Is it easy to replace a indesit widl126 thermostat fuse? or do i have to pay the £104 to have it done?
5 Suggested Answers
  • 1294 Answers
SOURCE: indesit widl126s
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
Posted on Jun 16, 2007
evanusa
  • 197 Answers
SOURCE: indesit widl126s humming noise on spin cycle and
Your drain filter is clogged with debris. Usually small items like dirt, paper, money, and much more. Clean the filter and you should be set to go.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 01, 2009
SOURCE: indesit 1200 washing machine boils everything and
make sure you have connected the cold water feed and not a hot water supply, these machines need a cold water feed only
Posted on Jul 27, 2010
Daniel S
  • 4323 Answers
SOURCE: Indesit Washer Dryer widl126s Error
Hi
It is an issue with the thermister which has gone bad and needs to be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 04, 2011
Indesit widl126 does not dry
Had the same problem, very hot but wet clothes. This is a condensor drier. The fack that the clothes are hot rules out the heater or its control. If yoy hear the fan running and there is no blockage the fault is caused by the 3 stage water valve. During drying a small amount of water is passed through a condensor chamber, the cold water causes steam the condense backi into water then is pumped out through the drain. If the water valve fails no condensing takes place and the clothes remain wet. The valve is easy to change and costs about 15 pounds.
Dec 04, 2012 | Dryers
INSTUCTION MANUAL REQUIRED
This online company list all Indesit WM manual:
http://www.unbeatable.co.uk/manuals/Indesit-Washing-Machines/27916330.html
From them:
Read & download instructions & manuals for your Indesit Washing Machines product, to help you install or troubleshoot any problems. Check out these manuals to help you set up & get the most out of your Indesit Washing Machines product.
no_image_large.jpg Read & download instructions & manuals for your Indesit Washing Machines product, to help you install or troubleshoot any problems. Check out these manuals to help you set up & get the most out of your Indesit Washing Machines product.
May 26, 2009 | Indesit Washing Machines
Indesit widl126s humming noise on spin cycle and doesnt drain
Mar 06, 2009 | Indesit WA 125 Front Load Washer
Ido not have a manual for this machine (WIDL126 ) and don't know
http://www.instructionsmanuals.com/u2/pdf/lavadora/Indesit-WIDL126-en.pdf
Nov 20, 2008 | Indesit Washing Machines
I've got an Indesit WIDL126S and it is leaking. The water escapes from behind a brass plate with wires on. The brass plate is held on by a 10mm nut. Do I need to buy a bearing and seal kit?
this sounds like the heater you are looking at. try tightening the 10mm nut a bit. if that doesn't work. loosen the nut, pull heater out and use some sealant. why do you think you need to replace bearings and seals?
Aug 23, 2008 | Indesit Washing Machines
Indesit widl126 wont get hot when drying
test thermal fuse and heating element.
Jul 12, 2008 | Dryers
Indesit widl126s
Jun 15, 2007 | Indesit WA 125 Front Load Washer
Washing Machines Logo
262 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
