Question about Refrigerators
Can't get water at the dispenser on a GE sxs
I can get water up to the connection just below the freezer door. I tried to blow thru the line to the dispenser at the connection but it is plugged. I'm guessing the line is frozen in the freezer door. How do I remove the liner to thaw the line? Or, is there a better way? My model # is GSS25QMFC.
  • bigzip271 Sep 11, 2009
    Thanks for the info, I did try the hair dryer with no luck. I disconnected the line at the bottom of the freezer door and used my air compressor and blew the ice out. Works ok now. Thanks again!
  • 93 Answers
GSS25QMFC I beleive is manufactured by GE. The line could definitely be frozen. 99% of refrigerators you cannot get into the doors. They are glued together and filled with spray in insulation. There is no easy way to do it. You can try a hair dryer or just let the fridge sit for 24 hours turned off with the doors open. Another place to check for a freeze up is in the rear of the refrig section. Most refrigerators run the line in the refrigerator to chill the water and if your refrig section gets too cold they can freeze in there. Most of the time refrigerators have a disconnect in the water line at the bottom corner of the freezer door where it goes through the hinge. You might have to yank off the lower grill to see it, but you can sometimes disconnect it there and let water run out. Good Luck
Posted on Sep 11, 2009
  • Refrigerators Master
  • 1,606 Answers
The inner liner cannot be removed . You can try turning the freezer temp up for a few days , to see if it will thaw . Or , open the freezer door and put tape over the door switch to hold it closed . Tape plastic to the freezer door opening , from the top to the bottom . Leave the door open to thaw . Walk by ocassionally , pressing the water dispensor , until it flows . Keep the freezer setting up slightly more than normal , to keep the door from freezing again .
Posted on Sep 13, 2009
Water dispenser not working GE model GSH25JSX13
Do you hear a slight buzzing when you try to get water?? If yes, you may have a frozen water line inside the freezer door. GE had some problems with those models. They offer a heater kit that has to be installed in the dispenser area of the freezer door. Once installed, in about a day the water line should be defrosted enough to dispense water again. If you don't hear that buzzing sound when trying to get water, you could have a bad inlet valve which is at the lower back of the refrigerator where your house water line hook to the refrigerator.
Mar 04, 2015 | GE Refrigerators
Tip
GE side by side refrigerators wont dispense water.
if you have a GE SxS refr that doesnt dispense water thru the door but you hear the valve buzzing or humming, then you most likely have a frozen water line inside the dispenser housing.
GE makes a repair kit for this. it has a foil type heater, with a 2 wire hook up. it is easy to install and is part # WR49X10173.
available from all internet parts sources for about 40 bucks.
on Jan 10, 2010 | Refrigerators
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
No water from the door.
Below the freezer door, behind the toe kick is a water line union disconnect it and hold the incoming line into a cup, have someone press the water button to see if the water is getting up to that point. If it is, then the water line is frozen inside the freezer door, and you will want to get a heater kit for the dispenser (small heater that attaches just below the water spout in the dispenser).
Jun 14, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
Water not coming out from water dispenser
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the door line is frozen , GE has a heater which is easily installed , to keep this from happening again pt # WR49X10173
May 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Water dispensor stoppedworking
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the time...it works great! If the light or ice dispenser do not work, the problem may be *********** board.
Mar 17, 2010 | GE GSL25JFPBS Side by Side Refrigerator
I have a GE model GSL22JFPH BS refridgerater and
Then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . There is a heater for the water dispensor tube , pt # WR49X10173 , which should keep this from happening again .
Nov 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
No water from door dispenser
you have a frozen wtr line inside door turn it off for a day or 2 then try it again but this time palce a thermometer in frezeer and keep temps at 0 to 4 degrees if it drops below 0 then the line will freeze again
Oct 30, 2008 | GE Profile PSW26P Stainless Steel Side by...
G.E SxS REFRIGERATOR
This is not good GE has a huge kit you have to install in the freezer door to stop the freeze up and it's expensive and a pain to install. I would call a tech out to make sure and go from there. Hit me up if you have any more questions.
Feb 08, 2008 | Refrigerators
Open Questions:
Refrigerators Logo
110 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
