Question about Ricoh CL4000DN Laser Printer
Windows Vista, I got drivers for a Ricoh Afice CL4000DN, x64 bits, and I can print fine, except everyhting's that's color prints black, eventhough properties are setup to print in color.
I need help with a windows 7 driver for SP-c210SF. does anyone know where I can find a driver that works?
There isn't currently a Windows 7 driver available for this machine. You can attempt using a Vista driver or the driver may be available embedded within the Windows 7 software. Worst case, you can use a generic driver such as the HP Laserjet 4 driver. Using this driver should get you printing but may not allow machine specific functions. It is available from within the Windows 7 software.
Dec 04, 2009 | Ricoh Aficio SP-C210SF Printer
Cannot print to canon c2880 image runner from vista 64 laptop
Sounds like you don't have the proper Vista x64 bit driver installed. It's different from both XP and standard Vista Drivers?
Get it here:
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2269&modelid=14357
Jul 23, 2009 | Canon imageRUNNER 5020i Copier
My Epson RX 620 will not print anything from the computer with Vista
Have you tried running a print test page? Have you gone to epson.com website to see if they have printer driver available for your printer...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=44341&infoType=Downloads -
Jun 16, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Not able to print from windows 2008 server 64 bit but able to print from xp clients
Install Addtional Print Driver --x64 bit from Printer Properties----require first to download Print driver from vendor website or if you already have this driver on CD, insert disc to CD/DVD ROM while installing
Apr 27, 2009 | HP Color LaserJet 3500 Printer
SC366 on CL4000DN
I just came across this post, you've likely solved it by now; However it is a "Toner density" error related to your cyan photoconductor. It is a defective connector. Replacing the cyan photoconductor should solve problem.
Feb 05, 2009 | Ricoh CL4000DN Laser Printer
Color Streaks down length of page
My rep advised that if this problem is occuring when using the feeder, the small glass strip to the left of the glass can have some sort of either high lighter or white out stuck to it. He suggests cleaning this with some alcohol.
Jan 09, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL4000DN Laser Printer Logo
57 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
