Saeco Odea Go
Problem for Saeco Odea Go
My Saeco Odea Go will not start.
By jonno_1_1 on Sep 11, 2009
My Saeco Odea Go will not start. When I press the powerbutton nothing happens. The electic court is properly jacked in to the wall and the other end is properly attached to the machine. Still it seems totally dead. We made a coffe a few hours ago without any problems. We might have left the power on after that coffee, I'm not sure. Could that break the machine in some way? In that case, what would be the solution for fixing that? Or what do you think could cause this problem?
Regards,
Jonno
Solution #1
posted on Sep 12, 2009
Not Rated)
EspRoastTech
Rank: Guru
Rating: 94%, 78 votes
It could be a few things. Could be a loose wire on the inside that came undone. It also could be the high limit thermofuse kick off in the machine to protect itself. Worst case it could be the electriconics themself. Doesn't sound like it, but you have to look at every possible angle.
If its still under warrenty you can rma it, if not you have to send it in. Reseting the high limits on the newer model machines is alittle bit of a headache and should be done only by a certified saeco tech.
Why does it happen? If you leave the machine on for elongated periods of time and the boiler evaporates all of the water, to protect itself, the high limit thermofuse pops to stop the boiler heating elements from heating up. Think of it like an emergency kill switch. It shouldn't cost much to reactivate them if that is the problem, its just the hassle of getting into the machine.
Saeco in the future may find an easier method of reseting the thermofuses, hopefully an external solution so we don't need to open the machine up every time.
Was this helpful?
Yes
No
Popular Solutions for Saeco Odea Go
Questions and Unsolved Problems for Saeco Odea Go
Do you recommend Saeco Odea Go?
Answer
Answer
I have descaled my Saeco Odea and the coffee beans light and the descaling light keep on flashing... (More)
Answer
Instead of brewing espresso, hot water comes through the spout. I've cleaned the brew group... (More)
Answer
thw lights are flashing in an alternating style and I cannot get them to stop. I have cleaned and... (More)
Answer
I can't remove the brew group from the machine.It seems to stick at the top of the brew group even... (More)
Answer
the exclamation point to the left of the dial continues to flash in red
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
in , CA
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
