Question about GE Microwave Ovens
GE Microwave, how do i find what parts i need to fix itDoes not heat, smokes a little.
  • Gary Jensen Sep 11, 2009
    I will try! Thank you.
  • GE Master
  • 13,433 Answers
Hi
Try http://www.repairclinic.com/
Also http://www.partstore.com/
These two places sell alot of microwave parts, I imagine these will have what your looking for.
Almost forgot - http://www.partselect.com/ - this website has very good diagrams.. aswell alot of parts.
Hope this answers your question.
Posted on Sep 11, 2009
Black smoke coming from exhaust of GE profile microwave
Possibly something cooked that shouldn't have been
Sep 13, 2017 | GE Microwave Ovens
My GE Profile JVM1790 convection microwave has issue. Was using the convection portion when a small spark and flame appeared and then went out and soot and smoke was all inside and now will not heat up...
Yep, that sounds very much like the heating element burned out. It happens. You should be able to get a replacement from the manufacturer's website... or there may be a list of repair centers in the manual - pick one & try to order the heating element through them.
Aug 13, 2014 | GE JVM1790 Convection / Microwave Oven
My GE microwave convection oven JVM1790SK 01. It has started to make a load grinding noise, and is sparking above the cavity area, otherwise it operated properly. When I remove the fan assembly part...
The fan is for air circulation regulation, e.g. preventing steam (and smoke) from building up inside, and also stops air pressure from building up inside so you won't get a blast of steam coming out or worse. On the convection side it heats the food faster and more evenly. You will need to replace the fan assembly to keep the microwave safe. the noise and sparks are probably due to spent bearings and / or a dislodged fan scraping against another surface or something getting in the way of the fan
Nov 30, 2017 | GE JVM1790 Convection / Microwave Oven
GE eterna spacemaker microwave won't heat
The problem is a magnetron, "heart of the system" or the inverter board, "if 7 years old or less" and possibly the keypad control board, all of these items are not cheap and lethal voltages are present.
May 05, 2012 | GE Microwave Ovens
I have a GE SpacemakerXL microwave oven - Model JVM1640WB004, S/NTZ979368S. It is no longer heating. The lights, fan and rotating tray are still working. Will this repair be so expensive that it would be...
When there is no heat, but everything else seems to work, it means the magnetron circuit has failed. The magetron is the part the generates the microwaves that heat the food. When it fails, it makes a loud buzzing sound. The replacement part can cost as much as a new oven, so it not worth fixing. Get yourself a new oven.
Feb 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave runs however it is not heating. I replaced Magnetron and it still doesnt heat. As I was replacing it I noticed a little debris around the HV Capacitor. When I turned it on there was smoke...
Not sure if they will or not. The magnetron is a fairly simple replacement. Soldering does take some skill and can easily ruin a control board if you do not know how to removed and replace components. If you know how to solder, just read the information off of the capacitor then search online for a direct replacement. More than likely it would be cheaper that way then getting it from GE (if they sell them).
Nov 29, 2017 | GE JES2251SJ Microwave Oven
Microwave does not heat
your magnatron tube (what heats the food) is out, if it is not still in warranty it will run 200-300 to fix, might be better to replace sorry
Jun 08, 2010 | GE Adora DVM1850 Microwave Oven
GE microwv-doesn't heat, strong electrical smell, all else ok
The most common problem would be your magnetron. Check your purchase date, magnetron's usually have a five year warranty. Not a part I recomend trying to fix yourself (high voltage ).
Mar 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Please Help my GE Microwave produces no heat!!
Most of the time it seems to be the magnetron. The Magnetron is what heats the food, when you remove the magnetron sometimes you will see signs of wear like a black or brown spot on the tube sometimes there is even a hole burned through. A cheap place to find these part is Global Micro Parts in Dallas TX. Usually Magnetrons are about $30 - $45 and shipping is only 7.95 there web site is www.allapplianceparts.com
Oct 26, 2008 | GE JVM1850 1000 Watts Microwave Oven
GE spacemaker xl1800
more than likely the fuse has blown onthe magnatron it is the button looking thing on the magnatron with two wires. there are 2 of these one is on the magnatron the other is above the heat box test these for open. if open replace. if good then replace the magnatron.
May 02, 2008 | Microwave Ovens
Microwave Ovens Logo
15 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
