Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
SDHC High Spedd Card Reader in PowerShort SD500
Hi:
It´s there a way I could Update the firmware of my Powershot SD500 so a 4GB SDHC Card Reader can work?
thanks,
Eliana.
  • joshjoshjosh Mar 09, 2008
    I'd like to know whether canon SD500 supports high capacity SD cards (HCSD). Thanks.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Sorry, no. SDHC cards are electronically different than SD cards and will not work in devices not originally designed to accept them. This is a hardware difference and cannot be changed by firmware.
Posted on Nov 03, 2012
SOURCE: Dropped Canon PowerShot SD500
See Canon SD 600 posts referring to Lens Error, restart camera. I just fixed mine today.
Posted on Feb 26, 2008
t00nz
  • 4738 Answers
SOURCE: My Powershot 450sd camera is not reading 4GB SDHC
SDHC memory cards are relatively new, and are sadly compatible with only the newest model cameras. For your model camera, recommend a maximum 2GB standard SD card. Fortunately, these days a 2GB card is very inexpensive.
Posted on Dec 29, 2008
Apparently IXUS 55 is not compatible with a 4GB SD card. Use a 2GB and you would be fine.
Posted on Feb 09, 2009
  • 11967 Answers
SOURCE: 4GB card incompatible?
I've come across many people who say their card isn't locked only to find that the slide switch on the side of the card is indeed in the locked position. Check yours.
Posted on Jan 15, 2010
t00nz
  • 4738 Answers
SOURCE: sd card
Sorry, but your camera was designed before the 4GB SDHC card came out. Although they look exactly the same as a standard SD card, they are not. Your camera can only use standard SD cards (2GB or less).
Posted on May 14, 2010
SanDisk 2GB microSD Memory Card not working
SaveMyUsb.com can recover data from most flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 18, 2010 | SanDisk 2GB microSD Memory Card
UNABLE TO ACCESSMY 4GB MICRO SD CARD
Your memory card reader lacks SDHC compatibility. You must either update your pc card reader to one which is compliant with SDHC or use a cheap external card reader to do the job.
SD and SDHC cards look the same and fit the same slots, but they have significant technical differences which older readers cannot handle.
Jul 22, 2010 | SanDisk 4GB microSDHC Memory Card
Sd card
May 12, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
It doesn't read 8gb sd cards on internal sd drive
There are two types of SD cards. The first, standard type, had a capacity limit of 4GB. But quite soon the technology advanced and higher capacity Flash memory has been developed, so the standard had to be revised - and SDHC was born (HC stands for High Capacity), which includes cards having 4GB and above.
There is an overlap, as you can see, because there are 4GB CD cards, and 4GB SDHC cards on the market.
Now your DELL is an older machine, and it's card reader is not compatible with the new SDHC standard. And it will not be, even with a BIOS update.
You have two options: find a 4GB SD card (they are hard to find, majority will be SDHC) and stick with this capacity, or purchase an USB SD/SDHC card reader, which is cheap, and use it to transfer files to/from your 8GB card.
Nov 22, 2009 | Dell Latitude D430 Notebook
System could not detect the pend drive
Hi viveka_sirka,
If you have the 4GB card the most likely problem is your reader is not SDHC compatible. SDHC cards are all SD cards that are 4GB and larger. If your reader is the reason then you must get a new reader to plug into your USB port that will read SDHC cards.
Kingston Tech Support
May 02, 2009 | Kingston 4GB Secure Digital High Capacity...
Can ixus700 upgrade to use 4gb memory card?
The ixus 700 is only specified to be compatible with SD memory cards (and MMC cards). The protocol for SD cards only covers up to 2MB. Cards of higher capacity are the SDHC (high capacity) protocol, but this protocol did not exist when the ixus 700 was introduced. As far as I can tell, there is no way to upgrade to be compatible with the newer protocol.
Dec 09, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Sd memory card
Yep, most older devices don't support SDHC in 4Gb or more. My camera didn't when I got my card, and I needed a firmware update for it.
As for your computer, if you're sticking it in a memory-card reader slot, it probably doesn't support it either! =-[
Your best (and cheapest) alternative is to buy a USB card reader that supports SDHC cards. I doubt you could get a firmware update for your existing card-reader, but it's certainly worth a try anyway!
Aug 22, 2008 | SanDisk 4GB Secure Digital High Capacity...
Formatting a 4GB SD card for my canon ixus 700
The IXUS 700 works with SD cards, 2GB and smaller. It will not work with higher-capacity SDHC cards. You need to use SD cards, 2GB and smaller.
The IXUS 700 is called the SD500 in some parts of the world. You may download the SD500 manual and more from here.
Jun 24, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
MEMORY CARD
I would think that as long is it is a sd memory card then it would be compatible since the camera uses the sd card and the 4gb is for photo storrage
Dec 31, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
185 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
