Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Recently moved our Canon ImageRunner 3300 and now it has an error code: E000514-0000. Tells me to shut off the main power switch and turn it back on, but error message just comes back up? Help!
    Sniper:
  • 103 Answers
Just clean the sorter unit section
if sorter not attached blower on heater sections up side on delevary section.
Posted on Sep 22, 2009
  • Aashish Chaudhary
    Aashish Chaudhary Mar 28, 2010
    The Copy Delivery Motor & Delivery Sensor Clean And Reconnect Both
    OK
    President:
  • 1,187 Answers
The hard drive in the copier may have been damaged in the move or the connections to it became loose...
If it is pulugged into a surge protector, or battery, or power strip, don't use any until this is resolved. Use power directly from the wall (temporarily).
1. Turn copier OFF and unplug the power cord.
2. Turn the copier ON ... with the power cord disconnected.
3. Leave ON (w/o power) for a minute or so...
4. Power OFF the copier (I know, I know)
5. Plug power cord back into wall outlet (not power strip, etc.)
6. Power ON copier...
If this works, use copier like this for a day or so and then power off and use the surge protector, or whatever...
If it doesn't work (let us know by comment) then you must call for service.
Hope this helps!
Posted on Sep 11, 2009
E000003-0000
good morning sir, my ir machine is 3300 the problem is showing to my machine is E000003-0000 please suggest me answer
Thanks
Apr 21, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
Turn the main power switch(on the main unit's right side)off and on again. error code E000000-0000
check the power supply first. is there any voltage fluctuations? Go to service mode. Addl. function>2&8>Addl. function> select copier. function>clear>err>ok. switch off the machine, wait for 15 minutes & turn on
Apr 09, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
I Have Canon 3300 Error Code 000003-00 what to do fo this
E003
0000 The main thermistor reading is lower than 140°C when paper is moved.
You can try to:
To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
SERVICE MODE: (*)(2,8)(*)
Main cause The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact
or has an open circuit; or, the fixing heater is faulty). The main power
supply PCB is faulty. The DC controller PCB is faulty.
Jul 02, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon Imagerunner 2200 with error code e000000-0000
Try to enter service mode, and from function clear the error.
Switch off and on. If the problem persists you have a problem with your fixing unit...
Sep 02, 2009 | Canon imageRUNNER C3220 Color Copier
Cannon Imagerunner 2200 Error COde: E000051-0000
There is information in the Service Manual to fix this problem. Make a service call and get a technician to fix this problem.
E051 is Horizontal registration HP detection error
0000 At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
Main cause: The horizontal home position sensor is faulty. The horizontal registration
motor is faulty. The DC controller PCB is faulty.
This problem should be handled by a technician.
Jul 03, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Error code E000803-000
that mean low power or The 24V output from the composite main power supply PCB is absent for 1 sec or more.
Main cause The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty.
Making Corrections
1. Connectors
Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely?
NO: Connect the connectors securely.
2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller
PCB (J300)?
(J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3,
J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3)
Feb 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
E000014-0000
E000014-0000 ir 3300 canon machine solution
May 03, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Computers & Internet Logo
367 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
