Question about Frigidaire Electric Dryer
Remove the back and replace the terminal block
  • computgeek4u Sep 14, 2009
    What is the easy way to remove the back of this dryer and replace the terminal block?
  • yadayada
    yadayada May 11, 2010
    what is the question here?
  • 1,531 Answers
You should not have to remove the back panel to replaced the terminal block.just a small acces panel held by a screw the two screws hold the block in place.
Posted on Sep 17, 2009
Replace worn electrical cord
Terminal block is fastened/secured with body by a screw but before removing the terminal block from body, make sure that the iron element terminals are also disconnected. this can be done by opening the screws on other side of the cord terminals-3 in number as also in the cord. Otherwise the terminal block would not come out fully.In any case you normally do not need to remove the terminal block.
Apr 05, 2012 | Tefal Irons
Need to replace 4 prong cord with a 3 prong cord on a new 500 series dryer.
On the back of the dryer, remove the screw(s) that hold the access cover to the back panel that cover the terminal block where the cord goes through the back panel and connects to the wiring terminal power block, loosen the two screws on the cord clamp the clamp it to the back of the dryer just enough to release the cord, remove the four nuts / screws that are connecting the 4 wires from the cord to the terminal block and or the back of the dryer,with the new 3 wire cord just match the colors on the terminal block with the same color wires that are connected to the other side of the terminal block, red,black on the outer most terminals and the white or green to the middle terminal, IT IS IMPORTANT THAT YOU PLACE A JUMPER WIRE/STRAP FROM THE MIDDLE TERMINAL WHERE THE WHITE OR GREEN WIRE CONNECTS TO THE TERMINAL BLOCK OVER TO THE CASE/CABINET OF THE DRYER, THIS CAN CONNECT TO THE CASE AT ANY AVAILABLE SCREW NEAR THE TERMINAL BLOCK! In short this means that the neutral and ground of the dryer must be connected together in a 3 wire set-up.
GOOD LUCK!
Aug 21, 2010 | Kenmore 500 6952 Dryer
The dryer is working but when you touch the dryer it feels like it is not grounded
Unplug unit ..Remove axcess panel in back covering terminal block ,check and make sure all terminals are thght esp, the one in the middle (white) if three wire power cord .. If 4 prong power cord make sure middle( White wire) neutral is tight and Green wire (ground is tight to chassis frame...If still a concern you may need to replace the terminal block in the dryer or you may need an electrician to replace the receptacle or a issue in the breaker panel......
Aug 15, 2010 | Whirlpool Dryers
Replacing power cords
The following link explains how to install either a 3 or a 4 wire appliance cord:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
The main difference is how the Neutral (White) and Ground (Green or Bare) wires are termianted. In a 3 wire configuration these two wires are termianted together at the terminal block. In a 4 wire configuration these two wires remain independent of each other. Neutral is terminated at the terminal block, while ground is terminated at the equipment cabinet. If there is a jumper wire or ground strap between the two, remove it.
If you have questions, please post back and let me know. I hope this helps you.
Feb 07, 2010 | Kenmore 62882 Electric Dryer
Wireing thee wire to four wire,small metal tab between ground and middle wire.?do I take it off?
If you have a 3-wire appliance and you are replacing the 3-wire cable with a 4-wire cable, yes, you _must_ remove the metal tab (bonding strap) that is connected from the white wire on the terminal block to the frame.
Connect the black, red, and white wires to the terminal block, then connect the green wire to the frame using the green screw.
Usually the bonding strap stays under the (green) screw without being connected to the terminal block so should someone need to connect it back to a 3-wire cable the bonding strap will be there.
Jan 13, 2010 | General Electric Stove/Oven/Range Chrome...
Plug does not go into outlet. Three blade plug with one "J" shaped blade. The outlet has three straight hole to acommodate three straight blades.
Replace the power cord to accomodate the outlet you have. You can purchase them at any hardware store for about $20. This is the easier option than trying to replace the outlet. To replace the cord follow these steps:
1. Remove the access cover on the terminal block on the back of the dryer. This is where the existing power cord is installed.
2. Remove the existing power cord from the terminal block.
3. Remove the power cord restraining clamp (if equipped). This secures the power cord at the entry point on the back of the dryer and prevents it from stressing the terminals and prevents chaffing of the outer insulation on the power cord. NOTE: Its a good idea to have this installed for safety reasons.
4. Remove the old power cord and install the new one following this color scheme at the terminal block:
RED (Hot) - 120VAC
BLACK (Hot) - 120VAC
WHITE (Neutral) - 0 VAC - Should be connected to the terminal block and grounded to the equipment cabinet via a grounding strap.
NOTE: If the power cord or wires at the terminal block are not color coded, the outer two wires (LEFT and RIGHT) are the two hot leads. The center conductor is Neutral.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Dec 22, 2009 | Dishwashers
How to switch out the battery
Remove Negative terminal first, then positive terminal. Battery will have some type of tie down or block at base with a bolt you will have to remove. Remember how it goes back together. Remove battery.
Install new battery and tie down or block. Install Positive terminal then Negative terminal.
Remember to never touch both Positive and negative terminals with a metal object (ie..ratchet, wrench etc) this can cause injury and/or permanent damage to a new battery.
