Question about Compaq 214799-001 ATA/ATAPI-4 9.4GB DVD-RAM Drive (214799001) (214799001) Burner
I can only use 8speed dvd rw when burning discs
    President:
  • 1,653 Answers
You are most likely suffereing what most of us suffer at some time in that various DVD RW will only work with certain types of media. You may find other 16x that will work but it may be a bit of experimenting required or searching various forums to see what other users have found to work. Also is the DVD drive that you have capable of 16x at write speed?
Posted on Sep 11, 2009
How to erase a dvd dics
dvd are read only.
dvd-r; dvd+r and dvd-rw are the re-writeable discs. mostly once only.
DVD Media Formats Explained
There are many different types of writable and rewritable DVD media on the market today. These formats include:
There are also "General Purpose" and "Authoring" discs. DO NOT confuse the "Authoring" media with the term for content development (making / editing what eventually goes on the DVD). The most common type of DVDR is the General Purpose type - if you do not know that you have an actual authoring recorder drive then you most likely have the general purpose type.
DVD-R is a write-once recordable format which allows excellent compatibility with both standalone DVD-video players and DVD-ROM drives. There are two main types of 4.7GB DVD-R discs: DVD-R for General Use and DVD-R for Authoring. Most consumer drives use the former cheaper General Use discs, while many higher end professional drives use Authoring discs. The correct media type appropriate for the drive must be used when burning. However, once burned, the discs should be able to be read in either drive type. (General Use DVD-Rs are designed to prevent backup of encrypted commercial DVDs).
DVD-RW uses rewritable discs which are rated at more than 1000 rewrites in ideal situations. Unfortunately, DVD-RW does not enjoy the same excellent compatibility with DVD-ROM drives and standalone DVD-Video players that DVD-R enjoys. Another drawback is that unlike DVD-RAM, one must generally erase a DVD-RW disc before reuse.
Most DVD-RW drives should also be able to record to DVD-R. However, the reverse is not true. Many older and some current DVD-R drives are not capable of writing to DVD-RW discs (but may be able to read burned DVD-RW discs). Some drives can also record to CD-R and CD-RW.
Currently DVD-RW and DVD-R are most popular in the multimedia market as well as the general consumer market. For instance the Apple SuperDrive, found in higher end Mac computers used in multimedia creation, is simply a DVD-R/DVD-RW (and CD-R/CD-RW) capable drive.
DVD+RW, like DVD-RW, is a rewritable 4.7GB DVD format. DVD+RW, however, in some ways offers some technical advantages, which for example include: lossless linking (which in turn more readily allows editing of a disc's contents after an initial write while maintaining integrity of the remaining data), currently slightly faster recording speeds, and optional future Mount Rainier drag-and-drop file access support (also known as DVD+MRW). However, DVD+RW does not have the very high compatibility with standalone DVD-video players and DVD-ROM drives that the DVD-R format enjoys. The level of compatibility of DVD+RW is said to be similar to that of DVD-RW. Also, DVD+RW does not currently have the same level of market acceptance as DVD-R.
DVD+R is a format that only was introduced to the public very recently (early 2002). DVD+R is a write-once 4.7GB format which promises to dramatically increase the compatibility with standalone DVD-Video players and DVD-ROM drives. Whether that claim is fulfilled remains to be seen, but initial reports have been very positive. It must be noted, however, that 1st generation DVD+RW drives do not support DVD+R burning, and it is likely that most cannot be upgraded to do so either. If one wishes to have DVD+R burning functionality, one must purchase a newer drive specifically designed to do so. DVD+R discs currently are somewhat more expensive than DVD-R discs, but prices will likely drop with time. Burners that write to these discs is the HPDVD100i and the DVD-Writer DVD200i drive
Thanks to www.AnandTech.com for this helpful information AnandTech Home
Mar 07, 2016 | Televison & Video
Recording/burning to disc
I searched your system and it shows a CD/DVD/RW.
So you can burn CD, DVD+R RW and DVD-R RW
So the most common DVD media would be the DVD+ media.
CD media would be all CD media. (info) RW: Re-Writable
Apr 07, 2014 | Computers & Internet
Cannot burn dvd
Does your DVD drive say DVD-ROM or DVD-RW? If it just says rom you can't burn discs. If it is RW do you have software to burn discs?
Dec 23, 2012 | Electronics - Others
I had a bunch of pictures on a DVD-RW that I transferred to a more permanent media. I then reformatted the DVD-RW disk. Now when I go to properties it says: Used space: 3.49 GB Free space: 906 MB How do I...
Rewritable DVD discs allow you to record and erase lots of times (up to 1000). Similar to DVD-R disc and DVD+R disc, DVD-RW is approved by DVD Forum, while DVD+RW not
did you finalise the disk after you finished the burn? depending on which burning software you are using some ask if you want to finalise the disk after a burn others just finalise or you might need to select multisession before the burn starts
hope this helps
Sep 08, 2011 | HP Computers & Internet
Mac mini superdrive ejects discs
Hi
I think the answer is in your question. Pioneer DVD-RW drive, DVD+R disc.
For some reason known only to Apple, some drives do not work with all discs. Mine will not burn -R dual Layer discs.
Nov 23, 2009 | Apple Mac mini 2.0GHz
Can read but can't burn dvd drive in toshiba laptop
IF YOU HAVE WIDOWS VISTA, IT WILL WONT ALLOW TO MAKE COPIES, OR THE DISK YOU ARE BURNING IS RIGHT PROTECTED...IF THESE ARE NOT THE PROBLEMS CHECK YOUR BURNING SOFTWARE SETTINGS...OR LAST THING IS TO CHANGE YOUR DRIVE
Oct 14, 2009 | Sony Toshiba Qosmio F45-AV411 Notebook
Burned DVD video couldn't play
are the videos you are rying to burn store bought
Mar 25, 2009 | Ricoh MP5240A (RICOHMP5240A) DVD+RW Burner
MP3 files on a DVD+RW disc - not all display or play
Toshiba SD-3990 does not recognize DVD+R/RW discs. You need DVD-R/RW
Jan 09, 2008 | Toshiba SD-3990 DVD Player
DVD+RW problem
When burning CD/DVD use a lower burning method... as not to rush data to burn and make sure that before burning the let it verify or test the data burned on the CD/DVD... it takes time, but be patient, after all it is your data.
Dec 10, 2007 | LaCie d2 DVD-RW Burner
Computers & Internet Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
