
Your hair is turning green because your missing red when you color your hair. Gray is uncolored hair and to get to a dark chocolate brown you need to add a little red to the color to make up for this. You don't need to strip it out.
Have you heard of people using purple shampoo to neutralize the yellow tones of their blonde? Red will neutralize the green tones, so adding a little red to your color will do this for you.
2helpful
2answers
Philips 55P8288A tv has a dull color and a red hue.
This sounds Like the the coolant for your piture tube has become cloudy and needs replacement (usually blue or green tube - thats why the image seems ovrely red).It's a big job (labour wise) since completee dissassembly is required ($200-300). It can be done youreself - check out TVrepairkits.com to get the coolant and instructions.
You can confirm that this is the problem by dissassembling the unit to the point where you can view the face of the CRT's (red green and blue) directly.
Dark picture
Well now I'm pretty sure that you can adjust the hue/contrast/brightness directly from the program using the drivers to access the device or you can simply go to philips.com and ask the resident experts. they are the very best chance you have in solving a philips related problem as they are the one who work with the product you are having a problem with.
Philips PC Camera SIC4750/27 Problem.
if you can change color effects then make sure it is not on negative mode
Ezonics IcatchVI PC Camera Ez307 help????
Something probably corrupted your webcam software or configuration. Probably the best is to uninstall and reinstall the drivers and the software.
Please check http://www.pcauthorities.com/pc-errors/how-to-fix-webcam-problems
The drivers should be here: https://www.shopezonics.com/Articles.asp?ID=108
Jules
HP 7550 PhotoSmart Printer prints photos with an unpleasant green hue.
If it's a B&W or sepia photo, and you wanted to print B&W or grayscale anyway, pull the color cartridge (assuming a 2 cartridge system). I did that with my HP DJ 5440 and it works perfectly.
2answers
Philips PC Cam
I have a philips webcam, afortunentaly i loose my driver CD!
Green hue instead of actual colors
Short on the crt board, look in the green area. Probably an small 3 leg transistor.
Faded colors
If the picture is dark or messed up too bad, the magic focus will not function, are all the primary colors faded? RED GREEN BLUE? You might have a bad CRT, would call a service man to check out.
Top Philips Computers & Internet Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
