Question about Seagate Barracuda 7200.7 40 GB Hard Drive
Hdd warrantty i bought seagate hdd on last year now i problem in hdd. the problem is that when cable attached to hdd then monitor display off and bad smell from hdd.i checked warrantty of hdd from online but it diplay 'out of warranty'. so, pls help me.pls....solved my problemthanking u in anticipation
  • 558 Answers
It would seem that your hard disk is about to die.if you have data you want to retrive you can place it in a double ziplock bah place it in the freezer for a couple of hours this will give you some time copy what you may need until it stop working.if not you can try a data recovery company.
Posted on Sep 12, 2009
Testimonial: "nice "
Pink and Green Horizontal lines across screen
Normally, horizontal lines on an LCD or LED monitor indicate a bad control board inside the monitor. However, occasionally the problem can be caused by loose or bad cable connections. The only things that you can really do is to disconnect both ends of the monitor cable and reconnect them firmly. Also, you can disconnect the monitor cable completely and just leave the power cable. With only the power cable attached, you can turn the monitor on and off. The monitor should have a "startup screen" or display a message that says something like "Video Cable Disconnected". If the green and pink lines are still present without your computer connected, then the monitor has gone bad. The good news is that Samsung SyncMaster monitors usually carry a 3 year warranty, whereas most monitors only have a 1 year warranty. You may be able to have the monitor replaced at no cost to you if it's less than 3 years old.
Jul 27, 2013 | Samsung SyncMaster Computers & Internet
Hi, I have got a problem with my Seagate free HDD 320 GB, I lost my original USB cable bought with the Hard drive, then I bought another USB common cable. I tried to connect it prompt the following: Light...
Start -> Run -> devmgmt.msc. Check any yellow marks or explainary marks or red x marks. Right click on that and UPDATE driver.
If not working, please try with another NEW cable..
Jun 17, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
I have plugged in seagate 250 GB seagate expansion portable drive into windows 7 but the disk is not detected. Can you help me how to resolve this ?
be sure power is supplied to the HDD, if and inter HDD change the cables, if is external check the USB cable and see if you need a complementary power brick or a second USB to power it.
Mar 17, 2011 | Seagate Computers & Internet
The monitor will display fpr 4 to 5 seconds and turn black! bought a new cable and still does the same thing. Bought monitor in may of 2009. should last longer then 1 1/5 years!!!!
There two boards that give trouble, the power supply board, and the inverter board that energizes the back lights behind the screen, failures are usually caused by bad capacitors and in some cases bulge at the top. To repair will need a service center and I recommend an estimate.
Feb 02, 2011 | Hannspree HW191D LCD Monitor
I have Seagate HD 500GB (Internal) and my PC configuration is Intel i3 Processor with 2GB RAM, 1GB Nvidia Graphic Card and 250GB HD(Internal) in which OS is loaded. I'm facing a problems as...
Your problem is very clear... The HDD has got bad sectors in it and that is the cause for the Sneak sneak sound...
This causes your HDD to not get detected under bios in most of the situation and this is the root cause for all the problems stated above...
Here is the solution:
It is not possible to do any kind of service from your end...
It has to be sent to a seagate service center to get serviced...
Mostly they will never service the HDD, they will replace it with a new one...
All the seagate HDD comes with 5 years warranty...
you can opt for replacement...
search in google for an authorised service center located in your locality...
Dec 18, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Hdd power problem
Hi!
Check your HDD with HDD monitor utility to see if it's ok. You can try this one:
http://www.techsupportalert.com/best-free-disk-health-monitoring-utility.htm
If your HDD has bad SMART or power controller or smth like that - then you definitely need to replace HDD.
Also issue may be caused by your PC power supply or motherboard power controller. If HDD monitor shows that your hard drive is "alive", then try to "hang" your HDD to another power cord from your PC power supply and try to connect to other IDE/SATA port on your motherboard.
Also I'd suggest you to try your HDD on any other PC.
Jul 02, 2010 | Seagate (9W2892-337) 80 GB Hard Drive
Computer powers on and runs but it will not post hhd in BIOS. any help?
Shut down you're system. Open you're case and double check the power cable and data cable from hdd to motherboard. (Disconnect both cables and re-connect both). Make sure the cables are fully inserted. Power up the system and enter the bios. The hdd drive should be listed. If not replace the data cable with a new one and check the bios again.
If you have two hdd, ATA IDE drives connected, make sure that each hdd is jumpered correctly. One set to Master with a slave.
The second drive should be jumpered as a slave.
If you're running 1 hdd make sure the hdd is jumper as a Master without a slave. There is a sticker on the hdd to help you set the jumper correctly.
If the bios still does not see you're hdd than either the hdd is bad or the motherboard controller is bad.
To check if the hdd is faulty, check the sticker on the drive. Find the manufacture's name and model. Google the manufacture's name. Every manufacture provides free software that will test and repair the drive by allowing you to create either a bootable floppy disk or bootable CD disk that runs in a DOS like window. Example: For a Seagate drive you would download SeaTools for DOS. Instructions are listed on the site; http://www.seagate.com/www/en-us/support/downloads/seatools
Seagate also supports Maxtor drives using the same software.
Cheers'
Mike
Apr 08, 2010 | HP (D7580-60003) Motherboard
External HDD is not detecting
Below is the address of Seagate Service center in Bangalore.
ACCEL Frontline Ltd, No: 18/8,
Saleh Centre, Cunnigham Road,
Bangalore - 560052
Karnataka.
Ph: 080 66279903
You can reach them online @ http://myservice.accelfrontline.in/WRMS/
Regards
Manish
Apr 07, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
SATA ports don't work
Thank you for using fixya. And I'm glad i could help.
Feb 01, 2009 | ASUS A8R-MVP Motherboard
Monitor Problems
Borrow a DVI cable from some friend and test it, just in case.
If you want to use multiple monitors, ensure you are using the right settings. Go to control panel>> Display,
open the Display properties box, click the last tab at the top right hand corner, and chose advanced see here for XP, Vista is similar:
Windows XP: Learn how to expand your workspace with multiple monitors
Sep 09, 2008 | Dell E207WFP LCD Monitor
Seagate Barracuda 7200.7 40 GB Hard Drive Logo
160 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
