Question about HP PSC 950 All-In-One InkJet Printer
Need to print 2x2 pics for passport photos using a canon camera and a HP printer. can you help with set up?
If I want to copy & paste from the internet my Canon Pixma MG3200 only prints the size of a postage stamp on A4. It used to be OK. What's wrong with my settings?
Default setting on printer itself must be set to passport photo size if from a computer go to devices and printers and look at printing preferences check paper size
Jan 08, 2015 | Canon Office Equipment & Supplies
I have lost my camera book and need help .when I try to print pics at Walgreens computer will not load pics.it says no photos available.but I can take pics fine and look at them on cf card in camera b
You may download the manual and more from here.
Are you possibly shooting pictures in RAW format? Photo kiosks such as those at Walgreens won't recognize Canon RAW photos, only JPEGs. Check the camera's image quality settings, as described beginning on page 60 of the manual.
Nov 14, 2012 | Canon EOS Digital Rebel XTI Digital Camera
How do i set the time on the pic after the shot to display on the pic when downloaded
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Nov 14, 2010 | Canon PowerShot S3 IS Digital Camera
My Canon digital camera puts the date and time on the photo, but when I sent away for prints (used Kodak.com) the prints were just stamped with the day the print was made, not the date the photo was taken....
When you download the pics to your computer and view them, is the date and time on the pics then? If not, then your camera is not including the info on the pic itself.
Feb 18, 2010 | Canon PowerShot A540 Digital Camera
Bad yellow cast to photos when printed
If you have a yellow cast to your photos, the problem might not be your printer. If you're using a digital camera, indoors under incandescent lighting without a flash your pictures will look yellow.
If this is the case, set your camera's White Balance to Incandescent lighting or use the flash. If all of your pictures, even those taken in daylight, look yellow you'll have to adjust the colors on your printer using the "toolbox" software that comes with it and back the yellow off. I've found that HP printers tend to have better color rendition than Canon.
May 24, 2009 | Canon Office Equipment & Supplies
How to print diferent sizes using Pictbridge on HP 7850
What model camera are you using? Normally, once connected, unless the camera has settings for print size and other options the printer will print whatever the default size is.
Oct 16, 2008 | HP Photosmart 7850 InkJet Printer
Resolution
ussually your shuold be able to print even the large files, or the printer you might have does not support photo printing in high quality
Jul 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Horrible print quality
hi i am a certified Canon repair tech for this printer. the first problem is the paper you are using hp photo paper is specialty formulated to be used with there inks. every manufacture is the same if you want the proper looking photo and you are using a Canon printer you need to use Canon photo paper because the paper is formulated for their inks. hope this helps to clarify.
Jan 04, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
RE PRINTING OUT AN IMAGE FROM MY BROTHER MFC-215c PRINTER
Neither nor do I press any of these buttons because you can print by help of the photo assistant of windows which will give you a hand.
Simply right click the picture on your pc and click printing. The assistenat will lead you thru the settings. You only have to make sure that your mfc is the chosen as the printer AND you havte to click the printer properties afterwards. The brother printer properties will let you choose the paper size (simply click the offered sizes and have a look at the left side of the window where a small pic can be seen. Beneath the pic you will find the explanation for the choosen setting e. g. borderless/ 4x6 inch etc.) choose the right paper like glossy for photo paper. When done click OK and leave the properties. Click further through the windows assistant and choose the resolution of the picture. Click OK and machine will print the desired pic ;-)
BTW you can do some very smart thing:
print a poster of 2x2 A4 or 3x3 A4 sheets of paper. You can set this size within the printers properties.
Have a look at the manual for further info ;-)
Dec 06, 2007 | Brother MFC 210C All-In-One InkJet Printer
Printing photos onto 6x4 inkjet paper
which is the model of the printer, not all the printers permite to you do this
Oct 30, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 950 All-In-One InkJet Printer Logo
874 people viewed this question
Seeker5211
Seeker5211
