Question about HP LaserJet 4L Printer
Error message "50 service" showing in message window. What does this mean, and where can I get service?
    President:
  • 1,653 Answers
1. Remove power to the printer for 15 minutes. If this doesn’t clear the error:
2. Perform the Fuser Checks shown in the table below.
3. Check the Fuses (FU101 and FU201) on the DC Controller PCA. Replace if faulty.
3. Replace the DC Controller PCA.
SUSPECT
CHECK
1. Connector
Contact Ensure that J103 and J204 connectors on the Fusing Assembly are seated securely into the DC Controller PCA connectors. Reseat the Fusing Assembly,
2. Thermistor wire open.
Remove the Fuser and measure the resistance between connectors J204-1 and J204-2, Resistance
should read approximately 440 K Ohms at 20 Deg C (room temperature). If the thermistor wire is open, replace the Fusing Assembly.
3. Thermal Fuse.
Measure the continuity between connectors JI 03-1 and J1 03-2 on the Fuser. It should be approximately 29 Ohms. If the thermal fuse is open, replace the Fusing Assembly
Posted on Sep 11, 2009
3 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: Message: 50 service ??? what does it mean?
Please see this thread, and the link within it.
However, there are other posts that indicate this error could be temporary and suggest possible workarounds. See here and here.
For the complete list of error codes for that machine, see here. If you need manuals or other resources for that printer, see the home support page here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 26, 2009
skipsinclair
  • 152 Answers
SOURCE: error code: 50 service. What does this mean??
Blown quartz fuser lamp. Replacement kit available here for about $40.
Posted on Oct 21, 2009
The printer is HP LaserJet III . Please - what means the message "50 service " on the panel ? Thank you! MP
A 50.4 code is bad line voltage. Don't plug it in a surge protector.
Any other 50 error is a fuser problem. Turn the printer off for at least 10 minutes. Power it back on. If the error returns, replace the fuser.
Oct 21, 2010 | HP LaserJet IIIp Printer
Hello; My Omron HEM 712C shows message: EE Can
'EE' means cuff is underinflating. Re wrap cuff with varying amounts of pressure and restart [wait 2 minutes between readings].
Dec 15, 2009 | Omron Hem 712CLCN2 Cuff Blood Pressure...
Down load the user manual. from my memory its got the codes in it.
Aug 26, 2009 | HP LaserJet 4 plus Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Message window says "transmission service required" whats it mean
If it says to service it, then it needs servicing.
Feb 24, 2009 | 2001 Volvo S60
Ntdlr error messages
If your pc is showing a error before starting windows it means your system is corrupt or damaged. This can be fixed with chkdsk or a repair windows install or a clean windows install.
That is something you cant prevent from showing. It will always come up when there is a problem with the operateing system.
Feb 17, 2008 | Systemax Neotach 3300 Notebook
50 service problem
Please try below solution.
ERROR 50 - Service
A 50 service error can be either a temporary error or a permanent problem requiring service.
Temporary Error: Power off for 20 minutes to allow the capacitor on the DC controller to fully discharge. If you don't allow this capacitor to discharge, you will still get a Error 50 even if you have fixed the problem.  This may clear the error - either temporarily or permanently. If it clears the error it was most likely caused by a low power problem  i.e. low line voltage causing the power supply circuits to drop out of regulation. Low/unstable power (low line voltage, brownout condition).  If it doesn't clear the error you may have one of the problems listed below
On the HP LaserJet 4L/4ML, errors are indicated by a series of indicator lights.  This printer has four lights, Paper Jam, Paper Out, Data, and Online.
If all four lights are on, press and hold the blue panel button to display a secondary light pattern.
An error 50 is indicated by the ready and error lights with the blue panel button pressed.
Turn the printer off for 15 minutes to see if the error clears.  If not, you will need to remove the fuser assembly to perform further checks.  This requires removal of the cover, an unpleasant task, and measurement of the fuser terminals.
Note: THERE ARE FURTHER STEPS TO CHECK THE ISSUE, HOWEVER IT IS NOT RECOMMENED TO CHECK USING YOU  ARE A USER, FURTHER STEPS NEED TO BE DONE ONLY IF YOU ARE COMFORTABLE AND INVOLVES MECHNICAL ISSUES OF PRINTER.
For your convienience, I will would like to provide the web link that shows the picture of the scene
link is:
http://www.fixyourownprinter.com/reference/guides/fuser/ex
try the things that are mentioned in web link. If the issue persists, then Printer needs to serviced.
I hope that this should resolve the issue for you.
If you need any further assistance, please let me know. I'll be glad to help you.
Bye.
Oct 18, 2007 | HP LaserJet 4 plus Printer
Printer message: Unable to Print
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Aug 27, 2007 | Brother MFC 420CN All-In-One InkJet...
Fax machine error
HI,my fax machine couldn't send and receive messages.it shows me an error code that read as 0552H call service....what does it mean..? please help me.
Jan 29, 2007 | Ricoh FAX5510L Plain Paper Laser
Error message on startup
The fuser unit could be the causes. But you can try this, power off the printer & unplug the power cord for 15 to 20 minutes. Power on after 20 minutes and se whether the problem resolves, if it ok, monitor it for a while just to make sure the problem resolves
Nov 20, 2006 | HP LaserJet 4 plus Printer
HP LaserJet 4L Printer Logo
118 people viewed this question
Seeker5211
Seeker5211
