Question about Car Audio & Video
Hi we have the code and are down to 5safe but it wont let us put anymore in even though we puttin correct code in vauxhall vectra any ideas thanks
  • yadayada
    yadayada May 11, 2010
    u don't say make year and model so how do u expect to get any help??
  • Car Audio & ... Master
  • 4,917 Answers
To reset from 5SAFE , leave SWITCHED ON...UNDISTURBED for several hours and it will automatically reset itself.
I would suggest that if your radio is NOT accepting your code, the problem is usually a wrong code or you are using the wrong Code Entry Instruction.
If you require the code to be checked PLEASE POST ANOTHER QUESTION quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY BARCODES, LABELS or STAMPED IN THE METAL CASING
Posted on Sep 11, 2009
How do you open a vauxhall vectra boot that wont open
Multiple scenarios:
If there is a release pull handle inside the car, try having someone push down on the boot cover (hood) while you pull the release. Most often this will work. If the release cable is broken you may need to consult a mechanic.
Nov 16, 2014 | 2003 Vauxhall Vectra
Vauxhall vectra fault codes
Check all the pipes under the bonnet as a loose or damaged pipe can cause the spanner to come on without a fault code.
Apr 01, 2014 | Vauxhall Vectra Cars & Trucks
Vauxhall vectra 2006 looses power
have you had the fuel regulator checked a leaking vacuum hose that controls this can make it do this or it is faling.
Jan 26, 2013 | Vauxhall Cars & Trucks
Vectra 2.2
Hi my vectra did this and didn't show a fault code it's the crank shaft position sensor located behind the starter motor on the front of the engine the sensor is about 30 pound mines never cut out sins i change my spark plugs and coil pack to trying to figures out who knew it was a little sensor it through a your crank shaft outta wack and it throws through a lot of petrol otta timing cheers scott
Aug 31, 2012 | Vauxhall Vectra Cars & Trucks
Vauxhall vectra fuel pump not pumping fuel out fast enough
You need to test the fuel pressure and not guess, you have no idea really what is causing this problem without comprehensive diagnostics being done.
Jun 08, 2012 | Cars & Trucks
My 2004 vauxhall vectra bonnet wont open
Cannot say i have done one on a vectra ,a couple on a astra though which is much the same and i went up from underneath with a long screwdriver ,my special snap on one for the old mini bottom hose ,its about 2 ft long
Apr 02, 2012 | Cars & Trucks
Free unlock code for my Delco CDR500 radio in my Vauxhall Vectra
Hi I have just bought a car and it is in safe mode the car is a vauxhall vectra and the stereo is a delco electronic cdr 500 and serial no on it is gm0500t9120228 pls can you help me thanks Brian
Oct 23, 2010 | Car Audio & Video
Delco no.90 566 821 ,suplier 4660103 mc,gm 0500x9595741 I need a code for this cd-player, because I losted and it*s from vauxhall vectra
I need a code for this cd-player, because I losted and it*s from vauxhall vectra b delco no.90 493 281 ,suplier 4 660 103 mc, GM 90 493 281 cdr 500 >PA 6 - GF 15< Thanks. mail sgul@qu.edu.az
Mar 06, 2010 | Car Audio & Video
Need Radio code for Vauxhall Vectra
yellow pages most phone unlocking places do car radio unlocking for a fiver
Nov 11, 2008 | Car Audio & Video
Car Audio & Video Logo
144 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
