Question about Dryers
How much does it cost to replace the heating coil
  • Dryers Master
  • 8,220 Answers
Anywhere from 20 to 50 bucks
Start here
Posted on Sep 11, 2009
Why is my deep fryer not getting hot both the power light and the heating lights are on
Sounds like your heating coils are burnt out. It will cost more to repair than to replace with a new one.
Oct 07, 2016 | Kitchen Appliances - Others
Outdoor heatpump unit,twx736a100a2, coils freeze over solid,replaced outdoor thermastat, checked freon and replaced a relay switch at a cost of $500/for 2 service call-outs.It worked fine whole month of a...
Coils freezing due to dust blocked coils and or air filter or short of gas. Service your unit completely.Please do not change any spare/s without knowing exact problem. Please follow the steps given below.
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks. To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 04, 2011 | Heating & Cooling
My kenmore series dryer does not heat. the timer
the heater element has two parts to the heat coil if one of the coils breaks it will not get hot enough to heat the load all the way to set of the sensor to stop . it seems like you need to replace your heat element . if you want to know how to take it apart i have a couple of posts that tell how or reply back the coil costs about 89 dollars you can get one pre strung for around double the cost
Feb 25, 2010 | Kenmore 63942 Dryer
The drum goes round but there's no heat.
there is a heating element on the back wall and it looks like a spring closer on a screen door it is kinda flimsy and bends and warps as it cools and heats and sometimes it will rub on the drum or the back wall it shorts out and breaks a new coil costs around 80 $ takes a while to string through the ceramic holders you get some replacement holders to replace cracked or damaged ones with new coil. you can buy one pre strung it will cost allot more not an easy task for a first timer.
Jan 15, 2010 | Dryers
Need to know how much heating coil cost on my 70 series kenmore extra capacity dryer.
open dryer door and get model # 3 numbers a period and 6 more #s, they varry in price from $30.00 to $100.00
Dec 09, 2009 | Kenmore Dryers
How do you put the heating coil in? a 1994 isuzu rodeo? if i am not able to do it myself how much is the part and typicall cost to get it fixes
the heating coil for the heater consists of two screws and a plug usually located on passengers side near the firewall of the vehicle look for on top of the unit a plug unplug the wires and remove the 2 screws and remove the old heating coil and reinstall the new one and replace screws and re plug the harness wires
Oct 02, 2009 | 1998 Isuzu Rodeo
Power Light goes on but iron will not heat
If it is more than 3 years old (no warranty) then you can get it repaired or replaced. The heating coil is broken. The heating coil in the iron cannot be fixed, but must be replaced.
If the iron is less than 3 years old, you can get it repaired under warranty; however, shipping and other costs may not be worth having it repaired. (More than $30).
If you can get an estimate, you might want to have it repaired.
My recommendation? Replace it.
Sep 03, 2009 | Rowenta Irons
Dryer works but it is not heating up
If it is a gas dryer, theres a igniter in it that needs replacing
If it is a electric dryer, it commonly is the coil that is burned out
Cost Gas igniter approx $40.00
Coil $40-60.00
I hope this helps
Diamond Services
Apr 02, 2009 | Kenmore Dryers
Mobile home coleman - evcon furnace model EB23B vandalized. I think what is called the Evaporator coil?? (Copper A shape) was taken from the home. All that remains is the blower. Now...was the copper coil...
What a shame! An a coil runs about $500-$600 and an elec. heater kit about $100 plus labor and if the coils are missing then you Will have to replace refrigerant at $20 per lb.. I would replace the unit for about $1000 and then you'll have warranties on it. Sorry for your misfortune.
Sep 25, 2008 | Heating & Cooling
Dryers Logo
755 people viewed this question
Top Dryers Experts
