Question about Acer Aspire 3000 Notebook
Just need to know how to insert a new memory stick I bought for my dinosaur 3000. Fry's salesman said I could find a step-by-step instruction. THX!
    President:
  • 2,976 Answers
Simple. Remove the battery and power cord. Open the small door on the back. You will see a few sockets where the stick will fit. Just plug it in, put the door back on and power up.
Posted on Sep 11, 2009
Testimonial: "Thanks - I knew it should be simple, so when Fry's offer to put it in for only $34.99....I knew I could do it. Thx!"
  • Acer Master
  • 13,433 Answers
Dinosaur, as in a old acer aspire 3000 or what?
Most likely two screws on the bottom of the laptop that hold the memory cover closed, inside you will find 1-2 memory modules, you may have to remove one of the old ones and then install the new one, or if one is free install the new one there.
Testimonial: "Yes, a gift from Dad, who had it for 3 years without using it - he tends to buy bottom of the line, but I have used the heck out if it. Thx!"
  • 615 Answers
This is very easy...turn your laptop over and you will see a small cover with a scrow open it and you will see one or two stick (I do not know how many your has) and take it out by pushing down and to the side the small handle next to the stick then you will see the old one move up pull it and put the new one exactly back and push the stick down and push the lever down back...
Need instructions
Step 1:
here is the pdf file from hasbro for monty with instructions on how to use
Step 2:
Dec 14, 2012 | Hasbro Playskool Kota and Pals Monty T-rex...
I want to transfer pictures from my toshiba laptop to a memory stick can you help please thank you
Insert your memory stick to your laptop, if your laptop has a memory stick slot or in the USB slot (if it is supported). If it doesn't have on you need a memory stick card reader. Insert your memory stick on a card reader then insert the card reader into the USB slot.
After that your laptop will prompt you and choose "view folder".
Now go to the folder where your pictures is located and choose the pictures you want to transfer and then right click on it and click "copy".
Go back to the folder of your memory stick, right click and then click "paste".
That should do it.
Thanks for using fixya!
Update me if you still have questions and let me know how I helped you.
May 28, 2011 | Computers & Internet
HOW CAN I REMOVE MEMORY CARD?
Hi There and Welcome to Fixya.
To remove/insert the memory stick pro duo from your Cybershot DSCW55, follow these steps :
  • Open the battery/memory stick duo cover
  • Remove the battery pack
  • Remove/insert the memory stick duo (insert with the terminal facing the camera lens)
  • Insert the battery pack and close the battery/memory stick duo cover
For more helpful information and details regarding usage and maintenance of this camera, please follow the below link :
Sony CyberShot
Pull up the website and simply click the "Instruction Manual".
Enjoy, and Thanks for using Fixya.
Apr 12, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Sony DSC-P32 Memory Stick Error, "C:13:01"? When I went to review pics on memory card, camera would not scroll through and it would immediately shut off. Assuming it was the batteries, I...
The C:13:01 error code is the self diagnosis display of the camera to identify the cause of the issue with the Camera. This error code indicates the issue with the medium used in the Camera. You can try few steps to check if the issue can be resolved.
Try using different Memory Stick in the Camera.
Make sure that the Memory Stick used is compatible with the Camera. (The maximum capacity that can be used in the Camera is of 2GB Memory Stick PRO Duo.)
Format the Memory Stick in the Camera and check if it works. (Formatting the Memory Stick will delete all the files saved in it).
This may happen if the files in the Memory Stick is damaged or corrupted.
Try turning the camera power off and on.
Remove and re-insert the Memory Stick several times.
Insert another Memory Stick in the Camera to check if the issue is with the particular Memory Stick.
Try resetting the Camera and check if it helps. To reset the Camera, press the RESET button located inside the jack cover using a sharp pointed object.
If the issue happens with different Memory Sticks after performing all the steps, service may be required.
Thanks for using FixYa.
