Question about GPX KCLD8815DT 7 in. Portable Television
Gpx under cabinet entertainment system KCLD8815DT
I am having trouble figuring out how to program this for cable. We have the cable hooked up and all I get is ch3/stereo when I have it on catv. I do not have an owners manual to figure this one out. I appreciate any help I can get.
  • 346 Answers
SOURCE: no sound
make sure the tv is not in the SAP mode
Posted on Mar 10, 2008
0 characters
1 Points
What size Machine Screws do I need to mount a GPX Under Cabinet TV?
Um, "machine screws"? Unless you have a metal fitting inside the cabinet for those to screw to, you don't need machine screws.
Assuming you do have the metal fitting, then take that fitting to the hardware store to get the correct screws (and perhaps nuts). How long? Measure the thickness of the bottom of your cabinet, add the thickness of the bracket(s), and get the next size longer.
Jul 09, 2015 | GPX KCL8806DT 7 in. Portable Television
TV-524 5 in. Portable Television: I have to upgrade my cable TV due to my cable comp...
There are "SMART" Universal Remotes out there that can be set to Learn the signal from the original remote when you point it at the new one and hit the button you want it to learn.
May 16, 2010 | GPX TV-524 5 in. Portable Television
No picture/no clock/ no sound nothing just black screen working fine one minute/gone next
i Know that GPX had problems with their under the counter TV. Contact them and you probably need to send it back to them for replacement. or you can check your stores to see if they have one like this.
Mar 08, 2010 | GPX KCLD8815DT 7 in. Portable Television
My remote is lost, i have a universal, but i need codes!
you should have the manual for the universal remote. go to the universal remote website for a listing of codes and just look under gpx. all gpx codes will work with just gpx.
Feb 19, 2010 | GPX KL858S 8.1 in. Under Cabinet TV
My gpx under the cabinet tv comes on, but after a few minutes the sound gets static in it, then I lose the picture, but the sound comes back perfect.
Double check the cabling, loose cable will case such issues, also try a different cable, if neither works, most likely you will need to exchange it.
Apr 02, 2009 | GPX KL858S 8.1 in. Under Cabinet TV
GPX Under The Cabinet TV/DVD Combo blips on and off
yes. you may reset your tv, by switching it off for some time.
Mar 06, 2009 | GPX KL858S 8.1 in. Under Cabinet TV
Gpx Under Cabinet TV
Have you tried to fine tune the channels? Other wise you need to set channels for cable and not air.
Jan 27, 2009 | GPX KL858S 8.1 in. Under Cabinet TV
Alba portable tv
i have a alba TVD3406X1 and the dvd player won't work
Jun 14, 2008 | GPX KCLD8815DT 7 in. Portable Television
No sound
Dear beth bnzd
You might have a problem of sound system selection.Check you menu and try to find sound system or just system and select those system one by one until you get the correct one
hope this will work for you
Feb 02, 2008 | GPX KCLD8815DT 7 in. Portable Television
GPX KCLD8815DT 7 in. Portable Television Logo
Top GPX Portable Televisions Experts
John Trigg
Are you a GPX Portable Television Expert? Answer questions, earn points and help others
