Question about Sewing Machines
Threading a Kenmore 12110 Sewing Machine
My daughter has borrowed my sewing machine and is in another town. I am having problems communicating how to thread it. She says is stiches a few stiches and stops. Can you help her. Email me and I will forward it to her
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
SOURCE: thread keeps snapping on NEW Euro Pro 32-Stitch sewing machine
I also have the same sewing machine. The machine is not very user friendly and the instruction manual doesn't really illustrate the right way to thread the machine. For the bobbin, make sure you thread it through the two tiny holes in the small rectangular metal piece in the bobbin case. I had to use a dental floss threader and tweezers to thread the bobbin correctly, if you can believe it! As for the upper thread, follow the directions EXACTLY as illustrated in the manual. Don't miss the little loop underneath the machine or the tension will be wrong.
Also, use extra strong thread. I used a professional quality break-resistant thread from Germany for both the bobbin and top thread, and the machine works okay.
Posted on May 19, 2008
  • 323 Answers
SOURCE: Threading my sewing machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Aug 27, 2008
SOURCE: bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Posted on Jan 23, 2009
Michaelle
  • 65 Answers
SOURCE: need help to thread our sewing machine.
you really must get a manual for this machine.
You can find manuals online for a small price.
At one time some sites had them for free, but I haven't been able to find many recently. sewusa.com has some older ones for free. but not many. you could try the kenmore site as well, if not I'd try to search on dogpile.com (sewing machine manuals)
Just so you know, your manual is the MOST important tool for any sewing machine, and its worth a couple of bucks to get it.
Posted on Jan 24, 2009
How to thread my Jones 781 sewing machine
I can't find threading info for your machine, but your Jones looks a lot like a Kenmore. The threading should be very similar:
14 Kenmore Top Threading FREE SAMPLE
How to Thread Kenmore Sewing Machine
Your machine is similar to a lot that were made from about the late 1960's through the 1980's.
Jul 18, 2018 | Sewing Machines
Kenmore sewing machine model 158.905 how does the bobbin and bobbin cqse go back in?
Sears carries manuals for most of their machines (usually for free). The manual is invaluable for using your machine, including threading instructions.
Kenmore 158 1792 Sewing Machine Threading Diagram
May 02, 2017 | Kenmore Sewing Machines
Why is the bobbin thread being cut on bobbin after a few stiches? machine will sew a few stiches and this happens.
your bobbin is place in the wrong position and you need to tighten the stitch....adjust it a bit.....play with it till you get the desire result
Sep 11, 2014 | Singer Sewing Machines
Singer 522
Hi . try adjusting the tension screw on the bobbin case on the thread tension leaf . tighten it slightly just enough that the thread needs needs a little bit of nudging to come out . do the same for the thread coming through the needle . this should help .
Sep 12, 2013 | Sewing Machines
1960s Elna Supermatic - lower thread only catches sometimes
Make sure you have the correct needles for this machine and that it is fully inserted into the needle bar and correctly oriented.
Mar 20, 2013 | Sewing Machines
When iam stiching the bobbin thread is not interlocking with the pool thread ,the straight stich is not stiching properly
Do you have thread in your bobbin?
Is your needle fully inserted in the needle bar?
Is it the right needle for the machine?
Is your needle damaged, bent or dull?
Jul 26, 2012 | Singer 7470 Computerized Sewing Machine
Sewing Machines Logo
116 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
