Question about Dryers
My dryer will start and run for about 1 minute then shuts off. It does heat and drum does turn. I wait about 15 minutes or so and then I can restart but the same thing happens again.
  • 93 Answers
Possibly a bad safety switch that senses an overheat condition. Is your vent clogged anywhere? If it is electronic control it could have a problem with the control board.
Posted on Sep 11, 2009
How do I fix my Whirlpool dryer that tries but won't spin the clothes or turn on?
The overheat sensor may be defective. In addition, the belt may have stretched resulting in uneven rotation of the drum. If you use softener sheets, there may be residue clogging the discharge of the drum.
Jan 19, 2015 | Whirlpool Dryers
Hotpoint Condenser Dryer Shuts Off After 5 Minutes
what is your model number is then we can get started then okay
Feb 01, 2013 | Dryers
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
I have an Amana NED7200TW dryer that is approx. 2 1/2 years old and am having issues. The first sign of a problem was it would not come back on after running a 40-50 minute cycle. Nothing would come on,...
Open the cabinet and look for lint buildup around the motor. Lint will act like a blanket and hold to heat in on the motor which in turn will cause it to shut down by way of it's safety mechanism. Check that out and post back your findings.
Oct 16, 2012 | Amana NED7200TW Electric Dryer
My dryer keeps shutting off after about 10-15 mins. It starts make a noise likes it's slowing down just before it shuts off. If I try to push the knob back in to restart. It will make a buzzing noise. If I...
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Mar 13, 2011 | Dryers
Whirlpool LER4634EQO Runs for about 2 minuts and shuts off.
It is possible your Cycling Themostat is not working properly. It determines at what temperature to turn heat on and off to maintain a consistent dryer temp. The High Limit Thermostat would turn off the heat but your dryer would still run. That leaves the Thermal Cut Off which is turning off your dryer. It might be faulty and turning off at too low a temp, or it might be doing it's job. In that case something else is wrong. If you can check the exhaust air temperature at the dryer, it should be under 175 degrees. If you are absolutely sure the vent is clear, then replace the Dryer Cycling Thermostat.
Aug 25, 2009 | Dryers
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Dryer runs for a few minutes, then shuts off
thermo sensor inside is bad (are you sure ALL vents and pipes are clear?)
Mar 12, 2009 | Dryers
Dryer only works for about 20 minutes, buzzes then stops.
the dryer is over heating up due to a blocked steam pipe , fluff build up inside the dryer. I have a dryer that id the exact same thing , found out it covered in fluff though out the whole dryer , motor and element ..
Jun 21, 2008 | Dryers
TGDX64OEQ1 Gas Estate Dryer
Sounds like the hi-limit temp switch is sensing too high a temperature and is shutting off the dryer. This is a safety feature and is usually tripped because the outlet air flow is restricted, and resets itself after it has cooled down. Check to see whether the rest of the vent in your house is clogged and clean it. It could also be an inlet fan or blower which introduces air into the drum. If this is not working, there will be no air flow into the dryer, causing excessive heat in the non-moving air in the dryer.
Feb 01, 2008 | Estate TGDX640JQ Gas Dryer
Dryers Logo
82 people viewed this question
Top Dryers Experts
