Question about Toshiba Satellite M40-S417TD Notebook
Missing or corrupt windows\system32\config\system file in XP
My Toshiba Satellite M40 displays the following message "windows could not start because the following file is missing or corrupt:
\windows\system32\config\system
It then suggests I can repair this file using the original setup CD ROM. I have the Product Recovery DVD-ROM supplied with the computer but the laptop doesn't access it. When I insert the DVD in the drive and reboot I get exactly the same message.
Any suggestions?
Harv
  • sciberteach Dec 11, 2007
    Thanks anyways Amanzoor
    This solution didn't solve my problem but it did give me the confidence to try the solution outlined on the MicroSoft page. I had found the page earlier and was going to try it but I wasn't sure if this was the "best" way to tackle my problem.
    Unfortunately I wasn't able to either delete the files in the \windows\system32\config folder or copy files from the \repair folder into it. So I've opted for a less satisfactory but acceptable solution. I'm using BartPE to access the data on the C drive of the laptop and copy it over to an external hard drive. After that I'll wipe the drive and re-install XP.
    Even though it didn't solve my problem the advice was helpful and I appreciated the support. It was a ton more than I got from Toshiba.
    Cheers
    Sciberteach
    Scholar:
  • 102 Answers
Sciberteach:
Go in the BIOS, in the boot sequence make your DVD player as the 1st number device to boot from, restart your machine and do follow the article (you should know the admin password to go into the system drive):
http://support.microsoft.com/kb/307545
Note: If you are too overwhelmed then your Product recovery DVD will give you your original OS and all settings back.
Posted on Dec 10, 2007
Im on my pc and im wondering where i can find a free download that can help me i get this message on my toshiba satellite a85s107... File missing or corrupt: \windows\system32\config\system\
Assuming you already tried pressing F8 on boot up and trying to get it into safe mode to run a disc check and that did not work?
This is a configuration file that can only be repaired by the use of OS installation CD, which if the laptop is booted with the disc in the drive and the bios is sett o boot from the DVD drive first, will give you the option to carry out a repair of the installation
Jun 21, 2012 | Toshiba Satellite A85-S107 PC Notebook
Following files missing or corrupt: \windows\system32\config\system
Well this means one of important files needed to start Windows is corrupted (it's a registry file).
I'd recommend repairing Windows installation. If you have Windows XP and also the Original Windows CD follow: this guide.
Dec 31, 2011 | Dell OptiPlex 740 (BPCW6TT) PC Desktop
I can't open windows xp i got this message:\r\n"unable to read file C:\windows\system32\config\software " I tried to fix it thru recovery console copying the i386 file but nothing happenned Help me please
hi You need to get a Windows XP from someone and follow these instructions: Windows could not start because the following files is missing or corrupt \WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your Windows XP CD. 2. At the first R=Repair option, press the R key 3. Press the number that corresponds to the correct location for the installation of Windows you want to repair. Typically this will be #1 4. Enter in the administrator password when requested 5. cd \windows\system32\config 6. Depending on which section was corrupted: ren software software.bad or ren system system.bad 7. Depending on which section was corrupted copy \windows\repair\system copy \windows\repair\software 8. Take out the CD ROM and type exit
Aug 28, 2010 | Microsoft Windows XP Home Edition
I have toshiba L300 pc laptop, i tried to formati
kindly follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
My tecra 8000 fails to boot cannot find config sys
Originally Posted by Don this problem occurs when you try to update drivers in the computer..sometimes windows XP cannot update the driver and that corrupts system.ini file as it has a lot of bad entries..Due to this you will get this error mesage..No its not due to virus.its due to an attempt to change system.ini file
Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
That means the System Registry Hive has become corrupted.
There are two ways to get back up and running. The easy way which doesn't always work, and then there is the hard way.
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console2.gif.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Aug 22, 2009 | Toshiba Computers & Internet
Toshiba laptop problem
boot your laptop from a xp cd and select repair option
Sep 30, 2008 | Toshiba Satellite A105 Notebook
Windows wont start up
NEED YOUR PC/LAPTOP REPAIRED......
ARE YOU HAVING ISSUES WITH YOUR PC OR NOTEBOOK NOT WORKING THE WAY YOU EXPECTED
well if your having issues with your wireless/black screen issues/bad-slow performance/
nb settings/error messages/recovery and restore/Internet Explorer/pop ups/Microsoft/sound
/software/hardware, pretty much anything at all why not try me FOR FREE at moonbayboys@hotmail.com
....i also help with the removel of virus/spyware/malware
Jul 31, 2008 | Toshiba Satellite A105 Notebook
Having problems with my compaq Persario 2500
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
md tmp
md tmp
Oct 11, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
Toshiba Satellite M40-S417TD Notebook Logo
345 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
