Question about Dell Latitude D600 Notebook
Starting up computer
I have had my computer for about 2 years. Just recently I have had problems starting up my computer. The lithium battery has full power on it but the computer will not start or if it does start it immediately shuts off after 15 sec. Do you have any suggestions because I recently cleaned up the computer with some anti-virus protection software and it had been working until I started having this problem. Any suggestions?
    Problem Solver:
  • 5 Answers
Al parecer tiene problemas con el disipador del procesador trata de checarlo fisicamente y mas que otra cosa que tenga pasta entre este y el procesador,, puede ser tambien que los tornillos que lo fijan esten flojos , solo aprietalos y prueba de nuevo prendiendo tu Lap....espero haberte ayudaddo suerte
Posted on May 31, 2008
    Problem Solver:
Go into safe mode, uninstall anti virus program.. maybe
Posted on Dec 10, 2007
My compaq computer is saying the battery is low. I cannot figure out what I need to order. My computer is Presario is CQ57 Can you tell me what I need to buy. Thank you
the battery is a 47wh, 6 cell,lithium ion battery
this is a battery pack made up of 6 separate batteries and what you have a indicates that one of those batteries is failing
you will need to get the new pack to fix the problem
go on line to Compaq web site spares to get a new one or search on e-bay-- battery for Compaq laptop make sure that you charger is charging before you order as well
Jul 08, 2018 | Compaq Computers & Internet
Battery charging
Depends on how much the battery is in use, and how much battery life is left.
If it's relatively new (3 years old) and fully empty, it could be full by 2 hours - 2 h 30 min. If it gets really hot before that time, it's full by then.
Mar 06, 2014 | Konica Minolta Dynax 5D / Maxxum 5D...
Hi my makita 18v impact driver seems to be getting alot weaker throughout the years, still works but no enough torqe
Lithium batteries have a limited lifespan, typically 3 or 4 years, and their capacity between charges decreases over the years.
To extend the lifetime of a battery it should be run completely flat after every few charges rather than topping it up. New batteries need to be charged several times and run flat under normal use before they gain their full capacity.
Apr 18, 2011 | Makita 18V LXT Lithium - Ion Cordless...
New battery and still camera will not turn on
Lithium batteries are usually supplied uncharged as new. You need to charge the battery (if you haven't already done so).
Out of three lithium camera batteries I have bought recently, only one would charge up, so it is possible that you got a dud. But try to charge it for a full twelve hours first.
Oct 20, 2010 | Canon PowerShot SD1100 IS Digital Camera
I have a Canon PowerShot A530 camera which is around 4 years old. till recently it was working great but from last 3 months, it is giving false indication of low batteries and shuts down. Even after full...
if you are using this camera for 4 yrs with the same lithium battery then you might need to try a new battery
any lithium battery cell's capacity diminishes after long use. it reduces the cell's ability to deliver current. the older batteries do not charge as much as new one.
when you charge your battery it irreversibly loses approximately 20% capacity per year.
hope this help
Sep 08, 2010 | Cameras
I have a Ryobi 18v drill with battery 130429002 that will not hold a charge. Expensive battery with very little use. Can you help?
If both batteries won't hold a charge the problem may be the charger (not providing a full charge). If one battery is OK and one not holding a charge, the problem is probably a defect with the battery. I know there expensive, (I recently had to replace one for DeWalt).
Aug 18, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
May 17, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
Apr 01, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Recently bought Craftsman Lithium battery & charger that failed.
Sounds like your charger is only for NiCad batteries. With most brands, the new Lithium chargers will also charge the old NiCads, but the old NiCad chargers will not charge the new Lithium batteries. You will be very happy with the lithiums once you are able to fix the problem. As for Craftsman, buy Craftsman hand tools such as wrenches and sockets but I'd look elsewhere for battery powered tools.
Mar 25, 2010 | Drills
Battery with HP Pavillion DV5000 won't work. Do I need to replace the battery or is there a battery charger I could use to recharge the battery? Dianne
You can order a power cable online or pick one up at your local computer store. They should run between $80-150. The battery itself is very expensive to purchase but is rechargeable.
Oct 22, 2009 | HP Pavilion DV4015cl Notebook
Dell Latitude D600 Notebook Logo
106 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
