Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Runs for a while then quits if i change plugs runs for while then quits weed eater sst 125 almost new
  • 157 Answers
Sounds like the carbarator mixture needs adjusting its flooding the plug
Posted on Sep 18, 2009
My murray m2510 gas weed eater runs at idle but when i go past fast idle it wants to die. i put a new spark plug in it, it didn't change. what could be the problem? it started doing it last fall.
Sounds like fuel problem. You may want to check the vent on the fuel tank. It can get clogged and won't provide enough fuel to run at higher rpms. I'm not familiar with that engine, but its a problem I've had in the past with weed eaters and chainsaws.
Apr 07, 2016 | Fast Garden
Engine tm251 sst lawn mower weed eater won't start?
Start with changing the spark plug. They love to eat plugs.
Nov 05, 2013 | Garden
I have a WEED Eater Model SST 45. I left the switch on all winter and now it won't start. What is wrong?
If it is a pull start, leaving the switch on did no damage to the weed eater.
Gary
Jun 29, 2011 | Garden
My weed eater starts but won't stay running. what
Try a new spark plug.Thanks for asking and I hope it helps
Jul 19, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Having a problem starting my Shindaiwa T22 Weed Eater.
take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
May 02, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
I have 2 weed eater brand weedeaters 18cc Featherlite and when i use both of them after a while they quit running ! I am using the correct fuel/oil mixture and i have changed the plugs and checked the air...
Possible coil break down. These cheap weed eaters only have a life expectancy of about 50 hrs Plus or Minus. You can buy new for less that it cost to repair them.Sorry that's the facts.
Oct 21, 2009 | Poulan Garden
Craftsman weed eater wont run
MAKE SURE YOU REPLACE THE CARB GASKETS. ALSO MAKE SURE YOU ARE USING FRESH FUEL WITH THE RIGHT MIXTURE. COMPRESSION SHOULD BE AT LEAST 90LBS
Sep 24, 2009 | Garden
Trot Bilt 4 cycle weed eater catches, but wont run.
rebuild carb to fix problem.let me know if this help you.ok
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Carburetor adjustment weed eater fl sst 25,will only run if held 90% to the right.
My machine didn't run idle either. Took carburator apart of the Sst 25. Cleaned it with gasoline and a brush. But no luck. Figured it must be the nozzle of the idle. There are two more or less hidden black adjustment screws for the nozzles (idle and gas). I used a plastic tube from a ballpoint to take screw out, ran some air through it, reassembled it and now the machine runs smooth again...
Apr 22, 2009 | Garden
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
246 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
