Question about Samsung HP-R5052 50 in. Plasma HDTV
Picture has specs thru it also black on bottom and lines running left to right.
    Genius:
  • Samsung Master
  • 1,039 Answers
Check the flex cables on the buffer boards. be sure to disconnect power supply from the sustsin boards before removing cables.If not panel is bad. Check VA and VS voltages. The voltages are listed on the panel back. Measure on the connector of the power supply. Adj are on the power board. Measure with respect to ground. Be sure all connectors are reconnected before power is turned on.
Posted on Sep 12, 2009
I have two sets of black horizontal lines going across my Sony Bravia KDL-52Z5100. If you make the picture smaller the lines extend into the black area that is not part of the picture. After the TV warms...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Take care in solving the problem...
Aug 06, 2011 | Televison & Video
Hitachi plasma 55HDS69 had lines going thru it then heard sizzle sound and went black.
I hope this will help in solving the problem and do take care....
Jun 26, 2011 | Televison & Video
Fine line running from left to right across page but fades about half across page to nothing, if you print from memory no line, if you run origional thru adf no line, What is causing this line when...
if it is copied on long or legal size of paper are the fine lines on top to bottom or left to right? if it id from top to bottom check for the charge roller, clean an dry it with a cloth, wet with alcohol or water. if from left to right on a legal size of paper check for any vibration coming from the developing unit, like loose gears.
Mar 05, 2010 | Ricoh Aficio 450 Copier
SONY TV PICTURE WENT BLANK WITH A STRAIGHT LINE THRU IT
want to know wat straight line. 1.white line in the middle from left to right or 2.white line from bottom to top there is a big diffrence in these two lines if 1 then u have to check the cvertical section ,the o/put may gone bad if 2 then u have to check the scanning coil
Jan 09, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Ewd2202 dvd/vcr combo when i put a vcr tape i can
the video heads are probably dirty.there is a steel drum 1/2 inch thick that you can see if you look thru the front lid where the tape loads.the video heads are little black spec looking things on the bottom of the drum.the easiest way to clean the drum for a novice is to put isopropyl alcohol on a piece of 2 inch square paper.hold the paper very lightly against the drum with your right index finger.turn the drum from the top,anti clockwise.you will see some black stuff on the paper.do the same with a piece of dry paper.otherwise the tape will stick to the drum if still wet.DO NOT use a q tip,as it will get caught in the heads and break them.
sometimes,just running a new blank tape for 15minutes will dislodge the particles and the picture will re appear.if you have recently rented a movie,and saw lines running across the screen,and noise from inside the machine,it is damaged tape going across the heads and drum and it can wipe out the picture just like that.run a blank tape first and then clean the drum if you have to.
Jul 07, 2009 | Emerson EWD2202 DVD Player/VCR
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
2" black line from top to bottom
my Black line is horizontall top to bottom more to the right hand side
Dec 10, 2007 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
Picture is now a thin horizontal line
now only visible in a thin horizontal line. first of all you reduce brightness to monimum. it just to protect your tv from crt demage. your problem is in horizontal output section as you have mentioned that week or so ago the right and left bottom edges of the picture began to move in like a sideways triangle filled with black so this sympton is due to hor. section problem. your flyback transformer or horizontal output might be defective. but remember check for power supply is ok from surge protector hope this will help.
Oct 07, 2007 | Hitachi 35UX80B 35" TV
Line going thru the tv
Josh, When you say a line going through your TV is it a line from left to right or top to bottom? Is there a picture present and this is a line imposed on the picture or just a line by itself? Let me guess, you have no picture just a horizontal line (from left to right) across the middle of the screen. If so that is collapse of the vertical deflection and most likely caused by failure of the vertical IC and possibly linked to some bad caps in theat circuit as well. It's not an expensive repair, just find a good reputable shop. You might also mention, or if they ask, that your unit is a lighbox. Meaning that when they go to repair it the insides of the unit separate from the cabinet for easier access.. Good Luck Bill
Jun 12, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Samsung HP-R5052 50 in. Plasma HDTV Logo
206 people viewed this question
Jerry Greenberg
Jerry Greenberg
