Water leaking under the bottom - Washing Machines
  • 65 Answers
Bad Pump or Pump hose, or dispenser hose has come off.
Posted on Sep 11, 2009
Water leak from the bottom of washer
Hi friend, thank you for your post!
I understand that water is leaking from the bottom of your Frigidaire washer. There are many components that could cause a washer to leak the bellow (gasket), leak from drain hose, drain pump, or water valve. Since it could be any one of these underlying issues I would recommend having a technician come out to diagnose and repair your appliance. Hope this is helpful. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
Looks like a leak at the bottom of engine
It is likely the water pump is leaking and the coolant is running back under the engine. Put you finger under the bottom of the water pump near the front where the shaft comes out, if it comes back wet with coolant the pump is leaking.
Oct 10, 2012 | 1998 GMC Sierra
Kenmore model #16761691 leaking at the bottom of the door. Where is the gasket located? Or is it another problem?
does it leak all the time or did it just start?try running it with nothing in it and see if it leaks,if the dishes were racked wrong the water can get deflected and leak out through the door,also,remove the bottom rack,look at the screws going around the bottom part under the wash arm,if any of those are loose it causes a wave in the dish washer and the water leaks from under the door.if it's leaking from one of the corners the gasket could be bad
Apr 17, 2011 | Kenmore Dishwashers
WAter leaking out of the bottom only during a large load
Look under bottom may be a hose or pump leaking Look around the hot/cold water inlets hoses May be coming from them and not the machine and running under the machine unplug it be safe
Mar 18, 2011 | Washing Machines
Water leaking into bottom of frezer,water frezing on bottom then leaking onto floor
defrost drain bottom rear of freezer is blocked . Defrost and clean drain tube.Poor water in trough at back under rear panel. If it drains out quickly then it is clear.
Oct 29, 2010 | Frigidaire Kitchen Ranges
Auto defrost works fine except for water accumlating in the bottom of unit under the bottom trays instead of in the water tray by the compressor. graywolf7499@yahoo.com
There is a leak or damage of the pipe leading from the evaporator downwards.The defrosted water is leaking out of the tubing to the bottom,replace this tubing or check the leak on the collecting tray under the evaporator.
Sep 30, 2010 | Whirlpool Refrigerators
Water leaking from under the freezer
Until defrosting the block of ice you canot see if is a hole or crack in the bottom. But I suppose is leaking from the door gasket under the pressure of the ice inside. Anyway, if you want to keep alife your refrigerator, better unplug it, defrosting and clean it before complete annihilation.
Sep 10, 2017 | Frigidaire Refrigerators
Water leaking into the bottom of frig. going under veggy crispers
Look for the drain trough on the bottom of the freezer and pour a mixture of baking soda and warm water down.
May 07, 2009 | Refrigerators
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Apr 18, 2009 | Refrigerators
Washing Machines Logo
119 people viewed this question
Top Washing Machines Experts
