Question about Samsung SGH-t609 Cellular Phone
Stuck in search mode
I have a t609 and it is stuck in searching mode with a phone with a line through it at the top. can't dial out can't get calls. please help! thanks disco99flav
email-disco99flav@yahoo.com
  • morandymo Nov 28, 2008
    I do have the same problem...stuck in search mode...no phone calls or text messages. sometimes I get random texts or calls, but can never dial or send out. I have searched for networks under settings and when it finds t-mobile, it always fails during registration. gonna have to go into a store, I think...
How do i unlock my sam sung tmobile phone to work in GUYANA wen it is say wrong sim.
Posted on Jan 14, 2008
How to pick the call from other extensions
I have downloaded several manuals for the Avaya by searching online, some are good basic user guides and some very technical. You can pick up a call in several different ways - here is a copy from the manual on call pick ups:
2.2.2 Call Pickup
If you hear another phone ringing, there are a number of ways that you can answer the call if you know the user, group
or line being called.
1.If already on a call, end the call by pressing Drop or put it on hold by either pressing Hold or pressing the
button which the call is on.
2.Press an idle Intercom or Call Appearance button.
· To pickup a call ringing at a particular extension:
Dial 6 followed by the extension number at which the call is ringing or parked.
· To pickup the longest waiting call in a pickup group:
Dial 66 followed by the pickup group number (1 to 4).
· To pickup the call ringing on a particular line:
Dial 68 followed by the two digit line number.
3. You can continue the call handsfree or switch to using the handset or headset (press the HEADSET button).
To Create a Call Pickup Button (ETR 18D/ETR 34D Phone)
1.At the phone press Feature 00.
2.Program Extension: is shown on the display.
3.Press the button that you want to edit or enter a number between 03 to 80 to select a button. The current setting
of the button is displayed.
4.Press the first intercom or call appearance button.
5.Dial 6 followed by the target extension number.
6.The button function is changed to Call Pickup followed by the target extension number.
· Exit programming by pressing Feature 00. You can also exit programming mode by lifting the handset, then
placing it back in the cradle.
To Use a Call Pickup Button
1.Press the Call Pickup programmed button
May 29, 2014 | Avaya Corded Phone avaparp18d
Need to know how to fax from mcf 210c
How to enter Fax mode
Before sending faxes, make sure (Fax) is illuminated in
green. If not, press (Fax) to enter Fax mode. The default
setting is Fax.
How to dial
You can dial in any of the following different ways.
Manual dialing
Press all of the digits of the phone or fax number.
Setup Send
3 - 2 SETUP SEND
Speed-Dialing
Press Search/Speed Dial, #, and then the two digit Speed-Dial
number. (See Storing Speed-Dial numbers on page 5-1.)
Search
You can search for names you have stored in the Speed-Dial
memories. Press Search/Speed Dial and the navigation keys to
search. (See Storing Speed-Dial numbers on page 5-1.)
* To search alphabetically, you can use the dial pad to enter the first
letter of the name you are looking for.
Fax Redial
If you are sending a fax manually and the line is busy, press
Redial/Pause, and then press Black Start or Color Start to try
again. If you want to make a second call to the last number dialed,
you can save time by pressing Redial/Pause and Black Start or
Color Start.
Redial/Pause only works if you dialed from the control panel.
If you are sending a fax automatically and the line is busy, the MFC
will automatically redial one time after five minutes.
If the LCD shows Not Registered when you enter the
Speed-Dial number, a number has not been stored for it.
Color fax transmission
Your MFC can send a color fax to machines that support this feature.
However, color faxes cannot be stored in the memory. When you
send a color fax, the MFC will send it in real time (even if Real Time
TX is set to Off).
Nov 02, 2011 | Brother MFC 210C All-In-One InkJet Printer
I canot hear it ringing when anyone calls. there is a dial tone,and i hear it ringing when called from another line but no ringing on my end
Because you said you have a dial tone I'm guessing that this is a land line (home) telephone. Make sure that the ringer volume is turned up. You may have to search for it but it is located somewhere on the phone. Plug another phone into the same jack and if this unit work replace your phone(very cheap). Still not working then you may have a defective phone cable which must be replaced.
Hope this help with your problem.
Jan 07, 2011 | Cell Phones
If I enter the phone number and then press "talk", the numbers dial extremely quickly, a dial tone comes on, and I have to enter the numbers again. How do I fix this? It is a Vtech 6.0 DECT.
Usually there are two modes provided to all fixed line telephones. Tone mode and pulse mode. Pulse mode will dial the call slowly and Tone mode will dial calls quickly. Your phone is in Tone mode i guess. You need not dial the numbers again. Wait for few seconds and the call will get accomplished!
Aug 01, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
One of my phone is stuck in search mode what do i do it i a vtech 6772.It is a three phone combo other two phones work fine
HI, To switch back to tone dialing, hold down the SELECT button for couple of seconds. The display on the base unit will read PU indicating pulse dialing. Now press and hold SELECT to change it to TN (Tone dialing).
thank you,
vijay
Sep 29, 2009 | Vtech Two Line Digital Answering Machine...
Need to unlock samsung t609 to work with my at&t sim card is this possible
Hello Justme12345,
I worked in the Cellular industry, and will have to say yes. I have unlocked phones from both providers and they will work either way once unlocked. You can search for unlocking software and do it yourself, or find a local shop that will unlock it for you for a nominal fee.
Good luck.
Feb 28, 2008 | Samsung SGH-t609 Cellular Phone
Calls being dropped / Searching for network after returning from sleep mode
Surely you have had it for less than a year. Call your local support agent by dialing *611(verizon) or whatever number you use to access your customer support, tell them that the radio in the phone is defective and drops calls. Request them to warranty the phone by manufacturer. They will send you a new one in a box with return instructions. Fill out any information and ship your phone back. Before you do so there may be an agent of your wireless carrier in the area. Visit the store to have information transferred to your new phone.
Jan 07, 2008 | Motorola Mobility MOTORAZR maxx V6...
Cybershot dsc-w70 stuck in video mode
Ok! I've searched and searched, so hopefully this will help you all out.
If the videos are very slow moving, you're in multi burst mode. Simple fix, actually...
Press menu button that's below the dial selector. There should be two small options near the bottom of the screen "mode" and the little suitcase.
Go into mode and make sure that Normal is selected. Multi Burst is actually a 16 frame per second function good for sports. It shows as a slow motion video on the camera and a sort of collage on your computer.
Hope this helps. :)
Nov 30, 2007 | Cameras
How to switch phone to tone
I found a manual from AT&T that had the information I needed. Thanks!
Sep 18, 2007 | GE 26920 Cordless Phone
Samsung SGH-t609 Cellular Phone Logo
107 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
