Question about Konica Minolta magicolor 2400 Laser Printer
Konica Minolta Magicolor stating paperjam
Anytime I try to print from drawer 2 I receive a paper jam message, and it won't feed all the way through. Otherwise I will receive a fuser jam if it does make it through.
I have a hunch something is also wrong with the drawer itself because it is not supposed to print when any part of the printer is open, however it is still pulling paper from other drawers when I have drawer 2 open.
Please help, I would appreciate it so much!
Thank you!
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta 1690MF causing Fuser Paper Jam error when printing color. Does NOT happen when printing black and white. (Paper is genuinely stuck entering the fuser). Why is the problem happening for...
I was wondering if the original poster of this problem found a solution. My printer does the EXACT same thing. B & W printing is perfect. Any color print jams in the fuser. The printer feeds the paper too far (from thin copy paper to cardstock) so that the top of the page is cut off. Konica sent me a new fuser but that did not solve the problem. Again, this only happens when printing any page that has color on it (even a document with only one letter in color). B&W printing is unaffected.
Aug 27, 2013 | Konica Minolta magicolor 1690MF All-In-One...
Konica minolta MEDIA JAM TRANSFER ROLLER
yes 2 things. 1 bad sensor. 2 bad paper. change paper brand and type. use hammil mill 20# long grain brightness90 and above to test. if this works you need better paper. if not you have a bad jam sensor and need a tech to repair ir.
Dec 30, 2009 | Office Equipment & Supplies
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
KONICA MINOLTA magicolor 5430DL don't recognize paper
The machine keeps track of what paper was reqested last, and asks you to change paper if the new job is different. I get the "put media" message and have to open and close the drawer if my next print job requests a different paper. So I suggest you gently open and slam the drawer a couple of times, or see if you can find the sensor switch that monitors whether the drawer is open. Also check if your paper guides in the drawer are clicked in place.
Sep 03, 2009 | Konica Minolta magicolor 5430 DL Laser...
Cannot see a paper jam even when the messages say there is a Medi
The paper tray should lift to present the paper to the feed assembly. If the paper tray does not lift then that will require attention and a fairly extensive strip down to replace either the complete tray or just the lift assembly.
Apr 12, 2009 | Konica Minolta magicolor 2300DL Laser...
LOve my printer.BUT...the light goes to error as paper jam
Start the Konica Minolta Status application and check the error, you should get more info there.
Apr 02, 2009 | Konica Minolta magicolor 2400 Laser...
KONICA MINOLTA magicolor 2490MF paper jam. It
I believe the duplex door is in the back of the printer.
Feb 18, 2009 | Konica Minolta magicolor 2490MF Laser...
Error light flashed when trying to print with Magicolor 2400W
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Jan 20, 2009 | Konica Minolta magicolor 2400 Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
55 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
