Question about Samsung Washing Machines
Error Message AE
During a normal wash cycle my samsumg WM1245A washing machine stoped and shown AE message on display.I´t doesn't work ani more when i turn it on it shows me AE messages and is no posible to selec any thing with controls. Please advise.
SOURCE: Error message on washing machine E20
E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
the drain pump may be blocked
or possible your filter is totally blocked. Clean out the filter everything will work again. Put a large bowl under the filter as you unscrew it; a fair amount of water could be there.
Good luck.Please rate the solution if accepted, also do post comments in case of any doubts.
Posted on Jan 23, 2009
  • 67 Answers
SOURCE: Zanussi ZWD1471W Washer Dryer error codes help please!
http://www.serviceforce.co.uk/pdf_search...
Posted on Nov 21, 2007
  • 380 Answers
SOURCE: Samsung washing machine gives Low Water pressure
You get these messages turned off by fixing the problem.
Low water pressure is basically one of the valves is not letting water pass through.
1. Do as you already did and clean the inlet filters. Any kinked hoses?
2. Adjust the water pressure in the house. Is it too high or too low?
3. Replace the valves in the unit.
4. Main board.
Posted on Dec 30, 2009
SOURCE: sud message Bosch washing machine
ur using too much soap rinse and spin and use less soapwhen u wash
Posted on Feb 19, 2010
Testimonial: "thanks-- how do you know how much soap is enough?"
SOURCE: SAMSUNG 845 - ERROR MESSAGE HE2 - not in manual
heater or wiring
Posted on Aug 19, 2010
Came up on display f10 and wont work
Hi dear,
F10 error related to OVER FILL. Follow the things below,see how it works.Thanks.
Troubleshooting
Error messages If an error occurs during the program, a message
is shown on the display. To exit the message after
taking action, turn the machine off and then back
on.
The error messages that may be shown in the
display are:
F10 Overfilling
1. Shut off the water tap.
2. See "Drainage error".
F11 Drainage error
Check:
• that no objects are stuck in the drainage hose
outlet.
• that the drain pump is not blocked by foreign
objects. Clean the pump. See the "Care and
maintenance instructions" chapter.
• that there are no kinks in the drainage hose
After taking action, run the Drain program or press
the Door Opening button (key symbol) to empty
the machine. If this does not resolve the problem,
call the Customer Care Center.
Jan 27, 2016 | Asko Washing Machines
Stuck on "problem detected" screen
Hi deejay961...You may want to begin with the following procedures. Please update your post with your results, and if needed, we can progress until we correct your issue....good luck my friend...chris The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature. "A problem has been detected with this unit" will be displayed on the screen. The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control. Solution: 1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT. 2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in. 3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Aug 23, 2007 | GE WPGT9360EPL Top Load Washer
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing ?Sud? error code on...
The error Sud is shown on the display due to Overdose of Detergent detected during the Wash Cycle in the washing machine.
In this problem check the MCU in the washing machine. The motor control unit senses a suds lock. Also check the Drain pump for any blockage or the heavy load in the washing machine. or over quantity of detergent is added to the machine and that is got blocked.
This will Help. Good Luck.
on Mar 11, 2010 | Washing Machines
Error message: Thermistor Fault
yes it is serious as it indicates an over heating condition probably on the motor or control panel
May 17, 2015 | Asko W6761 Front Load Washer
My washer error message unit detect a problem
The most common solution for this message is to turn the machine OFF and then ON. If the error resets, you are done.
Solution:
Mar 02, 2015 | GE Profile WPRE6100G Top Load Washer
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
As soon as the machine is on an error message of 3E appears and the machine stops
3E - MOTOR RESTRICTION ERROR
Hall Senior is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error is displayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 14, 2010 | Samsung WF337AA Front Load Washer
My ge profile harmony washing machine has a message that says "a problem has been detected with this unit."
Washers - Harmony Washer Error Message or Code
Solution:
GOOD LUCK. TIMOTHY DO 714-334-1998
Aug 04, 2010 | GE Washing Machines
Err02 shown during spin cycle on 1400 haier washing machine
WHEN I INVESTIGATED FURTHER I FOUND THE DRAIN TUBE FROM MACHINE WAS BLOCKED BY SOLID SOAP LUMP BUILT UP AT THE MACHINE END -AMAZING .
Apr 09, 2009 | Washing Machines
Washing Machines Logo
302 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
