Question about Briggs & Stratton Garden
As soon as my 10 hp Briggs & stratton engine starts, it goes to full throttle. I have no control
  • Briggs & Str... Master
  • 3,519 Answers
The engine speed is controlled by a governor and throttle position. There is a spring that holds the throttle (butterfly valve) against the slower position. When the motor is under load' the governor exerts force to open the throttle position. Make sure that all of the components are clean and not binding. Look for a broken or disconnected spring. It is also possible that the governor is stuck in the demand full throttle position.
Posted on Sep 11, 2009
I have a Briggs & Stratton 10 HP engine, model 220707 that I could use some help with the governor spring on?.
Should see a bracket with holes in it .and a small throttle bracket that has a hook shape the spring locks on to it.
May 20, 2014 | Briggs & Stratton Briggs Stratton Intek V...
I have a 16 horse v twin on my power washer,every time i pull the trigger the engine slow down
When you pull the trigger the motor comes under load as the pump starts to work at full pressure. Check for throttle control and setting for engine speed under load.
Apr 20, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Governor does not seem to work
Sometimes the governor gear inside the engine breaks and you have to replace it. Did you try to adjust the governor by putting the throttle full and unloosen the screw on the governor arm and push the governor piece the same direction as the throttle opens and tighten the screw.
Mar 21, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Ok i have a problem with my Briggs & Stratton 16HP v-twin vanguard engine.When i start the engine and rev it up when i idles back down it sits there and rev's up and down then it straightens out and...
It appears that you have a slight mis-adjustment in the idle speed and idle mixture. To adjust setup, start with at least a half tank of fuel, and have engine at operating temperature (That is warm but not overly Hot). The Briggs & Stratton Website manuals section should show the locations of the adjusting screws if you are not sure of them.
To adjust idle speed set Throttle control to minimum and adjust screw on throttle butterfly to maintain a good idle speed. To adjust idle mixture, screw in idle mixture screw (Lean) until motor falters and then screw out (Rich) until it falters again. Correct setting is the halfway point of these two positions. You may have to re-adjust idle speed again and also the mixture to get best running.
If you are not comfortable doing this, take it to a B & S dealer.
Sep 21, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
3.5 Briggs with not run at full throttle
same problem, was told it was the jets, are your symptoms as follows
runs at low throttle, will only run at full throttle if fully choked
dies if choke is relieved
Apr 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Hard to start lawn tractor
I have 2009 lawn tractor that will not start (from day 1) unless I use a small squirt
of start fluid into the air cleaner area. Nothing else seems to work. The battery will run down before it starts. Once engine is warm it starts great. Love the tractor,
hate the starting problem. Elevation is not a problem in michigan.
Jan 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 2500 Power Washer Loses Pressure Time to Time
If by "a few minutes" you mean 180 seconds, I really don't know what to say. But if you mean 5-10 seconds, you probably are experiencing air in the water line or normal engine warm-up behavior when the choke has been set to full lean too soon.
May 23, 2009 | Briggs & Stratton 020324 3700 PSI Pro...
Throttle control not operating.
Need more information. Is your cable hooked up to the carb or broken? Try checking that. Rick
Apr 06, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
778 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