Nov 27, 2009 | 1995 Eagle Vision
Have an old maytag dryer and need to replace 3 prong cord with 4 prong. How do we attach color coded wires?
First make dryer is unplugged !!!!!!!!! remove cover near cord entrance to dryer, you will notice 3 terminals. you should also see a green screw close by. there may be a wire or strap connecting center terminal to the green screw or ground. remove wires from terminals and remove strap from center to ground screw. connect new cord in the following order. green wire to green screw or ground, white wire to center terminal, black wire to left terminal, and red wire to right terminal. now you are done put the cover back on. I'm glad you asked this question. this is a very popular question. Your new 4 Prong cord is up to current code. I'm happy to see people updating there appliances to current code and making their homes safer. Thanks
Aug 29, 2009 | Dryers
My Whirpool dryer model LXE 7400 WO doesn't
Unplug the dryer.
Remove the back panel.
Inspect the wires at the terminal block where the cord connects.
With a volt meter set for continuity check the thermal fuse on the heater canister(up high). No continuity , replace it.
Check the hi limit thermostat at the heater terminals, no continuity , replace it.
Check the heater terminals for continuity. If none replace the heater.
Remember to remove at least one wire from each part before testing.
Feb 22, 2009 | Whirlpool Dryers
1999 Saturn SL2 Electrical Problem--Help!!!
Hopes this help, found answer on Saturnalia
http://www.saturnfans.com/forums/showthread.php?t=135171
If your mechanic has a schematic or looks in the owners manual and checks the loads listed for the IP BAT fuse in the UHJB and they are all dead then its the F-5 connection. The fuel pump is a direct feed from the IP BAT to F-5 to the fuel pump relay. the fuel pump fuse is on the other side of the fuel pump relay.
It covers exactly what I am trying to tell you. Check the IP BAT loads, if all dead, fix F-5 and if the internal wire is burned open replace the I/P panel.
File in Section: 08 - Body and Accessories
Bulletin No.: 03-08-45-001
Issue Date: May, 2003
Subject:
Intermittent No Start, Intermittent Stall after Start-Up and/or Loss of Radio Presets (Replace Instrument Panel Junction Block - IPJB and/or Terminal)
Models Affected:
1995-1999 Saturn S-Series Vehicles
Attention: Technician
Condition:
Some customers may comment that one or more of the following conditions has occurred.
^ Intermittent no start
^ Intermittent stall after start-up
^ Loss of radio presets
Cause:
Condition(s) may be caused by terminal tightness at PIN F-5 within the Instrument Panel Junction Block (IPJB Black 68 way).
Correction:
Refer to the Instrument Panel Junction Block (IPJB) and/or Terminal Replacement procedures in this bulletin.
Procedure:
Instrument Panel Junction Block (IPJB) Removal:
1. Disconnect negative battery cable.
2. Disconnect positive battery cable.
3. Remove left and right lower trim panel extensions by pulling outward at dual lock locations. Rotate panels outward to disengage hinges from console.
4. Remove screw and ground wire from H-bracket.
5. Remove wiring harness from H-bracket.
6. Remove screw and disconnect rear electrical connector from IPJB. Remove IPJB screw.
7. Using a small screwdriver, release lock tabs on IPJB and slide off of mounting tabs.
8. Feed IPJB through H-bracket towards front of car.
9. Inspect PIN F-5, circuit 402 on the Black 68-way connector of the instrument panel junction block for signs of arcing. If signs of arcing are present, replace IPJB and terminal. Refer to the IPJB Installation and Terminal Replacement procedures in this bulletin.
10. If no signs of arcing, verify terminal tightness using GRAY probe. Replace terminal using the Terminal Replacement procedure in this bulletin.
IPJB Installation:
1. Feed IPJB back through H-bracket.
2. Slide the IPJB into mounting tabs and lock into place.
3. Install rear Black 68-way electrical connector into IPJB and then install screws in connector into IPJB.
4. Reconnect wiring harness to the H-bracket.
5. Reconnect ground wire to the H-bracket.
6. Reinstall left and right lower trim panel extensions.
7. Reconnect positive battery cable.
8. Reconnect negative battery cable.
Terminal Replacement:
1. If terminal replacement is required, remove CPA from Black 68-way connector. Insert tool 12094430/J04898 to remove terminal.
2. Put connector seal (if equipped) on wire.
3. Remove insulation from the end of the cut lead and the harness. Recommended strip length is 9.5 mm (3/8 in.) Caution must be used to prevent cutting the wire strands.
4. Position stripped ends in sleeve until wires hit the stop in the center of the splice.
5. Hand crimp using the approved crimping tool. Gently tug on wires to make sure they are secure before applying heat to them.
Important biggrin.gifO NOT USE MATCH OR OPEN FLAME TO APPLY HEAT TO SEAL.
6. Apply heat using the Heat Gun or some other device, heating to 175°C (347°F) until glue flows around edges of sleeve.
7. Insert the terminal into the connector. Check to make sure the terminal lock tab is engaged by gently tugging on the wire.
8. Replace any terminal position assurance (TPA) devices.
COMPLEMENTS OF: OldNucSuper Member reputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gif
Join Date: Apr 2008 Location: Far Southwestern Iowa Posts: 17,413
1998 SC2
Jul 31, 2008 | 1999 Saturn SL
Frigidaire  Electric Dryer Logo
131 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