Dec 05, 2010 | Sony Cyber-Shot DSC-P32 Digital Camera
How to use a memory stick right from the start
hi
  • Understand how a Memory Stick Pro works. The small card saves information from a portable device. You can save, delete and rewrite to the card as many times as you want. You can also remove the card and insert it into another device. For example, you can save photos from a camera, then insert the memory card into your laptop to view or download the images.
  • Step 2 Make sure you buy a memory card that matches the demands of your electronic device. The cards have different saving speeds and data-holding capacities. Generally speaking, the more data the card can hold and the faster its speed, the more expensive the memory card. Check your electronic device's product information for recommendations on the best type and size of memory card.
  • Step 3 Insert the Memory Stick Pro into the electronic device. Most devices have a small flap or cover on its side that holds the card. The memory card slides into a slot under the flap. Gently push in the card and close the flap.
  • Step 4 Save to the memory card. Once the card is installed, many devices know to save new data to the card. In some cases, however, you may need to specify where to save files, either to a built-in hard drive or to the memory card.
  • Step 5 To remove the card, open the flap and gently press the card in. The card should then pop out of the slot for easy removal. The card can now be inserted into another device.
  • vote me if your setisfied
    Jun 29, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
    My psp memory card dont let me put stuff in
    you may have to format the card. Also make sure your card is not placed in the lock position.
      How to Fix a PSP Memory Stick
    1. Step 1 Upgrade your PSP's Firmware (its operating system) before doing anything else. Firmware 5.0 solves many software problems that are encountered with older memory sticks. You can upgrade it by simply connecting your PSP to any wireless connection through its WiFi. Once a connection is established, the PSP will update itself automatically.
    2. Step 2 Check to see that your memory stick's plastic tongs, the small sticks that separate each connection, are straight. If one is bent, your PSP will not recognize the stick.
    3. Step 3 Remove your memory stick if it still does not work. Insert it into a PC with a memory stick slot. You will most likely be able to see all of your saved files. If so, continue to the next step. If you still cannot see your files, then your memory stick is defective, and it is not the PSP's fault.
    4. Step 4 Copy your files from the memory stick to the hard drive.
    5. Step 5 Format your memory stick using the "Format Disk" option in Windows. Open Windows Explorer, and find your memory stick listed in the "Drives" section. Right-click on the memory stick, and click "Format." Follow the on-screen instructions in the windows that pop up.
    6. Step 6 Insert your memory stick into your PSP. It should recognize the disk now. However, you now need to format the memory disk again with the PSP.
    7. Step 7 Go the PSP main menu, and select "Settings." Then select "Format Memory Disk."
    8. Step 8 Put your memory stick back in your PC, and return the files you removed earlier. When you reinsert the stick into your PSP, it should now see all the files.
    Mar 25, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
    Need to know jumpers for adding 2gb ddr ram if there are any
    You have inserted RAM in the worng slots. Insert it in alternate slots and not in adjacent slots.
    Mar 24, 2009 | EliteGroup P4VXASD2 Motherboard
    Problem loading the NEW PSP ACTION REPLAY.
    TADA! answer 4 u.
    It's your battery. Take out your battery from the psp and look on the back of it. If, at the top, it says PSP-S110 and at the bottom it says made in China, be bummed. That's what mine said and the codejunkies website warns about that battery. Dunno where to get a new one though. Hey, diagnosing the problem is half the battle. Good luck.
    Dec 03, 2008 | Video Game Consoles & Games
    Acer Aspire 3000 Notebook - major memory problem!!
    it sounds like the memory, try removing the new memory from the notebook and see if there are any errors, if not then that stick is ok, try just your new memory in the notebook and leave out your old memory, if the same problems you know its the new memory, if there are no problems, then the two sticks wont work together.
    Jun 04, 2007 | Acer Aspire 3000 Notebook
    Acer Aspire 3000 Notebook Logo
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
