Question about Everex StepNote VA4103M Notebook
After a second my laptop screen turns black
I turn on my laptop and it starts up like normal. After just a fraction of a second the screen goes very dark. I can see faint images of white on the screen, but that's it.
  • 44 Answers
Sounds like the back light on the LCD is going out or the invertor board is malfunctioning. In order to replace either you have to purchase the part and disassemle your lcd screen. I would suggest just purchasing the whole LCD panel and replacing it to be safe. If your system happens to be under warranty call tech support and have them replace it.
Posted on Sep 12, 2009
  • Everex Master
  • 13,433 Answers
Sounds like the inventer or the backlight is failing, the inventer doesn't cost much to replace.
You must be outside of warranty to have this problem, I'm not fimiliar with the Evorex laptops, never seen one over here In finland, take it to a local professional for a checkup I'm sure they will also be able to provide you with the parts needed. Get a repair estimate first.
Posted on Sep 11, 2009
HP screen goes black 5 seconds after ac adapter is plugged in or out
This may not be the ac adapter itself. the metal prongs on the side of your HP Laptop to connect to the wire of your ac adapter may be bent or shortciruited. try to get a replacement which may be hard depending on what type of HP Laptop you own. or you may just have to send it back if you dont know how, in order to avoid breaking the warranty policy by mistakenly damaging it.
Apr 18, 2013 | Computers & Internet
Y compaq pressario v2000 goes from black screen to intermittent normal screen. The black screen is on the computer 80% of the time and then the pics fade in and out
The screen on your laptop goes black after every few seconds.
It resumes after a mouse-click or after a key-press.
Solution
Click on Start --> In search bar, type power options and press Enter.
"Select a power plan" window will be opened.
Click on "Change plan settings" next to "Balanced (recommended)".
In "Turn off the display", select "Never" from the drop-down menu under both the options "On battery" and "Plugged in".
Now click on "Save changes" button.
hope this helps
Nov 20, 2012 | Computers & Internet
Acer 3610 screen goes black
It can one of many problems.(did anyone open it,does l/p get hot, is battery charging)
Plug in external screen
how did the problem start
need more information
May 06, 2012 | Acer Aspire 3610 Notebook
So my laptop froze yesterday and I turned it off to restart it. When I restarted it it everything was normal but after the starting windows goes away it usually goes to the login page well now all it does...
Try starting it in safe mode.
When the computer is starting just after the beep or when the bios info goes away press f8 repeatedly and you will get an option to open in regular or safe mode.
Alternativly you can also hold down teh ctrl key and it should do the same.
Did you install or update and drivers recently?
Aug 25, 2011 | Compaq Computers & Internet
Pavilion dv 1000 will turn on but screen turns
click start when the previous settings were working.
hope this helps
Apr 26, 2010 | HP Pavilion dv1000 Notebook
Black screen
• 1) TAKE OUT YOUR LAPTOP BATTERY
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
• 3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS.
That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen. After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
Replace your battery.
Restart!
Mar 02, 2010 | Dell UltraSharp 2407WFP 24" LCD Monitor
Used as second monitor suddenly stared to go dark
If the screen is lighting up for a fraction of a second when you turn on & then goes dark, this indicates a fault either with the backlights on the screen or the inverter part of the monitor. You can check the backlights if you have access to a backlight tester, you need to remove the rear cover & connect the backlight cables into the tester, if this checks ok then look for a problem on the inverter board, checking the capacitors for any signs of distress.
Aug 11, 2009 | LG W1934S-BN 19" Monitor
Gateway laptop mx3414-black screen cannot load windows
Try going into safe mode upon startup by hitting the F8 button. If it does then hit safe mode to get into your computer. Go to start>accessories>system tools>system restore. Follow the wizard to restore your computer to a date earlier than when you started having problems. Let me know if you have any problems or questions.
Mar 19, 2009 | Gateway MX3414 Notebook
ASUS F3S startup problems...
Have you tried doing a system recovery using the "hot" keys for the machine. Contact ASUS support for the instructions.
Apr 11, 2017 | ASUS R1E-B1 Tablet PC
Everex StepNote VA4103M Notebook Logo
59 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
k24674
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
