Question about Xantrex Technology Heart Freedom 20 12 Inverter
Where can I find parts for my Freedom 20 Inverter/Charger near Virginia Beach, VA? The cooling fan is inoperative.
    Scholar:
  • 76 Answers
Contact Tekris Power Electronics
They are in NJ. Ph 732 938 4996
They know the Freedom units very well, I send all of my dead ones there. Good luck
Posted on Sep 13, 2009
Who knows a good land rover repair specialist in virginia beach va...my land rover range wont start it cranks and doesnt starts thanks and greatly need help
Hello
The engine and automatic transmission in this vehicles drive train are fully electronically controlled by a computer called the PCM (Power Train Control Module). Whenever a problem like this occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM
Jul 26, 2012 | 1999 Land Rover Range Rover
Freedom 20 Inverter/Converter Charger installed on Alpenlite RV. When remote switch for solar use (2000 watt) is turned on, all 110 system is energized. Turn solar switch off and voltage check at...
Second Freedom 25 inverter/charger...first one repaired, this one went to fault...started microwave on fire, fried the satillite receiver and possibly other components....installing a Mangnum....."do not let anyone rebuild the Freedom 25" First time about $900.00 to rebuild...this time about $9000.00 with components it fried. Fleetwood LLC Corporate knows of problems and only offer to sell you the conversion kit for about $4200.00....bankruptcy sanctifies previous problems "they" left with us.
Oct 27, 2010 | Xantrex Technology Heart Freedom 20 12...
The cooling fan in my Freedom 25 is inop. Can it be replaced?
Yes, *if* you can find an exact replacement and get someone to sell it to you. In order to protect their propriety designs, Xantrex only provides OEM replacement parts to its factory authorized service network, but you might find one of them locally who would be willing to sell you the part, especially if the unit is on a boat (a Marine Freedom 25?), and can't be brought to them.
Sep 27, 2010 | Xantrex Technology Heart Freedom 25...
Wiring Freedom 20 inverter
make sure your new inverter is made for 220 volt supply as that is what the red wire represents. its the other leg of a 220 circuit and should not be connected to your new inverter until you read the manual to see if it is designed for this and if so how to wire it in. it could cause you are the unit serious harm if you connect a 110 inverter to a 220 circuit. consult an rv repair shop or a good electrition if you cant find the needed info. it may actually be printed on the side of the inverter as well.
May 27, 2010 | Xantrex Technology Heart Freedom 30...
2009-10-05 I have a motor in my garage that serves my water softener, sprinkle system, and outdoor faucets in conjunction with a well pump. I live in Virgina Beach, VA. The motor is an A.O. Smith machine...
sounds like just pressurizing ur holding tank pumps come on and off depending on how sensitive ur pressure control is normal operation of unit
Oct 07, 2009 | Plumbing
I have a Heart Interface Freedom 20 Inverter/Battery Charger installed on a powerboat. The fan (cooling fan?) is making noise - it seems to be rubbling inside the unit. Is there a way to repair? Replace...
The fan can be replaced. It is very similar to some of the PC cooling fans. I've got the same problem (again) and will be replacing it soon. I will give you the fan specs once I remove my fan ( I think it is 4" 120VAC - will let you know when I repair mine).
Jun 14, 2009 | Xantrex Technology Heart Freedom 20 12...
HEART 25 INVERTER
if the charger will not charge the batteries, it means the charger is bad or the fuse for the charger is broken
Mar 18, 2009 | Xantrex Technology Heart Freedom 25...
Inverter won't charge
check if the inverter has a fuse for the charger, if it does test it if it is still ok if not change it
Mar 09, 2009 | Xantrex Technology Heart Freedom 20 12...
Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
Jan 15, 2009 | Xantrex Technology Heart Freedom 20 12...
Xantrex Technology Heart Freedom 20 12 Inverter Logo
812 people viewed this question
Top Xantrex Technology Boating Experts
Tre Elkins
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
